2TR Denso Spark Plug Question
Discussion in '4 Cylinder' started by Bowers86, Jul 8, 2016.
  1. Jul 8, 2016 at 5:46 PM
    Bowers86
    Bowers86 [OP] Well-Known Member
    Vancouver, WA
    2013 RC 2WD 5-speed
    Access Cab Buckets, OE backup cam, AFE Air Filter/Secondary filter removed/Fender Elbow removed, Magnaflow 11225, XII springs/4x4 leafs/XR Bilsteins, Prodigy P3 brake controller, 3.73 Third, Undercover Tonneau, Koomus CD slot iPhone mount, Paint matched rear bumper, Drag 18x9 et20 wheels, 3rd Gen Airdam.
    I recently changed the spark plugs on my 2TR and after doing so ran into a slight difference of part number. The Denso plugs (I am assuming they are OE still as I only have 60k on the odo and the threads were getting a little corroded) I removed had a part number SK20HR-A11 (3493), the ones I installed were SK20HR11 (3421). I didnt notice the change until well after I had installed the plugs. Truck runs fine so I assume they are okay, but wondering if anyone could tell me the difference between the two.
  2. Jul 9, 2016 at 12:23 PM
    TRDCal
    TRDCal Well-Known Member
    Canada
    2018 DCSB Sport MT
    ilovich likes this.
  3. Jul 9, 2016 at 12:51 PM
    ilovich
    ilovich Well-Known Member
    Daniel
    Los Angeles
    2011 MGM Reg Cab 5-Speed 4x4
    Leaves in the bed
  4. Jul 9, 2016 at 7:55 PM
    Bowers86
    Vancouver, WA
    2013 RC 2WD 5-speed
    Thanks for posting those links back to back. Yeah definitely the same, just weird that it appears both are still being manufactured under their respective PN#s. Still going good so I guess I'll report back only if something goes horribly wrong, lol.
  5. Jul 25, 2016 at 8:42 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    One of them is a high life plug the other a thinner electrode for a faster spark. The difference is negligible I've ran both. The only thing is the plug with the thin electrode does wear out faster about 60k vs 80-100k.
