2TR-FE MAF Sensor & Throttle Body Cleaning
Discussion in '4 Cylinder' started by 05Taco4x4, Feb 10, 2013.
After cleaning, do you notice any different engine behavior on a cold start?
  1. NO
    36 vote(s)
    42.9%
  2. Yes, I see a rise in initial RPM
    18 vote(s)
    21.4%
  3. Yes, I see a fall in initial RPM
    6 vote(s)
    7.1%
  4. Yes, I see erratic RPM behavior
    1 vote(s)
    1.2%
  5. Yes, No, What? I was hoping to seee bewbs
    23 vote(s)
    27.4%
  1. Apr 12, 2015 at 8:47 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I lost maybe an ounce of coolant when disconnecting the coolant lines from the throttle body. The throttle body is located high up compared to the rest of the cooling system, and if this service is done cold there will be no pressure in the system... in fact I think there would be a very mild vacuum since the system is designed to draw in whatever is needed from the overflow bottle as it cools down.
    Greenbean likes this.
  2. May 3, 2015 at 11:58 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    So do you spray a lover the sensor? Inside it and everything?
  3. Nov 12, 2015 at 5:55 AM
    Wolverinesam
    Wolverinesam Well-Known Member
    New York State
    2013 Tacoma Prerunner 2.7L
    Sorry to wake up the thread. I removed my MAF sensor for cleaning today, and it doesn't look anything like the pictures I've seen on TW. Here is what it looks like.
    Do I spray the MAF cleaner on the metal surface only, on the wires inside only, both? Looks pretty darn clean for 43k miles.
    Thanks for any help!!
    D0m1n1ck likes this.
  4. Nov 14, 2015 at 6:34 PM
    Wolverinesam
    New York State
  5. Nov 18, 2015 at 7:07 PM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  6. Nov 19, 2015 at 1:16 PM
    Wolverinesam
    New York State
    Domo origato Chad-San.
    05Taco4x4[QUOTED][OP] likes this.
  7. Apr 29, 2016 at 11:11 AM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Just like mine.
    Spray the body and all ports in the airflow. I use Electrical Cleaner works well and can be sprayed in the internals with no problem at all.
  8. May 2, 2016 at 7:20 AM
    Wolverinesam
    New York State
    Thanks! Just returned from vacation and am catching up. Appreciate your input.
    2.7taco[QUOTED] likes this.
  9. May 4, 2016 at 5:44 AM
    2.7taco
    Texas
    Not a problem. I like quick drying cleaners.
  10. Jul 10, 2017 at 10:03 AM
    saratogajoe
    saratogajoe Well-Known Member
    I have never cleaned the MAF on any toyota that I have ever owned, however I do run a bottle of castle fire ball plus fuel system cleaner every oil change. I love this stuff and really swear by it.
  11. Jul 10, 2017 at 4:28 PM
    2.7taco
    Texas
    Honestly if you call an injector shop they will tell you your not doing much with the additives you dump in the tank.
    The MAF and throttle body cleaning is something to do once every year or 2 depending on drive cycle and how you drive. I had to replace mine due to crud getting in the element and not being able to blow it out.
  12. Aug 20, 2017 at 2:47 PM
    sabre19
    sabre19 Member
    Phoenix, AZ
    2011 i4 Auto SR5 4x4
    GROM-USB2 w/ iPod and BT interface, OEM hitch and trailer harness, OEM tube steps, AFE Pro Dry S
    If anyone is interested, the part number for the non-reusable TB gasket is 222710C021. I didn't see it posted anywhere.
    nettto, Greenbean and Moana Nui like this.
  13. Jun 26, 2018 at 5:45 PM
    05Taco4x4
    2TR-FE Enthusiast
    MAFs have their own cleaner for a reason, please do not substitute other cleaners.
  14. Jul 6, 2018 at 8:46 AM
    dawgn86
    dawgn86 Well-Known Member
    2013 Toyota Tacoma
    After cleaning the TB on the 2.7, do you have to have the computer relearn the idle air volumes like on the Nissan 4.0?
  15. Jul 6, 2018 at 9:34 AM
    #35
    05Taco4x4
    2TR-FE Enthusiast
    IDK about the TB, I would expect some sort of learning after the MAF cleaning
  16. Apr 22, 2019 at 9:40 AM
    #36
    pv2smurf
    pv2smurf Member
    Sorry to revive thread, but can't find information on this either. Any help on Throttle Relearn to idle for this engine would be EXTREMELY GRATEFUL!5
  17. May 9, 2019 at 8:18 AM
    #37
    pv2smurf
    pv2smurf Member
    After doing the above on my 2009 2.7L (2tr-fe) as well as a new cylinder head and cylinder head gasket I have some updates.
    I just called the local dealership and talked to my buddy who is the trained one for the Tacoma's and tundra's. He said when I reconnect the battery (bc it's been d/c for about 72hrs) to hold my foot on the floor with a WIDE OPEN THROTTLE before I turn thr key on. Did that and held it for 10 seconds. Turned truck off and repeated 3 or 4 times. Then I checked it with a Autel scan tool to verify the wide open throttle was relearned.
    He told me the truck after a dead battery (which resets the ECM) takes about 30miles of driving to adjust to thr crappy sensors the system has. After about 80 miles it seems to idle MUCH BETTER and doesn't quit at a red light like it did 2 times within the first 10 miles.
    Hope this information helps someone else in the same situation as me
  18. May 9, 2019 at 10:18 AM
    #38
    05Taco4x4
    2TR-FE Enthusiast
    Good info, thanks :thumbsup:
  19. May 13, 2019 at 9:40 AM
    #39
    DGXR
    Friend
    Sacramento, CA
    Thanks you! I don't suppose your buddy said if this "WOT before ignition on" procedure works with all 2nd gen 2.7s, or just your 2009... or 2009 and forward model years?
  20. Jan 9, 2020 at 8:48 AM
    #40
    dawgn86
    2013 Toyota Tacoma
    Great writeup! I cleaned my TB this weekend and it seems to idle smoother now right at 750 rpm's.
    05Taco4x4[OP] likes this.
