2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Jun 8, 2020 at 3:08 PM
    #201
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    That is why I jumped to an R series. I could just give it the HD treatment if I blow this one up.
  2. Jun 8, 2020 at 4:54 PM
    #202
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    Awesome thanks for the help!
    Yes sir, they are so sounds like I'm good to go
  3. Jun 8, 2020 at 5:19 PM
    #203
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I always thought the earlier 2nd gen 2.7 didn't have the secondary air injection, like the v6, but was added later down the road?
  4. Jun 8, 2020 at 5:25 PM
    #204
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Nope. The 2TR had it the whole time. My 08 has the SAIS.
    Ginger-Vitis and Torspd like this.
  5. Jun 10, 2020 at 5:58 AM
    #205
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Uhmm, let's see a manifold! I am still lacking that crucial part!!
  6. Jun 10, 2020 at 6:26 AM
    #206
    OVTune
    OVTune Well-Known Member
    OVTune
    2016 Tacoma 2.7L AT Engine, Transmission, Torque Converter Tuning with vF Tuner is now available as beta support
  7. Jun 10, 2020 at 6:32 AM
    #207
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :woot:
  8. Jun 10, 2020 at 6:33 AM
    #208
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Need a truck in the garage first.
    BassAckwards[OP] likes this.
  9. Jun 10, 2020 at 6:41 AM
    #209
    BassAckwards
    I pulled the trigger on a used motor with 54k yesterday. I can send you an OEM manifold if that would help at all with this, although i know you'd probably need the truck for fitment. Figured i'd throw it out there either way!
    MrCrowntown and whatstcp like this.
  10. Jun 10, 2020 at 6:49 AM
    #210
    dirty deeds
    Nick
    Eastern KY
    Speaking of 35s...I'll be in that club shortly, I think. Hopefully what I've got done already will be enough.
  11. Jun 10, 2020 at 6:56 AM
    #211
    BassAckwards
    Have you regeared already?
  12. Jun 10, 2020 at 6:59 AM
    #212
    dirty deeds
    Nick
    Eastern KY
    Yup, 4.88. Better than stock clutch. Header. Snorkel coming soon.
    Need a CMC and all the other cutting and beating.
    Brakes are my other concern. And wheel fitment, I've got spacers and 3 different wheels to try though.
  13. Jun 10, 2020 at 7:14 AM
    #213
    DevilTaco4
    DevilTaco4 Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    I’m MT.
  14. Jun 10, 2020 at 7:15 AM
    #214
    BassAckwards
    I think you'll be good to go since you've got the 5spd.
  15. Jun 10, 2020 at 7:17 AM
    #215
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    IMO, doubt it. I wouldn’t even touch 285/75/17 with 4.88, but all depends on what’s considered acceptable performance. You wouldn’t even be back to stock (if you run the RPM numbers on Grim Jeeper with R156f tranny) and IMO even the 5spd is undergeared from factory with 3.91 with my 245s I have on now while I make up my mind. Heavy truck for 160hp
    personally I’d want to take as much stress off the 2.7 as possible, but again, to each his own and I understand not wanting to turn 3k at ~73mph (5.29 + 315s)
    around town all good, but every time I head up to the mountains or actually off-road Is where you’ll wish you had more gear. 2nd/3rd gen guys need to realize it’s not the same as light 1st gen guys with same motor
  16. Jun 10, 2020 at 7:17 AM
    #216
    dirty deeds
    Nick
    Eastern KY
    I feel it'll be closer to stock-ish performance, certainly want to be able to get out of my own way. The other 4 cyl folks I know have now gone above 35s but with 5.29 gears
  17. Jun 10, 2020 at 7:29 AM
    #217
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Alright! That would be a great help. Can get some flanges made. Would ultimately need a truck though, to make a jig.
  18. Jun 10, 2020 at 8:37 AM
    #218
    BassAckwards
    Yeah i guess acceptable performance is all relative. But ive run 4.88s in my 2nd gen 5spd with 66lb 295/70/17s and im sure the 4.88s will be sufficient to turn 35s as they're not much heavier. I agree, 5.29s would probably be the way to go if you stay n/a. That being said my truck w/ 5.29s turns 3400rpms at 75mph and 33s, so im not sure youd really want anything less than a 34 with 5.29s.
    4.88s will be fine, just dont get in any hurry
    I think 4.88s will be a nice compromise of gear and less revs on the hwy. Regearing is a big game of give and take unfortunately. When's someone gonna come out with a quick change rear end for our trucks? :D
    Sure thing man, i will try to find a box that i can send it in. I figured that'd be the case. Maybe here in a few months i can drive down and you can use my truck to make a jig.
    dirty deeds[QUOTED] likes this.
  19. Jun 10, 2020 at 8:45 AM
    #219
    dirty deeds
    Nick
    Eastern KY
    Quick change?! LOL!
    It doesn't take long at all to swap 3rds
  20. Jun 10, 2020 at 8:55 AM
    #220
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Could just add a "crawl box" but with taller gears. Instead of having a typical 5:1 ratio in the crawl box, you could put in 1:1.1
    I think it might be hard to shift it on the fly though.
