2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Dec 8, 2020 at 5:50 PM
    #401
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Oh man do I understand that pain. I'm excited for the new truck, but I also want to keep rebuilding the spare engine for boooost! I'm thinking of trying out a wet kit on the stock engine in the truck once the improved engine is ready to replace it...
  2. Dec 8, 2020 at 5:55 PM
    #402
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Didn't like exposed oiled filter with K&N setup having just the divider wall deal, didn't like no support for intake tube between TB and filter box on the Volant setup. Also Volant tube didn't provide mounting point for some vacuum thing like oem and K&N tube did. aFe was for the dry washable filter. The ramair part collected too many airborn objects in filter box. The Volant box also breathes thru oem wheel well port. So I combined the best of both setups with a dry filter.
  3. Dec 8, 2020 at 6:03 PM
    #403
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Also ran the LCE header for 8 yrs or so before it cracked at collector nugget. Had it welded back up but needs recoating. Also had Gibson catback and tooter intake spacer. Went all the way back stock with only aFe drop in during chasing the header leak. Had to replace cat, went with Bosal replacement. That's where she is now. Seems to like being back stock too, smoother, quieter and seems to be 2-3 mpg better on tank of gas. Just leaving it alone and driving it. It made it to 200k so it deserves some slack...............
  4. Dec 8, 2020 at 6:07 PM
    #404
    BananaMan
    This looks fantastic, the truck I'm getting has the K&N setup on it right now, how much did the volant filter box run?
    BassAckwards[OP] likes this.
  5. Dec 8, 2020 at 6:17 PM
    #405
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    Yeah the leak at the header has haunted me as well, but mine isn’t cracked, just that stupid spring clamp design.
    My plan at some point is to cut those flanges off, and weld on some v-band flanges and a flex pipe. I have chased lean AFRs in the past and it ended up being that stupid gasket leaking. So frustrating to have the primary AFR sensor downstream of that.
    What were your thoughts on the Gibson catback? I was looking for one of those at one point but couldn’t track one down.
  6. Dec 8, 2020 at 8:31 PM
    #406
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Wouldn't be hard to help you with a flange swap. :thumbsup:
  7. Dec 8, 2020 at 8:48 PM
    #407
    BananaMan
    @Torspd What do you need to come up with a turbo header? A truck with the engine in it? Or measurements of the space available with the engine in the truck?
  8. Dec 8, 2020 at 8:56 PM
    #408
    BassAckwards
    Thanks man! I will have to get your help with this once I get everything together
    I am running the LCE header and I think the collector flange is steel. Is there any issue welding 304 stainless to that?
  9. Dec 8, 2020 at 11:06 PM
    #409
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not at all.
  10. Dec 8, 2020 at 11:07 PM
    #410
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Thanks to BassAckwards, I have a header to get flanges made from. Then hopefully soon I can use my friend's truck for mock-up.
  11. Dec 9, 2020 at 1:20 AM
    #411
    BananaMan
    That's awesome! I've got an entire spare engine lying in various bits of my garage basement, not to mention the new truck coming I can use for measurements if needed. This is to say- I'm happy to use my scattered parts to help how I can!
  12. Dec 9, 2020 at 1:29 AM
    #412
    BananaMan
    This is just the block and head. Intake and exhaust and accessories is all in bins in my garage too. Nicely labeled I might add! 42611C13-303C-41E9-86F3-F3E6BFAC979C.jpg
  13. Dec 9, 2020 at 3:19 AM
    #413
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I liked the sound, gave it a cool gurgle with the header and intake. Mine is in the attic and ready for meetup for you to score from me,lol. Also I think Summit has new ones for $275. I would let mine go much cheaper than that and save shipping cost.
  14. Dec 9, 2020 at 3:22 AM
    #414
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I paid like 120 and 100 for the k&n and volant intakes used and tried them both then did my thing with them. Only mod was shortening then k&n tube slightly to make it right length to position the afe filter in the box correctly. Sold the ram air part awhile back.
  15. Dec 9, 2020 at 4:36 AM
    #415
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I gifted my used tooter spacer when going back stock but just happen to have new uninstalled one. Also a never installed urd maf calibrator, the used KVA intake in pic above with filter, gibson rc catback and the LCE repaired header that I will be making a fs thread about complete with pics all compliantlike....will be considering package savings and or trade for 040 skewpt hood, lol........this is the head's up post. Preference will be given for meetup sales to sidestep shipping. Won't be shipping catback for sure. Advantage TX residents.
  16. Dec 9, 2020 at 5:10 AM
    #416
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'll keep that in mind.
  17. Dec 9, 2020 at 6:17 AM
    #417
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Spacer dibs, idk why, but dibs :D
  18. Dec 9, 2020 at 12:04 PM
    #418
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Also have an Innovate wbO2 with gauge that has never seen a bunghole for all you fi guys monitoring afrs and such......
    BassAckwards[OP] and BananaMan like this.
  19. Dec 9, 2020 at 3:08 PM
    #419
    BananaMan
    Would you ship that piece in particular? I'll be wanting that come turbo time.
  20. Dec 9, 2020 at 3:53 PM
    #420
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yeah, maf calibrator, im spacer, header & wbO2 are not unshippable, just added cost. The intake stuff wouldn't be that heavy but would be big box and extra shipping due to size. The catback had some miles on it and is in one piece so that is mostly a meetup item. Not sure I could even get it separated at this point. I don't live in rust area but when I had all this on the truck it was getting a lot of 85 on the frwy for 80 miles a day. Muffler still in good shape. It is the aluminized version, not the stainless version.
    IIRC, the wbO2 is Innovate LC-2. I will put hands on it and give more detail. Also provide current pics with signage to be all correct and such before any possible transaction.
    BananaMan likes this.
