2nd Gen Tacoma 4.6 V8 1UR-FE and GX powertrain Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dpanibratets, May 22, 2022.
  1. May 23, 2022 at 5:28 PM
    #61
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    this would be the challenge id like to know about.
  2. May 23, 2022 at 5:34 PM
    #62
    dpanibratets
    dpanibratets [OP] Well-Known Member
    Denis
    Vancouver, WA
    2005 DCSB soon to be with V8 1UR-FE
    There may need to be parallel fuse boxes. One to keep existing systems running on the tacoma, the other to power this engine.
    MSN88longbed, saf023 and Reggie4x4 like this.
  3. May 23, 2022 at 5:37 PM
    #63
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    I know getting the factory gauges to work has been one of the bigger hurdles doing swaps into Tacomas.
    Kind of thinking if I were trying this, I would try to use as much of the donor in that regard. Driveline, ECU, cluster, BCM etc.
  4. May 23, 2022 at 5:45 PM
    #64
    dpanibratets
    Denis
    Vancouver, WA
    I think it will be easier to get the Tacoma Gauge to work than make the GX cluster to look aesthetically pleasing in the Tacoma dash. As much as I would like the GX cluster I don't think that is a hill I am willing to die on.
  5. May 23, 2022 at 6:07 PM
    #65
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    X2
    :popcorn::popcorn:
  6. May 23, 2022 at 7:02 PM
    #66
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Same, Screw all the BS I want to see the final results.
  7. May 23, 2022 at 7:06 PM
    #67
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    That would be correct. At least that’s what the forums said when I last checked 6mo ago. I meant to say HP’s opened the door for tuning Toyota/Lexus. I’d be surprised they don’t add the GX in the future given how popular it’s been with the overlanding community and how pig rich the OV guys claim the stock tune is.
    saf023 likes this.
  8. May 23, 2022 at 7:12 PM
    #68
    henryp
    Henry
    Montana
    If only these guys would make one for the taco.
    https://www.carobotor.ca/shop/fjdashboard/
  9. May 23, 2022 at 7:26 PM
    #69
    Richie Rich
    760 (San Diego)
    Wonder how hard it would be to swap the whole dash in? They are similar size. Tacoma with the bougie Lexus dash, seats, console etc.
  10. May 23, 2022 at 7:33 PM
    #70
    Jesse
    Poulsbo
    15' DCSB OR S/C
    agreed. if i knew how....
  11. May 23, 2022 at 7:40 PM
    #71
    dpanibratets
    Denis
    Vancouver, WA
    Also crossed my mind, unfortunately mine is beige interior and to me that is a downgrade.
  12. May 23, 2022 at 7:48 PM
    #72
    Jesse
    Poulsbo
    15' DCSB OR S/C
    the journey is where results happen.
  13. May 23, 2022 at 9:36 PM
    #73
    dpanibratets
    Denis
    Vancouver, WA
    Well I'll tell you what boys, just looking at it makes me excited20220523_113811.jpg
  14. May 23, 2022 at 9:50 PM
    #74
    Scorchedtaco
    Scorchedtaco Well-Known Member
    AZ
    2012 ac trd 4x4 sc , 2012 sequoia 4x4
    Whats the horsepower and torque of the 4.6 ?
  15. May 23, 2022 at 9:52 PM
    #75
    dpanibratets
    Denis
    Vancouver, WA
    301hp and 329 ft lbs
  16. May 23, 2022 at 9:54 PM
    #76
    Scorchedtaco
    AZ
  17. May 23, 2022 at 10:13 PM
    #77
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Unless you also want to use the electric brake booster I see no need for two under hood fuse boxes. There will be lots of repinning wire connections though. Lots. Engine immobilizer may be a challenge. Taco doesn’t have it but the GX does. Hope you got the keys with the donor truck. Hold on to those!
    edit: I think the Taco actually does have an immobilizer
    jjgandarillas and TomTwo like this.
  18. May 23, 2022 at 10:51 PM
    #78
    dpanibratets
    Denis
    Vancouver, WA
    Whenever you play a car on copart or iaai you are guaranteed that the keys will be stolen. Copart claimed that it had keys and ran, picked it up and the keys are missing. I ordered a oem key today, I will have a lock smith come out to program the key. I will make sure it runs prior to tearing into it. Good advice thanks.
    Additionally yes, I do want the electronic brake booster and traction control. I think the gx fuse box will have all systems that the tacoma currently has (and then some). Likely I will have to match tacoma wires to gx fuses/relays with the corresponding circuits.
  19. May 24, 2022 at 11:12 PM
    #79
    dpanibratets
    Denis
    Vancouver, WA
    Does anyone know if the GX rear diff, that is 8.2 inch, will bolt into a tacoma axle housing? Along with the axle shafts.
  20. May 25, 2022 at 12:57 AM
    #80
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Unsure but why not use the GX axle? Weld on leaf perches and so what needs to be done. weld on a 12” relocation for some extra fun. Since you want to keep the rear disc setup of the GX
