2nd gen turbocharged
Discussion in 'Performance and Tuning' started by nitro1021, Jun 6, 2015.
  1. Jun 6, 2015 at 12:28 PM
    nitro1021
    nitro1021 [OP] Never Ends
    Eric
    PITTSBURGH
    06 Taco TRD Sport 6 spd
    bilstiens 5100 urd shifter ome dakar leafs
    I have been tossing around the idea of turbocharging my truck . I have a 06 TRD sport with a 6 speed. Now I don't have deep pockets for this build I have a shop with enough tools to make this happen . I have no plan set in stone , but it's gonna be pieced together , junk yard parts, rebuilt turbo from a popular vechile etc .
    Any thought , Ideas and advice will be heard. Thank you
  2. Jun 6, 2015 at 12:57 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    My advice? Don't. The first half of your third sentence should tell you all you need to know. Even with a high budget people have lots of trial and error trying to do exactly what you're trying to do so what makes you think you can do it cheap using used parts and crap and come out with a Picasso on the other side? Believe it or not the supercharger option is the cheapest and you're still looking at north of $5k. To do a turbo right (read: not have a Tacoma perpetually broke down in your garage for the next three years) you'll need more money than that plus fabrication & tuning skills or your budget will need to be substantially higher.
    In closing: Don't.
    I doubt you'll get too much response to your query other than that as most who know what it takes won't even take the time to post.
  3. Jun 7, 2015 at 6:04 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Redlanturn is running a turbo on stock internals (upgraded fuel system obviously) and he has a build page u should check out if ur serious (also check out torspd build page but dont expect those kinda results on a budget) anyway redlanturn is in Hawaii and had a crap load of s&h fees and i still think he only has around 6k in his system and has way more potential for growth for way less than a sc set up (like getting more power after purchase) i think he's puttin like 330 hp to the wheel with a 46mm turbo. I wouldnt go in thinkin u can do it for less than a sc, but u shiuld be able to do it for close to the same. Ive window shopped all the components for a system and its gonna be really close to 3k plus all ur fab work.
    https://www.tacomaworld.com/threads/redlanterns-brokanic-build.262425/
    Lord Helmet and Torspd like this.
  4. Jun 8, 2015 at 6:19 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well said. :thumbsup: Depending on the resources available to you, such as fabricating the kit yourself, quality used turbo, possibility of purchasing materials at wholesale, you might be able to knock off some decent cost. Might.
    If you wanted to truly be frugal, you could also run the TRD s/c injectors and TRD reflash. Which will save you a lot over an aftermarket EMS.
    All depends on how resourceful you are will to be.
    Lord Helmet likes this.
  5. Jun 8, 2017 at 5:37 AM
    First Choice
    First Choice New Member
    Royce
    08 Toyota Tacoma
    I see this was posted a year ago... does the opinion of don't turbo the 1gr-fe still stand? And has anyone used underdog racing development for upgrades? I'm haveing a hard time finding forged parts for my engine. Well tested internal parts for my engine to be exact. I just moved to California and was told there is a company that makes larger gas tanks for tacos with perfect fit ,but I can't remember the name. Any help will be help thank you.
  6. Jun 8, 2017 at 6:27 AM
    yota243
    E.J.
    north Alabama
    I got my injectors and fuel pump and mapecu3 from urdusa.com and in the mapecu3 if u buy 2 or more u save $200 per unit. I started a groupbuy thread on them and me and 2 other members went in on it together. There were others interested but just werent quite ready at the time so when it comes time for you, you could get with them and save some cash
    First Choice[QUOTED] likes this.
  7. Jun 8, 2017 at 7:28 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    A handful of companies make forged internals for the 1GR.
    www.lceperformance.com
    http://www.molnartechnologies.com/rods-sc-toyota.html
    http://www.briancrower.com
    http://pauter.com/parts/rods/
    www.cp-carrillo.com
    www.wiseco.com
    LCE, is the vendor and an engine builder.
    Also check out the turbo BS thread.
    First Choice[QUOTED] and yota243 like this.
