2nd Generation Tacoma suspension
Discussion in 'Suspension' started by rab89, Jun 27, 2012.
  1. Jun 27, 2012 at 6:56 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I wrote this up the other day, and figured I'd publish it today.
    I've done extensive research on the suspension of the Tacoma, and plan to do more, but here is what I have...
    2nd generation Toyota Tacoma Suspension
    The Tacoma uses coilover shocks, with progressive coils to support the front of the vehicle. There is 4’’ of up travel, and 4’’ of down travel when stock, when the suspension articulates and reaches full “droop” on down travel, it is stopped by a ball joint, and when the suspension articulates all the way up, there is a bump stop on the lower control arm that will hit the frame and stop the suspension.
    There are a few basic lift kits I want to go over, first we have an in coil spacer. This is often a piece of polyurethane that is placed between the coil and the “hat” of the coilover, compressing the coil, making the assembly longer to achieve lift.
    This type of lift kit is cheap to buy, but requires a coil compressor for install, which is usually a job to bring to a mechanic.
    Unfortunately when you add a spacer like that inside the coil of a progressive spring, it has a large effect on ride comfort, this would be the least comfortable way of lifting your Tacoma.
    The next lift is an above coil spacer, this is usually a piece of steel or aluminum that is bolted to the top of the coil over assembly, which is then bolted into the stock mounting location. This is also easy on the wallet.
    This lift can be installed in your home garage with basic tools, and ride comfort won’t suffer, as the coilover hasn’t been changed, just moved down.
    The problem you may encounter with this lift, is that the suspension articulation is now changed, where we had 4’’of up travel and 4’’ of down travel at stock, it is now moved a few inches depending on the size of the spacer, common spacers are around 3’’, when you add the inches to the top, it means you will now have 7 inches from where the lower control arm sits, to where it will hit the bump stop, the problem is that the shock itself isn’t long enough, and will bottom out before the bump stop touches the frame, resulting in shock failure over time.
    This lift is great if you simply drive on the road and dirt roads to camping spots etc, but is not a great option for more hardcore wheeling.
    The next option is new coilovers, you can buy parts to assemble your own which is quite common, or you can buy the entire assembly.
    To build your own coilovers, you will need a set of Bilstein 5100 series ride height adjustable shocks, paired with longer, non-progressive coil springs.
    Bilstein 5100 series shocks are adjustable, there are clips on the bottom part of the shock, with these you can set the clip to stock height, .85’’ of lift, 1.75’’ of lift, and 2.5’’ of lift, if these are used with the stock coils, it works the exact same as an in coil spacer, which remember, will have a negative effect on ride quality.
    Now to fix this issue, we use a longer, non-progressive coil spring with the Bilstein 5100 shocks.
    Longer non-progressive coil springs.
    These coils are longer than the stock coils, for instance the Eibach coils alone provide 1.6’’ of lift. These are also non-progressive coils, meaning if they are compressed using the adjustability of the Bilstein shocks, ride quality won’t suffer like it would with stock coils.
    Often, the Bilstein adjustable shock will be set at .85’’ of lift, with 1.6’’ lift Eibach coils, this will net you roughly 2.5’’ of lift. If you would like slightly more lift, you can buy a very small top plate spacer, MUCH smaller than the ones used as a lift kit.
    These will be in the ¼’’ to ½’’ range.
    Commonly the Tacoma has a slight lean to the left, as that is where the battery, driver, and gas tank are located. To compensate, you can use a smaller spacer on the pass side than the driver’s side. If you are happy with the 2.5’’ of lift you have, then you can add a small spacer to the drivers side to level the truck.
    Tip: Old Man Emu (OME) is also a great option for lifting the truck, they have different coil springs for different applications, that are made to work with their shocks. Some people prefer the Old Man Emu lift over bilstein/eibach lift, and vice versa, both lifts would fit into the same category.
