2nd Gen Tacoma 4.6 V8 1UR-FE and GX powertrain Swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dpanibratets, May 22, 2022.
  1. Jan 18, 2024 at 7:45 PM
    #1041
    dpanibratets
    dpanibratets [OP] Well-Known Member
    Denis
    Vancouver, WA
    2005 DCSB soon to be with V8 1UR-FE
    Okay guys I need another phone a friend on this one. Remember that I had to switch the GX460 window regulator motors from left to right and vice versa to make them fit on the to window regulator. Well the problem now is that the master driver window switch lowers the right window with the left switch and vice versa. Additionally the switches are inverted, up is down and down is up. Not good, I need suggestions.
    The trouble is that I could invert the wires coming off of the window switch but the body ecu communicates via CAN network to the window regulators. I seems that the window regulators have their own individual bit signal that identifies them as right or left.
  2. Jan 18, 2024 at 8:08 PM
    #1042
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Looks like they operate on a LIN bus, quite a complex setup just for power windows.
    Based on what I can see on the wiring diagram and the description of the system I have to assume each window motor is hard coded with it's position on the truck and the Master Switch sends commands out on the LIN Bus that tell each motor what to do, since they (the motors) are on opposite sides from where they belong they won't operate properly.
    If you could somehow swap just the electronics and/or motors from side to side (if that's possible?) that should correct your problem.
  3. Jan 18, 2024 at 8:16 PM
    #1043
    dpanibratets
    Denis
    Vancouver, WA
    I agree with you on the complex part. First this that came to my mind was to swap the electronics, they are detachable to but appear to be side specific. I am going to look at lx570 window regulator.
  4. Jan 18, 2024 at 8:19 PM
    #1044
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Will the complete motors swap?
  5. Jan 18, 2024 at 8:27 PM
    #1045
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Looks like those are even more complex than the GX460.
  6. Jan 18, 2024 at 8:28 PM
    #1046
    dpanibratets
    Denis
    Vancouver, WA
    It will but it is upside down and doesn't line up with the hole on the door. Before I got hacking up the door, I just wanted to see if there is anything off the shelf that could solve this issue.
  7. Jan 18, 2024 at 8:33 PM
    #1047
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The 2016 Tacoma withe jam protection appears to use the same setup and connectors for the front window motors, whether or not they will work with the Lexus system I couldn't tell you.
  8. Jan 18, 2024 at 8:37 PM
    #1048
    dpanibratets
    Denis
    Vancouver, WA
    Hmm that makes me wonder. The gx460 front window motors bolted right in. I wonder it those would work on the back window. I am going to take my front motor off and try it on the rear regulator.
  9. Jan 19, 2024 at 12:16 AM
    #1049
    dpanibratets
    Denis
    Vancouver, WA
    Okay so front motors are a bust although they do work with the window switch at the door, they don't work with the master switch as intended. It communicates the command via LIN network finds the motor and rolls down the right rear window when you pushed the front right window. Then I thought what if I just change the rear electronics onto the front window motor and same problem. That tells me the worm gear is not reversed in there, it seems that the polarity of the motor is changed by the computer of the motor. Anyway, I guess I'll hole saw a new hole with these window regulators mounted upside-down relative to the Tacoma.
    I will tell you what I really like about this Lexus window regulator system. When the auto up or down switch is pressed, they start slow, speed up to really fast and slow down before closing. That is really nice and feels high end.
    SR-71A and Tatts521 like this.
  10. Jan 19, 2024 at 3:17 AM
    #1050
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    MSN88longbed and SR-71A like this.
  11. Jan 19, 2024 at 5:22 AM
    #1051
    Gallowbraid
    Gallowbraid Known Problem
    This is due to Lexus focusing their car designs around omotenashi which roughly means "hospitality". The windows mimic the culturally proper way to open and close a tea house door in order to provide the least amount of distraction to other patrons inside. This focus extends throughout the build and design process on their vehicles. Doors have a very particular amount of sound deadening to not only block outside noise while driving, but also to cause the sound the door makes when it is closed to resonate at a certain frequency that is considered to be the least offensive. Malcom Gladwell did an episode of his Go and See podcast about Omotenashi and 5 other episodes about Lexus which are an interesting listen.
  12. Jan 19, 2024 at 8:14 AM
    #1052
    dpanibratets
    Denis
    Vancouver, WA
    That is very cool, I will check it out. The good news is that the window motor mounted upside-down does clear the door stop/dampener. I would've been in trouble if it didn't.
  13. Feb 29, 2024 at 8:14 AM
    #1053
    Pittsy
    Pittsy AKA LS6Taco - Ex car guy, current truck guy.
    AZ
    07 DCSB 4x4, 25 Tundra Limited
    BTF Fab +4.5 - DMZ SUA - TE Cage - LS6 Stroker Swap - LS6Taco
    Updates???
    TireFire likes this.
  14. Apr 2, 2024 at 3:54 AM
    #1054
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    iwashmycar likes this.
  15. Apr 2, 2024 at 10:51 AM
    #1055
    kozy
    kozy Well-Known Member
    Tim
    Arizona
    2006 Access Cab 4x4/6MT
    Any chance you have more info/pics on that fan setup?
  16. Apr 3, 2024 at 6:29 AM
    #1056
    MA_TACO
    Wesley Chapel, FL
    dborrer, essjay, tacoman45 and 4 others like this.
  17. Apr 5, 2024 at 6:22 AM
    #1057
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    This is something I might have to do to mine to be more comfortable in the truck. Never understood why electronic adjustable columns were kept away for such a cheap long whole unit system. I need to bring the column closer and hope to make power off a trigger to go to Forward and tilt up. Then memory back to the last position.
  18. May 12, 2024 at 3:24 PM
    #1058
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I wonder if this truck has been painted yet……
    I do hope it’s not just sitting, waiting to be finished….
    :mudding:
    TegoTaco likes this.
  19. May 12, 2024 at 3:30 PM
    #1059
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    What intake is that and how did you mod it to your snorkel?
  20. May 13, 2024 at 3:11 AM
    #1060
    MA_TACO
    Wesley Chapel, FL
