2nd Gen Tips, Mods & More
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Mar 26, 2008.
  1. Dec 18, 2015 at 8:33 AM
    #461
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Agreed - but the issue is easily solved - cut bigger holes in the bed mat to allow spacers to be used between the d-ring and the bed. The mat will still be held captive by the -d-ring flange.
  2. Dec 18, 2015 at 8:47 AM
    #462
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    If you were to use an extra spacer like a nut, with a very large flat washer. You could torque the bolt down using the nut as a spacer, but the large flat washer would prevent anyone from removing the matt from the bed.
  3. Dec 19, 2015 at 10:25 AM
    #463
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    Precisely, I did a mild body lift, made sure my bolts could be used for that and torqued them into spec.
    Have fun fighting the thievery. (3+years and not an issue and I haul a lot of heavy ish, and do a lot of hard wheeling)
  4. Dec 20, 2015 at 12:54 PM
    #464
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Never had to a problem with my bed mat walking off. Hell if they want that heavy sob they can have it.
  5. Dec 22, 2015 at 2:55 AM
    #465
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    If they are extra bed bolts just for holding the mat down then torque holding bed to frame is completely irrelevant to keeping the mat in the bed.
  6. Dec 27, 2015 at 2:11 AM
    #466
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I cant find a master list of second gen torque values, for diffs, plugs, etc. i saw it I think, just cant find it
  7. Dec 27, 2015 at 8:40 AM
    #467
    MrOlearhy
    MrOlearhy One day at a time. Sometimes minute by minute.
    Tedd
    NW corner
    Small useful for me stuff.
  8. Dec 27, 2015 at 9:09 AM
    #468
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
  9. Dec 28, 2015 at 1:29 PM
    #469
    billybob50
    Bob
    Just installed this $35 dollar cruise control kit off of Ebay. Had an issue it didn't come with instructions. I also ended up robbing the ground wire from the old wire harness connector and installed it to the new connector for the air bag. The other issue was the plastic molding around the stalk wasn't correct for my model, but you can use it as a template to drill/file a hole. https://www.youtube.com/watch?v=TjoTus5q5p0
  10. Jan 4, 2016 at 8:35 PM
    #470
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Anything for suggested "emergency" tool kit, some basic tools that go a long way? Looking to build a box for when I go out, I.e. 3/4 deep socket with 1/2 in drive and a breaker bar for lug nuts (working off memory)
  11. Jan 4, 2016 at 8:51 PM
    #471
    Tacomatwo
    Tacomatwo -
    15MGMDCSBS 4WD
  12. Jan 5, 2016 at 4:36 AM
    #472
    billybob50
    Bob
    I can't believe the stuff, I and my wife have stored in back and under the seat! It's gotten to the point if there's an extra water bottle or tennis ball. I can't move the seat back after my wife uses it because of all the stuff, jams the track! Purchased a used plastic truck tool box off of Craigslist for $30. Best investment I've ever made!
    Biscuits, Bennoclarke and stbear like this.
  13. Jan 7, 2016 at 2:08 AM
    #473
    MattLikesTacos
    MattLikesTacos Well-Known Member
    Matthew
    2015 Tacoma sr5 Access cab
    I can't seem to find the Bhlm anywhere can someone help me out!
  14. Jan 7, 2016 at 2:17 AM
    #474
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Black headlight variations
    Links in Posts 9 & 10 of that thread.
  15. Jan 18, 2016 at 11:47 PM
    #475
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    Is there a abs deleate link somewhere? Not doing well searching on my phone
  16. Jan 19, 2016 at 2:17 AM
    #476
    DrFunker
    DrFunker Well-Known Member
    I see you found it. :thumbsup:
  17. Jan 20, 2016 at 3:22 AM
    #477
    Redgrom
    Brent
    san clemente
    Nothing like a slow long night shift to google the night away!
  18. Jan 24, 2016 at 10:55 AM
    #478
    billybob50
    Bob
    Purchased a Mcgard 76029 Tailgate Lock and realized it's body was a hair too tall. Instead of returning it I ground off the top part of the body w/name an 1/8 of an inch and a 1/8 of an inch off the bottom corner heal. This allow enough clearance in closing the tailgate without binding. Also installed two plastic tie wrap in each key hole, so it makes it a little more difficult for thieves in removing the tailgate support cables.
  19. Jan 24, 2016 at 11:04 AM
    #479
    black_cukui
    black_cukui Well-Known Member
    Patrick
    Riverside, ca
    2010 T4R SR5
    is there a map light mod that doesn't require and soldering?
  20. Jan 24, 2016 at 11:07 AM
    #480
    billybob50
    Bob
