2nd Gen Tips, Mods & More
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tcBob, Mar 26, 2008.
  1. Feb 28, 2018 at 3:11 PM
    #781
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    want to go full spring under kit
    I don’t know really what to do because I have a one peace drive shaft and the slip yoke goes into tail shaft of the transmission . do you recall what you did on this truck in the photos.
    Or did you guy just limit OEM one peace drive shaft on that truck with limit straps if so how much down travel can you pull with out messing up the drive line
    I would hate to have to make a two peace drive shaft just for spring under kit
    What do you think is best for the 5lug
  2. Feb 28, 2018 at 6:56 PM
    #782
    saviorself
    saviorself Member
    Joey
    2015 Tacoma TRD Sport 4x4
    Stock right now :(
    Safe to say if I don't find that harness or the white box... I'm fuct? Toyota was pretty quick to tell me I didn't have it. I had to check what year it was because I was pretty sure the gd truck was made after 1999 and should most definitely have it. Gonna do this tomorrow...
  3. Feb 28, 2018 at 7:05 PM
    #783
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    I believe so..
    From what I've seen, if its an 05-15 and you have power locks, you should have at least the harness there.
  4. Feb 28, 2018 at 7:21 PM
    #784
    saviorself
    saviorself Member
    Joey
    Stock right now :(
    Sounds good. Will update tomorrow.
    Doogz[QUOTED] likes this.
  5. Feb 28, 2018 at 7:29 PM
    #785
    DuttonCD
    DuttonCD Well-Known Member
    Alabama
    2018 TRD OR CEMENT
  6. Feb 28, 2018 at 8:25 PM
    #786
    crackerz28
    crackerz28 New Member
    James
    2012 Tacoma Pre-Runner
    Ditch Lights, Fog Lights, Roof Rack, Tonneau Cover, Running Boards
    For what it is worth, my truck has been wired for fog lights, cruise control, and a plug and play swap for intermittent windshield wipers. It just came without any of those options. I think if you are in the same boat, you might be in luck.
  7. Mar 15, 2018 at 2:39 PM
    #787
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    idk if this has been shared on TW yet, but I like it so much I have to share:
    https://www.amazon.com/Drop-Stop-Or...21149615&sr=8-1&keywords=shark+tank+drop+stop
    This thing has saved me countless times from food, cell phone, chew can, etc. falling between the seat and center console and ending up under the seat. It is well made and durable, and has a slit sewed in it to fit over the seat belt receptacle, keeping it in place.
    My life is much better since I bought it. Now, when I drop my cell phone or a renegade french fry gets loose, I look down and say "ahh yeah". :yes:
  8. Mar 15, 2018 at 3:37 PM
    #788
    floodedkiwi
    floodedkiwi Well-Known Member
    Ken
    Naw'lins, Louisiana
    2019 GMC AT4
    Dog.
    That is brilliant....:cheers:
    LC7[QUOTED] likes this.
  9. Mar 17, 2018 at 7:33 AM
    #789
    WhiskeyTaco
    WhiskeyTaco Well-Known Member
    Zach
    Denver, CO
    2011 White Tacoma Access Cab TRD Off Road
    Yea I get these for all my vehicles lol. Just remember to clean them
  10. Mar 17, 2018 at 11:03 AM
    #790
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    We call 'em French fry stops. And they get just as nasty as you'd expect but are machine washable.
  11. Mar 19, 2018 at 7:12 PM
    #791
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    Any negatives with this? Anyone?
    thanks
    Tamytacoma likes this.
  12. Mar 20, 2018 at 3:59 PM
    #792
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Other than having to drop the rear end for install.....none really
    hammertaco11 and LC7 like this.
  13. Mar 21, 2018 at 12:07 AM
    #793
    bagleboy
    Scott
    Norcal, Santa Rosa
    It just catches all the stuff that would ordinarily fall in that crack. It's easier to pull the stop and toss it in the wash than get a vacuum in there. It's a foam filled sleeve w/ a slot for the seat belt.
    doityerself[QUOTED] likes this.
  14. Mar 21, 2018 at 8:33 AM
    #794
    doityerself
    The Deep South
    2006 SR5 DCLB 4x4
    Wow! Sounds like a complicated mod! Too much for me. LOL!
  15. Mar 25, 2018 at 2:59 PM
    #795
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    @10xBuilder thia thread will be very helpful. Look at the 1st post for links to the good stuff.
  16. Mar 25, 2018 at 8:32 PM
    #796
    Kingaa
    Kingaa Well-Known Member
    2015 TRD sport DCSB MGM
    Thanks for making this thread. Pretty sweet!!
  17. Apr 10, 2018 at 8:10 AM
    #797
    tcBob
    tcBob [OP] Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  18. Apr 27, 2018 at 7:25 AM
    #798
    DraculaS2k
    DraculaS2k Active Member
    2011 ac trd off road
    4.88s, air lockers, 3" ,33s mt, snorkel,
    2011 off road here...Is there a rear locker anytime mod like the 1gens (gray wire mod) for our models??? :notsure:
  19. May 28, 2018 at 5:09 PM
    #799
    Tennessee YODA
    Tennessee YODA Damn pigeons
    Knoxville tn
    2008 red tacoma pre runner
    Bull bar nilight light and light bar grill vision rims replacement grill aftermarket headlights
  20. May 30, 2018 at 5:38 PM
    #800
    Plain Jane Taco
    USA
    Here's a little something I came up with a while back. For those who hate the initial splatter that sometimes happens when you pull the oil drain plug. Oil on the floor and in your face....not good.
    My $4 fix. Works like a charm. Zero splatter. Wipe it out and use it again. Been doing this for more than a couple of years.
    Cut the bottom out....you're done.
    IMG_7188_zpslych13ni_8e4da76621b452bf6086319051721146ef2fb7b9.jpg IMG_7187_zpsprist7an_7dcea90138e56f18a29142d195c44f9c4f741bdd.jpg IMG_7189_zps7kifoguz_c76efbd2f6a183cb442cbb7b9bbb083b017151d5.jpg IMG_7190_zps3yeqqtce_65856b596c42b466fcf0046bf74e29b67f9417e3.jpg IMG_7191_zpsvmzkrcnl_b87ea426a19503a1215bec85baaff1a29dbe0b99.jpg
    Turbulent28, wmg, Atlas86 and 11 others like this.