    These are a better option than the in coil spacer and top spacer, because you won’t lose suspension travel, and you won’t risk damaging a shock due to bottoming out.
    Next is pre assembled coil overs. These are the best option in lifting a Tacoma, and gaining suspension performance, they can be adjusted with a “spanner wrench” while on the truck. These use very high end shocks and coils, and can be adjusted much more precisely than the Bilstein 5100 shocks, that means you can set the drivers side to compensate for the Tacoma lean, and you can set the lift height wherever you want. These coilovers will outperform the other options because they often use a larger shock body, and even a remote reservoir, this helps keep the oil inside the shock cool, and performing it’s best when being used hard.
    These coilovers can also be valved to your specific needs, based on intended use and desired ride performance. These are the best, and of course the most expensive way of lifting your Tacoma.
    Rear lift options
    Lifting the rear of the Tacoma is fairly simple.
    You can use a lift block, which is a small block, usually between 1’’ and 2.5’’ placed between the bottom of the leaf pack and the on top of the axle. With a block, your ride quality will be as stock, however there is more leverage allowing more “axle wrap” than stock, which will slightly decrease the longevity of your leaf springs.
    Next is an Add A Leaf (AAL) this is either a single leaf, or a progressive 3-leaf pack, placed between the overload leaf, and the rest of the leaf pack, these are usually 1.5’’-2’’. These will help keep a healthy bend in your leaf springs, and allow you to carry weight in the bed of the truck, with less sagging than stock.
    A single AAL will have a slightly negative effect on ride quality when the truck bed is unloaded, the progressive 3 leaf pack will still be a stiffer ride than stock, but smoother than the single leaf AAL.
    Tip: If your leaf springs are older and starting to sag, an AAL is a great option to bring them back to life for a bit.
    A new leaf pack is a great way to lift the rear of the Tacoma, there are options for a more comfortable ride that will flex more, but sag more with weight, or a similar leaf pack to stock that achieves desired lift, while keeping your weight carrying abilities. Some of these leaf packs will have an overload leaf, and some will not, and some will have more leafs in the pack than others, you’ll need to decide what you intend to do with the truck, to decide on the best application for you.
    Tip: If you would like you truck to sit level while lifting the front 3’’, use a 1.5’’ rear lift.
    A common lift kit for the Tacoma is Bilstein 5100 series shocks set at .85’’ setting, matched with Eibach coil springs to achieve 2.5’’ lift, add ½’’ top spacer on drivers side, and ¼’’ top spacer on pass side to achieve roughly 3’’ lift and sit level. (Also look at OME for a similar set up)
    An AAL or block to achieve 1-2’’ lift in the rear, paired also with bilstein shocks (rear are not adjustable)
    That is a budget friendly lift kit worth spending your money on.
    I hope this guide has helped you understand the mechanics of the Tacoma suspension, as well as decide what lift kit is best suited for your application.
    All lift numbers provided are average.
    If you are installing a suspension lift yourself, I have used this method in the past, and it worked extremely well, and I felt safe doing it.
    However, I will not be held liable for any injuries that may occur during install, I am simply showing you what I have done in the past.
    http://www.youtube.com/watch?v=vkVLBOnAifc&feature=player_embedded
    Tacodouche likes this.
  2. Jun 28, 2012 at 10:40 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    Check your link. I get webpage not found.
  3. Jun 28, 2012 at 11:39 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    there, posted.
  4. Jun 30, 2012 at 2:52 PM
    g34rh34d
    g34rh34d Well-Known Member
    Colorado
    '08 4 DR TRD Off Road - ICON Stg 1 Adjustable Coil Overs ~3" lift, UCWMS, Airbags
    UCWMS; ICON Stg 1 Adjustable Coil Overs ~3" lift/shocks; Diff drop Spacers; Light Racing UCAs, Firestone Airbags
    Great writeup... I have been considering the various options, and this really helps! Thanks for the info!
