2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Oct 29, 2020 at 6:14 AM
    #341
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Oct 29, 2020 at 6:22 AM
    #342
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
  3. Oct 29, 2020 at 6:25 AM
    #343
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    ECU plugs are different between 05-12 and 13-15 trucks
  4. Oct 29, 2020 at 6:28 AM
    #344
    BassAckwards
    It's a good time to be a 2TR owner!! :taco:
    Sscustoms, 05Taco4x4 and dirty deeds like this.
  5. Oct 29, 2020 at 6:38 AM
    #345
    jowybyo
    Joe
    Baltimore, MD
    Weird, I guess I didn't notice that. The 2012 wiring diagram is the same as the 2014 and the connectors on my 2014 looked the same as what was shown in the wiring diagram.
  6. Oct 29, 2020 at 6:43 AM
    #346
    BassAckwards
    I may be wrong but I think the pinout is a little different. Plugs might be the same actually.. the URD sc has different wiring instructions for the 05-12 vs the 13-15 though
    Torspd likes this.
  7. Oct 29, 2020 at 6:43 AM
    #347
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
  8. Oct 29, 2020 at 6:59 AM
    #348
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Stand-alone ecu for tuning the engine. When you need absolute control. Great for turbo or supercharger builds.
  9. Oct 29, 2020 at 6:59 AM
    #349
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have the Elite 2500 on my truck.
  10. Oct 29, 2020 at 7:01 AM
    #350
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Probably plug availability or differences. The Boomslang company may have their own harness available. The ecu itself will. The plug n play nature, is the likely reason.
  11. Oct 29, 2020 at 7:07 AM
    #351
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Too bad you don't live closer.....It'd be fun to build a turbo header for a turbo kit. Hint hints.
  12. Oct 29, 2020 at 7:11 AM
    #352
    BassAckwards
    Do you need the motor in the truck to build the header? My guess would be yes, but now that i have a spare 2TR laying around figured i'd ask..
  13. Oct 29, 2020 at 7:14 AM
    #353
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Some parts yes. Some parts no. Ultimately, yes, to verify clearances. At least until a jig could be made.
  14. Oct 29, 2020 at 7:16 AM
    #354
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It would be an easy adaptation since you already have the s/c.
  15. Oct 29, 2020 at 7:40 AM
    #355
    BassAckwards
    Understood, that only makes sense. This will definitely happen at some point, i've been hunting for a nice stainless manifold and havent been able to track anything down, so hopefully we can change that!
    I did see where 5lugfury adapted his with the turbo and it did look pretty simple how he set his up. I will probably do something similar when the time comes, but im still debating on what to go with.. I still have a lot to learn about turbos too. With a built motor, would it be unrealistic to put down around 500rwhp/550rwtq? I have a feeling the power band would be higher in the revs to try and get those numbers but with my 5.29s it may not be that bad down low. I would think it has to be better than what it is N/A now
  16. Oct 29, 2020 at 9:01 AM
    #356
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    All depends on the size of the turbo, as well as the size of the turbine housing's A/R. Exhaust routing will or can play quite a role in spool time.
    For example, I have a 1k HP rated turbo, starting to make boost by 2K RPMs. All how you do it.
    With a built engine, that would not be hard to accomplish.
    BassAckwards[OP] likes this.
  17. Oct 29, 2020 at 10:23 AM
    #357
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Need to gather some materials, and make a road trip so we can make this happen. :D
  18. Oct 29, 2020 at 10:35 AM
    #358
    BassAckwards
    Have any recommendations on places to get 304 stainless flanges for the header and tubing? I will have to start getting some supplies together so we can make this happen. I may even go turbo before building the old motor. I think the turbo and the manifold would be the biggest costs since most everything else is already in place.
  19. Oct 29, 2020 at 10:44 AM
    #359
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any machine shop. Possibly even LCE.
  20. Oct 30, 2020 at 4:49 AM
    #360
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you want to supply the header flange material, Metal Supermarkets. Then you could give that to a machine shop.
    Half inch, is my recommendation.
