2nd Gen Tips, Mods & More
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Mar 26, 2008.
  1. Apr 30, 2013 at 6:40 PM
    #181
    gjtacoma
    gjtacoma Active Member
    San Diego County
    4x4
    How to install a 1" body lift Sorry if its already been posted.
  2. May 4, 2013 at 2:20 PM
    #182
    Priddle
    Priddle And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    How to quickly remove a seized rotor, no hammer or mallet needed. It worked for me in 2 minutes after an hour of trying everything else. This is not my video.
    http://www.youtube.com/watch?v=mtsTJCRljAs
    I had a 1/4" piece of aluminum as a spacer and used the caliper bolt to press against the spacer. Note you need a large size spacer as the bolt overlaps with only 1/2 of the rotor surface, unlike this video. A spacer the size of a quarter as an example will not work.
  3. May 5, 2013 at 11:03 AM
    #183
    blanchard272
    blanchard272 New Member
    Steven
    Eielson AFB
    05 PreRunner lifted
    Lift, halogen bulbs, after-market radio
    Bought my wife a 05 tacoma with a little lift and doesnt ride all that great. What kind of shocks could i put on it to help with the ride?
  4. May 21, 2013 at 8:52 AM
    #184
    ExtremeCustoms505
    ExtremeCustoms505 Well-Known Member
    Albuquerque WS
    2010 Tacoma 4d 4x4
    3" Revtek spacer kit in front w/ aal and 1" block in rear. No TSB aal installed yet. Spider Trax spacers.
    Bilstein 5100 all the way around will be a huge improvement in my opinion.
  5. May 21, 2013 at 8:53 AM
    #185
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    what kind of lift is on there now? any pics?
  6. May 26, 2013 at 8:31 PM
    #186
    Norcal Taco Lover
    Norcal Taco Lover Member
    Andy
    Humboldt County
    Just want to give a shout out to all of the contributors, especially for the DIY write-ups, amazing job thank you!
    I bought an '07 4.0L Double-cab sport with 83,000 about this time last year and until this weekend all I've done is change the oil. Between yesterday and today however, I:
    Changed the front & rear diff., and TC oil
    Did the rear diff. breather Mod
    AC condenser drain extension
    Changed the Spark Plugs (1st time on 86,000 miles, plugs weren't completely toast either, but getting there)
    Changed Cabin/Air filter (didn't need write-ups for these, not that inept!)
    Planning on keeping this thing till the wheels fall off and I feel much more confident in that knowing I'll be performing most of the maintenance and saving so much $$ in the course of doing so. Keep up the good work!
    Timbuktu and Melinda like this.
  7. Jul 1, 2013 at 7:45 AM
    #187
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
  8. Jul 23, 2013 at 9:17 AM
    #188
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
  9. Jul 24, 2013 at 12:03 AM
    #189
    tillithz
    tillithz Active Member
    Oakland
    2013 Toyota Tacoma Double Cab PreRunner Sport
    Viper 5704 Tonneau Cover Rear view camera in Stock Head Unit
  10. Jul 31, 2013 at 2:50 PM
    #190
    biker921
    biker921 Well-Known Member
    Austin
    '17 TRD Pro
    GREAT sticky, thanks!!
  11. Aug 11, 2013 at 9:35 AM
    #191
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Pittsburgh, PA
    2013 Black Baja Access Cab
    I found this mod on a Tundra forum and thought it might be a good one to add tothe list. Its super easy – took about 20minutes – and my fogs are MUCH brighter now but still have the appropriate light pattern. I used standard Sylvania H9 bulbs, but there are also SilverStar bulbs available that would be even brighter. You can also get 100w H9 bulbs,but I’m not sure if this is safe for the wiring or the lens. Switching from standard H11 to H9 bulbs goes from 1350 lumens to 2100 lumens, while the wattage goes from 55w to 65w. Nobody on the Tundra site reported any problems after switching to the 65w bulbs.
    The pics are not mine, but they explain the process in detail. I also posted them in the "2012 foglight anytime mod" thread.
    Jerry311SD likes this.
  12. Aug 16, 2013 at 3:02 PM
    #192
    CampGuy
    CampGuy Well-Known Member
    Dmitry
    California
    2013 4x4 TRD-Sport
    Hey Guys, Anybody can help me find out the "Radio stay on when you remove the key from ACC"-MOD, Please,
    I saw it ones but can't find it now?! :(
  13. Aug 21, 2013 at 10:51 AM
    #193
    itacoma
    itacoma Member
    Definitely go with Bilstein 5100 might also have 5160 available. Check Bilstein's new website Bilsteinoffroad.com you can order online and call for tech info. Had a great experience myself.
  14. Sep 8, 2013 at 6:25 PM
    #194
    joshuabuilt
    joshuabuilt New Member
    josh
    san diego
    4banger 4x4
    bought a fog light kit for my Tacoma from ebay. the kit had no instructions, plugs that were not labeled, wires were either too long or too short and the switch would not fit the Toyota blanks without cutting them up. so I scrapped everything made my own harness waiting for a oem switch and wired the fogs to the running lights instead of the low beams. what a waist of 107.00
  15. Sep 11, 2013 at 8:08 PM
    #195
    whitetacoma1
    whitetacoma1 White Tacoma 4X4
    Dan
    Alberta
    2009 and 1997 tacoma 4x4
    3" toytec Lift front OME 885s and AAL in the back
  16. Sep 18, 2013 at 3:07 PM
    #196
    LAoffroadin
    LAoffroadin BURY ME WITH MY TACO!!
    Joshua
    Northwest
    2012 offroad 4x4
    ICON stage 5 coilers w/ ICON ucas, dakar leaf pack with Fox rears, k&n cai, LED cab light, raceline 16 inch wheels , toyo m/t 33",painted front yota emblem gloss white, retrofit headlights with mirrimoto 3 " lenses running the 6k headlights. Bhlm, bestopper, wet okole seat covers (max 4), weather tech mats,winch with piaa fogs. All pro apex front bumper. Sliders etc
    LOOKING FOR SOME IDIOT PROOF INSTRUCTIONS ON HOW TO WIRE IN MY (dont know why i was yelling) halos on my retros... any help? i cant seem to find a forum, maybe im not looking in the right place..:cool:
  17. Sep 18, 2013 at 4:41 PM
    #197
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
  18. Oct 21, 2013 at 9:50 PM
    #198
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    now why the hell would you ask about that?^^ :facepalm:
  19. Oct 21, 2013 at 9:51 PM
    #199
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Who says burnouts aren't smart?
  20. Oct 21, 2013 at 9:51 PM
    #200
    Jerez
    Rod
    Ontario Ranch
    Estock
    idk figured there would be a better thread to ask that lol