  5. Jun 30, 2012 at 8:02 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    No problem man!
  6. Jul 2, 2012 at 7:27 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Thanks, Ross, for takin' the time to put a bunch of useful info in one place :thumbsup:
    CC
  7. Jul 3, 2012 at 1:28 PM
    pgiroua
    pgiroua Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    So ALL Tacoma models come with progressive coil springs? No difference between SR5, TRD and TRD Offroad?
  8. Jul 3, 2012 at 1:28 PM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    sub'd
  9. Jul 3, 2012 at 1:40 PM
    tmreyes1
    tmreyes1 Well-Known Member
    T-Rey
    TX
    2017 TRD
    What is the lift and drop after the 5100's and Eibach coils?
  10. Jul 3, 2012 at 5:38 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I've heard that SR5 and base model coils are non progressive, but I haven't confirmed it myself.
  11. Jul 3, 2012 at 5:40 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    eibach coils alone give 1.6'' of lift, you can then compress them a bit to gain desired lift, most common is to set the 5100's to .85 with the eibachs. that gives approx 2.5'' lift up front, if you want more, your best bet is to add a small top plate spacer.
  12. Jul 3, 2012 at 6:06 PM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    Progressive would be better than normal right?
  13. Jul 3, 2012 at 8:00 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    not if you plan on compressing them to achieve lift. At stock height, or with a top plate spacer they will perform better.
  14. Jul 3, 2012 at 8:04 PM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    I will be running Bilstein 5100's at 0.85 and I am trying to decide if I should replace my stock SR5 coils (100,000 miles). I was thinking of trying to find some TRD off road coils to replace them with. Any suggestions?
    I will also be running spindles...
  15. Jul 3, 2012 at 9:43 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I would be buying eibach coils. your stock coils are too old to be compressed now, they will sag and won't ride very nice. Eibach's are also only $170.00. pretty cheap I think.
  16. Jul 3, 2012 at 9:57 PM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    Well the only problem is I don't want to sit that high in the front (with the spindles)...
  17. Jul 3, 2012 at 10:02 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    how high do you want it to be? OME has some different coil options for different ride heights. I don't know what they are though so you'll have to do some searching.
  18. Jul 3, 2012 at 10:21 PM
    buddyfixit
    buddyfixit Well-Known Member
    Jon
    DFW Texas
    2012 4x4 SR5 Avid Lightbar "super taco"
    TRD air filter, Predator Step Bars, WeatherTech Floor Liners, Avidoffroad Lightbar, B.A.M.F. lightbar, Rearview Mirror Bracket, Console Organizer, CH Holster in dash, More to come...
    I am trying to improve my Highway feel. I have a 2012 sr5 4x4 that I am thinking about putting the bilstien 5100 shocks on front and 5150s on rear. I will be doing minor offroading. I dont want to lift the truck per say as much as get a better ride out of it. Dallas fort worth texas roads are horrible. whether it be highways or side streets or just around town the potholes and surfaces are beat to hell. The truck looks level to me and at most I think I would set the fronts to .85 So my question really is.... Do I need to do anything with my stock coilovers? I have access to a wallmounted coilspring compressor and full body shop so installation is easy. Just dont want to mess around with all this unless my current ideas will accomplish a SMOOTHER ride. What do you think. Thanks for any input in advance.
  19. Jul 4, 2012 at 4:27 AM
    pgiroua
    Royce
    Cypress, TX
    07 PreRunner SR5
    Just looking to be around 5" so that the back can be level with the standard All Pro leaf pack. The spindles and Bilsteins set at 0.85 would get me where I need to be. I will do a little more research. I do appreciate your help!
  20. Jul 4, 2012 at 12:09 PM
    oaker
    oaker Active Member
    '11 Tacoma DCSB TRD
    well i was gonna go with the 5100s but after reading that im considering just going with an above coil spacer since i just want lift and dont do any off roadin.
