2nd Gen Tacoma LED Brake Lights are not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raco.the.taco, Jul 28, 2016.
  1. Jul 28, 2016 at 5:15 PM
    raco.the.taco
    raco.the.taco [OP] Well-Known Member
    Chad
    Denver, CO
    Locked, Geared & 1/2 Long Traveled
    Pelfreybilt Front Bumper, All-Pro Rear Bumper & Sliders, 35's, Toytect Boss Coilovers, JBA UCA's, DTF SUA Kit w/ E30 Deavers, Wheelers superbumps, Front & Rear Locked, 4.56 Gears
    I recently swapped out my 07 red (pink) tinted tail lights for the newer led style (led stock knock off) tail lights from eBay. Everything worked fine for at least a month until some friends behind me noticed that my brake lights weren't working today. I went through with the work day and reversing into my parking spot after work I noticed the brake light were working off the reflection. Pulled forward and did the same thing and they didn't work.
    Anyone have advice? I read about a ground issue from a post a couple years ago but I can find the connection that supposedly grounds on the bumper.
  2. Jul 29, 2016 at 5:37 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Do your collision avoidance lights on the cab work? If they work that means your brake light switch is good, of course also check fuses.
  3. Jul 29, 2016 at 9:55 AM
    raco.the.taco
    Chad
    Denver, CO
    It was the brake switch under the gas pedal. Phew
  4. Jul 29, 2016 at 10:18 AM
    topcathr
    2015 limited
    Glad to hear that. that's why I asked if the collision light worked. lol
  5. Jul 29, 2016 at 3:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Why do you have a brake light switch under the Gas Pedal?
    That doesn't make any sense...
  6. Jul 29, 2016 at 3:10 PM
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
  7. Jul 29, 2016 at 10:07 PM
    raco.the.taco
    Chad
    Denver, CO
    Amazing. I've had this problem for the last 3 weeks and have been using the override button. Didn't even realize it was connected. All I did yesterday to fix the brake lights was adjust the switch location so that it's tighter to the pedal. After that the adjustment my shifter started working. Thank you for the heads up. This community is amazing.
