2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Jun 4, 2020 at 7:25 AM
    #181
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    That's probably more clutch related. I lost that lag when I put mine in, now that's gotten some miles on it, it's back but not near as badly.
    Hell, it may even be the ECU not wanting to get off the couch and do something productive.
    I gotta figure out what I'm doing wrong, or the truck, because more often than not, I'm crunching that shift to 2nd. Prevalent on "cold" starts, but more or less nonexistent after about 15 minutes of driving. Weird!
  2. Jun 4, 2020 at 7:29 AM
    #182
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    I always thought this was caused by first and second gearing being too far apart. I have to ring it out in 1st so it isnt a turd right when i get into 2nd.
  3. Jun 4, 2020 at 7:49 AM
    #183
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I doubt it. 2nd gear ratio in the R154 is 1.955:1 which is taller than the R155 (2.06:1). If anything, I'd expect it to be worse. It's likely that the problem isn't that the gap is too big, just that 2nd is too high. Instead of making 1st closer to 2nd, you should make 2nd closer to 1st.
    It'd be interesting to know if you could swap the 2nd gear from the R151 or the R156 into the R155. That would help.
  4. Jun 4, 2020 at 8:37 AM
    #184
    dirty deeds
    Nick
    Eastern KY
    This is also a thing too. I forgot about that.
  5. Jun 6, 2020 at 1:53 PM
    #185
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I've made some progress on the billet cover, will be slow on this one.
    You can't just swap the single gear, would need to swap a shaft too (you'd be a hero and well paid if you make a custom shaft to swap in the the R155/6). I've asked PGS many times if their R154 gearsets will work in the R155 but never received an answer.
    Torspd and BassAckwards[OP] like this.
  6. Jun 7, 2020 at 12:26 PM
    #186
    jowybyo
    Joe
    Baltimore, MD
    Aren’t you the hero that created the custom cv shaft to make 2nd gen manual hubs work? I was counting on you to figure this out.
  7. Jun 7, 2020 at 3:33 PM
    #187
    05Taco4x4
    2TR-FE Enthusiast
    Something like that haha
  8. Jun 7, 2020 at 3:36 PM
    #188
    05Taco4x4
    2TR-FE Enthusiast
    I didn't catch this first time through, this is hearsay from trusted source or seen yourself?
  9. Jun 7, 2020 at 3:51 PM
    #189
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @MadTaco461 , which transmission did you install in yours? 2rz, but still.
  10. Jun 7, 2020 at 10:44 PM
    #190
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    I have a r155 bolted to a 2rz.
    Torspd[QUOTED] likes this.
  11. Jun 8, 2020 at 6:31 AM
    #191
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did you ever come across anything R154, during that research?
  12. Jun 8, 2020 at 9:29 AM
    #192
    MadTaco461
    CA
    Kinda stock
    It's pretty much the same thing, just a different gear ratio. When I searched rebuild kits they are compatible with the whole r series family. I figured if the bearings are the same size they are all the same strength. This was just an assumption I came up since I never touched a r154.
  13. Jun 8, 2020 at 10:04 AM
    #193
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    Staria's Transmissions who builds all my friend's powerglides told me any R is interchangeable, as well as Weapons Grade Performance in CT had a few R's and showed me the bellhousings and gears. Haven't made a trip to WGP since Doug passed away though. If I get back there I'll get some pictures.
    05Taco4x4[QUOTED] likes this.
  14. Jun 8, 2020 at 12:51 PM
    #194
    05Taco4x4
    2TR-FE Enthusiast
    Right on, that'd satisfy curiosities. Now I have a problem, I was head first into an auto swap but swapping in a better gearset might do the trick. But that clutch though :frusty:
  15. Jun 8, 2020 at 12:52 PM
    #195
    05Taco4x4
    2TR-FE Enthusiast
    these guys
    MadTaco461 likes this.
  16. Jun 8, 2020 at 1:08 PM
    #196
    BassAckwards
    Does anyone in here know if a 13-15 2TR-FE will work in an 05-12? I know the wiring harness changed in the cab, but i wasnt sure about the engine harness. Trying to track down a good used motor and there are tons of 2013s for cheap, but i wasn't sure it would work in my 2009
    Ginger-Vitis likes this.
  17. Jun 8, 2020 at 1:30 PM
    #197
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do all the year models have that exhaust recirc? Whatever that is?
    BassAckwards[OP] likes this.
  18. Jun 8, 2020 at 1:40 PM
    #198
    BassAckwards
    Yes all models of the 2TR have the secondary air injection if that's what you're referring to..
  19. Jun 8, 2020 at 2:28 PM
    #199
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Then boom. It'd be no different that swapping in a 2012 + 1GR into a pre 2012. Swap over any different external parts.
  20. Jun 8, 2020 at 2:29 PM
    #200
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    As long as they are all single vvti
