2nd gen tacoma inner fender lining after fender trimming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Riles10tacoma, Feb 19, 2020.
  1. Feb 19, 2020 at 12:07 AM
    Riles10tacoma
    Riles10tacoma [OP] Member
    Riley
    2012 Toyota tacoma
    6" fabtech lift, coilovers, 4.56 gears, more mods to come
    Hey guys,
    So I have a 2012 tacoma, doing some fender cutting and body mount chop but somethings kinda caught my eye maybe someone has already figured it out, idk.
    I’ve ripped out the inner lining and honestly don’t want to use that flimsy plastic anyways. When removed it just caught a TON of mud.(I drive logging roads almost year round)
    but now the inner fender is completely exposed and don’t really now how I like it.
    so, has anyone modified sheet metal or rubber mat to block the mud and shit to get up in there waay better than the cheap plastic shoved up there oem??
    if there’s any threads or if someone has done this before, chim in! thanks
  2. Feb 19, 2020 at 8:56 AM
    DNATACO
    DNATACO Well-Known Member
    Santa Cruz
    14 DCLB SR5
    2.5” Fox coilovers RR with DSC Deaver U402 stage 1 leaf pack ‘16 OR wheels on 255/85r16 Snugtop Rebel
  3. Feb 19, 2020 at 3:46 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear and all wheel bearings front /rear Yukon 3.73 ring/pinion rebuild Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 in 2024
    No help on what to do but remember that the air intake is in the passenger side dead space between the fender and liner so you may get a lot of crap sucked in now.
  4. Feb 19, 2020 at 3:49 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like a business opportunity
  5. Feb 24, 2020 at 8:55 PM
    Mech_Eng
    Mech_Eng Well-Known Member
    Birmingham, AL
    2009 TRD 4x4 DCSB
    See Build Page
    I've spent the last week researching this. Seems the best solution is 1/8" abs sheets and clip nuts. Make a cardboard template first. I am in the process of building some now. Like most things in life, I'm sure it's easier said than done. This is a picture of someone else on Tacomaworld. Again it's not my truck, but what I am trying to replicate. IMG_5001.jpg
    will.i.was likes this.
  6. Feb 25, 2020 at 9:32 AM
    DNATACO
    Santa Cruz
    14 DCLB SR5
    Again, www.geartechcustoms.com
