2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Jun 10, 2020 at 9:00 AM
    #221
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    It's such a pita though having to get the gears set up though. Maybe i should just get a 3rd w/ some 4.88s to swap in for long trips. After going s/c i kind of regret doing 5.29s
    I like where your head's at, but it might be difficult to get that setup to work on my prerunner. I have considered a halfway 4wd swap without the front diff/cvs/etc so i could get 2 low, but at that point, it would be stupid not to make it 4wd since the trans has to be replaced
    dirty deeds[QUOTED] likes this.
  2. Jun 10, 2020 at 9:02 AM
    #222
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Yeah, gearing setups do take time. I was meaning exclusively swapping the whole 3rd.
  3. Jun 10, 2020 at 9:05 AM
    #223
    BassAckwards
    ahhh sorry, yeah swapping the 3rds arent too bad, just time consuming cleaning up all that RTV lol
  4. Jun 10, 2020 at 9:38 AM
    #224
    DevilTaco4
    DevilTaco4 Well-Known Member
    Folsom, CA
    2017 SR Access 5MT
    weight has little to do with performance. It’s tire diameter that lowers you’re effective gearing, i.e - turning 295s (true 33) is not the same as turning 315s With the same gearing regardless of weight. I have stock size Toyo MT 245s on right now far heavier than stock P rated tires and it feels identical.
    as for your rpm - well yes, you’re in a predicament there and that’s why I was as well. 4.88 isn’t enough for 315s IMO, and I didn’t want to run 3k+ at 75mph. Joys of a 2.7 lol.
  5. Jun 10, 2020 at 9:59 AM
    #225
    BassAckwards
    agree to disagree :thumbsup:
    imo unsprung weight is the worst kind of weight you can add to these trucks. Doesnt matter what gears you have, you're going to feel the performance loss of a heavier tire not only in acceleration but braking as well
  6. Jun 10, 2020 at 11:21 AM
    #226
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    Definitely agree to disagree!
    If your logic was sound why would anyone regear when jumping to a bigger tire if you can find a wheel/tire setup lighter than stock? You’d still feel the loss of gearing 1000000%. Everyone likes to parrot that bullshit without actually seeing the difference first hand. I mean, who actually gets a 245 MT? Besides me lol.
    my setups:
    stock tires + stock gearing
    STT pro 285s + stock gearing
    Toyo MT 245+ stock gearing
    285s Is where it got crushed and the setup was hardly heavier than what I have now.
    My MPG and acceleration are same as stock weight tires. By your logic that isn’t possible and the “worst thing I can do.” I have no reason to lie - that’s why I’m sticking with these until I decide if 5.29 + 35s is worth the trouble.
    no worries though!!
  7. Jun 10, 2020 at 12:11 PM
    #227
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What aspect ratios are those tires? All the same aspect ratio, or all different so that the overall tire heights are the same?
  8. Jun 17, 2020 at 9:21 AM
    #228
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    waiting on 2012.....
  9. Jun 17, 2020 at 11:27 AM
    #229
    dirty deeds
    Nick
    Eastern KY
    Far as the gearing, tire size, and weight thing...
    Stock 4.10 gears and stock P245/75/r16 tires, drove like stock, street truck, no lift, no armor. Duh.
    Stock 4.10 gears and LT254/75/r16 Grabber AT2s, a difference in every aspect, not yuuuge, but different negatively. Braking, cornering (probably no sway bar), acceleration, mpg loss. Had 5100/885 and AAL. Struggled on steep climbs in 4lo even, smoked the clutch. Skids and sliders, rear bumper.
    Stock gears still and 255/85/r16 KM2s, replaced my clutch with LCE's. Even more degradation of braking and acceleration. Truck was a bit of a turd and wasn't winning any drag races. Still same suspension, then added Dakar HDs and Fox ext travel IFP in the rear. Added front bumper and winch.
    Upgrade to 4.88s, LCE clutch, header, 255s, 5100/885, Dakar HD, Fox ext travel, all the armor, and I felt as though my truck was enough for anything I could want!
    The LCE header was put on at some point, can't remember before or after gears.
    When I went to 4.88s, all my hopes dreams and wishes came true! What a damn game changer for off road performance! Still a bit much for 5th gear interstate speeds ~75mph, but I wouldn't change a thing.
  10. Jun 17, 2020 at 11:42 AM
    #230
    dirty deeds
    Nick
    Eastern KY
    I've got a real hard time believing that the larger Coopers (notoriously heavier tires vs competitors) are 'hardly heavier' than Toyo 245s.
    I'll assume 285/75/r16 and 245/75/r16 sizes per. And that the Toyo is the Open Country.
    STT Pro ~61#
    Toyo MT ~52#
    10lbs of added or subtracted rotational mass at each corner makes a difference.
    The 35s I'm looking at weigh in around 63lbs vs my 255 KM2s at 55lbs. 8ply 35 vs 10ply 33
    Reh5108 likes this.
  11. Jun 17, 2020 at 11:46 AM
    #231
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    It's not just about weight, but also moment of inertia (how far that weight is from the center of rotation).
  12. Jun 17, 2020 at 12:22 PM
    #232
    dirty deeds
    Nick
    Eastern KY
    That is correct!
    SCIENCE!
  13. Jun 17, 2020 at 12:37 PM
    #233
    BassAckwards
    Did this this past weekend. Truck is a paper weight now. Gotta find a shop to rebuild my old motor. The one the wrecking yard sold me had a damaged timing cover, so I'm going another route now. Any recommendations for a shop in Texas that does rebuilds? I'd love to have LCE build it, but the idea of shipping it all the way to AZ isnt so appealing
    Ginger-Vitis and whatstcp like this.
  14. Jun 17, 2020 at 2:00 PM
    #234
    dirty deeds
    Nick
    Eastern KY
    DO EEEEET!
    You're closer to LCE than I am lol
  15. Jun 17, 2020 at 2:21 PM
    #235
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    Toyos are on stock 30lb steelies
    Coopers were on 21lb Ray10s
    donthe numbers now..
    believe what you want broski
  16. Jun 17, 2020 at 2:27 PM
    #236
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    yeah, diameter lol. As I’ve been saying..
    most people parrot it’s simply weight
    whatstcp likes this.
  17. Jun 17, 2020 at 5:05 PM
    #237
    dirty deeds
    Nick
    Eastern KY
    Devil is in the details man. You left that part out lol
    If the numbers are correct, then it's a wash
    DevilTaco4[QUOTED] likes this.
  18. Jun 17, 2020 at 6:21 PM
    #238
    DevilTaco4
    Folsom, CA
    2017 SR Access 5MT
    Lol, yeah that’s all I was trying to explain man. I don’t by any means think we should ignore unsprung weight, but the killer is diameter - if you’re gearing doesn’t match up it’s going to feel like a pig.
    I mean, look at all the complaints of people saying stock wheels/tires still feels slow lol. Well double OD gears at 3.91 r&p are to blame.
  19. Jun 17, 2020 at 7:01 PM
    #239
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How is the rest of the engine, despite the timing cover? Can you not just swap it over?
  20. Jun 18, 2020 at 5:11 AM
    #240
    dirty deeds
    Nick
    Eastern KY
    I'm guessing 3rd gen 2.7s MT are 3.91? All the 2nd gen 2.7 MT are 4.10.
