2nd Gen Tacoma 4.6 V8 1UR-FE and GX powertrain Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dpanibratets, May 22, 2022.
  1. May 25, 2022 at 8:33 AM
    #81
    dpanibratets
    dpanibratets [OP] Well-Known Member
    Denis
    Vancouver, WA
    2005 DCSB soon to be with V8 1UR-FE
    One side is scrap and there is a chance that the other side is not. If the other side and the diff check out okay then the cheapest option will be just to buy a low mileage axle shaft from a wrecker. A whole rear axle would run me in the neighborhood of $1500 bucks. It would be nice to just install existing parts into my tacoma housing.
  2. May 25, 2022 at 3:53 PM
    #82
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    gotcha makes sense. curious if it would or not. Diff is is 8" vs 8.2" splines may line up but not 100% I know the t4r/fj the lines in the CVS are different but where it hooks up to the knuckle and diff they are the same.
  3. May 25, 2022 at 4:37 PM
    #83
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    saf023 and replica9000[QUOTED] like this.
  4. May 25, 2022 at 7:05 PM
    #84
    dpanibratets
    Denis
    Vancouver, WA
    Little Tacundra
    fatfurious2[QUOTED] likes this.
  5. May 25, 2022 at 7:08 PM
    #85
    fatfurious2
    David
    Ashburn, VA
    Whipbash was insane at wiring. I would have cried 9 times, then probably lit it on fire, and given it away. I hate wiring, but if you know how to do it, many many props to you! I look forward to seeing your build come out. Definitely check out his videos. If theres one thing I learned, is remember the immobilizer in the ignition
    saf023, Biscuits, SR-71A and 4 others like this.
  6. May 25, 2022 at 7:20 PM
    #86
    dpanibratets
    Denis
    Vancouver, WA
    I have seen his videos and partially was inspired by his swap to do my own. I have enough experience to take on a wiring project like this. I plan on downloading both factory service manuals from TIS. I can't wait to tear into it.
  7. Jul 23, 2022 at 8:11 AM
    #87
    dpanibratets
    Denis
    Vancouver, WA
    Okay everyone, I am starting to swap out the diffs. I got 4.56 gears, I am going to be running 275/70R17 10 plys. In order to retain AWD from the Lexus I have to swap the front diff housing extension and shaft to delete the 4WD A.D.D. Additionally, I found that the gx460 transmission support cross member appears to be about 3 inches more towards the rear. I suspect I will have to plasma cut and weld the cross member in the correct spot. I will bolt the tranny to the engine prior to cutting anything to verify location. The good news is that there is enough box frame to move it back 3 inches before the frame becomes a C channel. 20220720_113824.jpg
    PistonHead81, dborrer, Maxx and 13 others like this.
  8. Jul 23, 2022 at 8:42 AM
    #88
    henryp
    henryp A member of TW
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
  9. Jul 23, 2022 at 4:18 PM
    #89
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
  10. Jul 26, 2022 at 8:08 PM
    #90
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Subscribed
  11. Jul 26, 2022 at 8:34 PM
    #91
    dpanibratets
    Denis
    Vancouver, WA
    I took the axles out today, working on taking the diffs off because I have to get the cores sent back to east coast gear supply with 30 days to get my deposit back. 4.56 gears, new hubs and new brakes going in. 20220726_124008.jpg
  12. Jul 27, 2022 at 8:02 AM
    #92
    Rmtomasin
    Rmtomasin Well-Known Member
    2011 Super White Tacoma Access Cab V6 6SPD
  13. Aug 15, 2022 at 8:29 PM
    #93
    dpanibratets
    Denis
    Vancouver, WA
    Hey Everyone,
    I got a key programmed to the Lexus, engine runs great and transmission is shifting fine. Good news.
    See video here:
    https://youtu.be/mdo61lrP9SM
    It is going to sound great with a magnaflow muffler.
    Over the weekend I pulled the driveshafts, CVs, LCAs, spindles and I plan on using all of those parts on the Tacoma. Interesting fact, the spindles appear to have holes in them for a sway bar link even though the all gx460s have KDSS which has a sway bar that bolts on to the LCA. The LCAs appear to be similar with the exception of a bracket that holds the sway bar that is welded on to the original LCA. There may be a difference in a mounting bolt diameter, cross that bridge when we get there. Tomorrow, I am pressing on new rear hubs, hopefully later this week the rear axle will be fully rebuild with 4.56 gears. This Saturday, I would like to pull the tranny out of the GX. Like I said before, the transmission support cross member will need to be relocated. I will likely cut it off when the transmission is out. So far everything is looking good.
    Lastly I got to thinking about brake lines for the brake booster today. I am pretty confident that I can make the front GX brake lines work in the tacoma engine bay. As for the rear lines the GX lines will not work due to the wheelbase differences in the two vehicles. I found out I can purchase lines that are pre-bent from a 2015 Tacoma that has a similar booster. I think I am going to go that route to keep things clean and simple.
  14. Aug 24, 2022 at 9:13 AM
    #94
    dpanibratets
    Denis
    Vancouver, WA
    Hey Everyone,
    To my surprise, I discovered that the exhaust headers interfere with the transmission removal. Basically the bell housing is trapped by the headers. The manual says to remove the headers and starter. To remove the right side header you have to remove the intake and oil dip stick. Everything is much tighter in this engine bay and harder to reach.
    On the bright side, I noticed the gas feed, return and evap lines come out in the same exact location in both engine bays! You can see it in the picture. The connectors look the same also. It's looking like they might just plug in. I will however install the gx fuel pump and it is my understanding that there might be a ECU for the fuel pump. Will keep you updated on that.
  15. Aug 24, 2022 at 9:16 AM
    #95
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You’ve done more than 90% of the “engine swap guys”.
    Definitely following this one.
    Good job on the progress:thumbsup:
    Anton338, FloridaFree, saf023 and 5 others like this.
  16. Aug 24, 2022 at 9:49 AM
    #96
    Tacobot14
    Tacobot14 Heep Recovery Vehicle
    Ty
    North Carolina
    2015 TRD OR White Tacoma 6MT
    OME BP-51, JBA UCA, SOS Streamline Bumper, SOS Sliders, Toyo AT2 tires, many more.
    Subbed.
  17. Aug 25, 2022 at 5:21 PM
    #97
    dpanibratets
    Denis
    Vancouver, WA
    I will have to use the GX steering wheel because it interacts with the LCD screen in the gauge cluster. There is a GX steering wheel that is leather and without wood. It is on the base model and I managed to find one on ebay yesterday. My existing steering wheel is Sepia (biege) color with a wood grain. Also I found a seller on ebay that sells black airbag cover so I will use my existing airbag.
    #97
  18. Aug 25, 2022 at 5:24 PM
    #98
    dpanibratets
    Denis
    Vancouver, WA
    I got both exhaust manifolds off, hopefully the tranny will be out this Saturday. There is no way the engine would come out with the exhaust manifolds on. If you're going to do a swap like this, buy a late model and low miles. I am really impressed that the hardware is like new when this car is 6 years old and 70k miles
  19. Aug 25, 2022 at 8:59 PM
    #99
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    I couldn’t believe how clean the engine and hardware was when I did the 4x4 conversion. Dude your build is awesome!
  20. Aug 26, 2022 at 2:32 PM
    #100
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Are there aftermarket headers for the GX460? What a nuisance the headers need to be pulled first to pull the motor OR trans!
