2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Dec 10, 2020 at 4:12 PM
    #421
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    Outran a 5.3 avalanche on my way home today.
    The guy was pretty cool though, he complimented the truck afterwards. I think that’s the first person I’ve run since putting the blower on. This was on the conservative stage 1 pulley/tune so there’s still room for improvement:devil:
    not_nick, EdgemanVA, Torspd and 3 others like this.
  2. Dec 10, 2020 at 4:28 PM
    #422
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I'm not saying I want to make money using my truck once it's turbo... but I wouldn't be against it. :burnrubber:
  3. Dec 10, 2020 at 4:33 PM
    #423
    BassAckwards
    I’m sure it’ll be a sleeper by the time you’re done with it. I am looking forward to someone building a 2TR and seeing what kind of numbers they can put down. They sure do respond well to boost
    BananaMan[QUOTED] likes this.
  4. Dec 10, 2020 at 4:45 PM
    #424
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    What fuel pump do you have?
  5. Dec 10, 2020 at 4:46 PM
    #425
    BananaMan
    My updated goal after more researching and planning, is to hit 25lbs of boost. I think I'll be struggling keeping a clutch or tires in it at that level. No idea what the limits of the r155 are that this truck has.
  6. Dec 10, 2020 at 4:53 PM
    #426
    BassAckwards
    I’m running the AEM 340
    Steves104x4[QUOTED] likes this.
  7. Dec 10, 2020 at 4:59 PM
    #427
    BassAckwards
    That sounds like a good round number lol. Do you know how much the stock intake manifold can take before it needs upgrading? I have wondered how necessary it is to swap intake manifolds once you start pushing it
    I have read some stuff online and it’s sounds like it’s a beefed up version of the r154 that comes in the is300 and Supra. From what I’ve read you can use the billet shift forks for the r154 in them as well.
    https://www.clublexus.com/forums/pe...r155-transmission-a-new-solution-to-r154.html
    Torspd and BananaMan[QUOTED] like this.
  8. Dec 10, 2020 at 5:01 PM
    #428
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on the motor?
  9. Dec 10, 2020 at 5:02 PM
    #429
    BananaMan
    I figured I'd put a block off plate on one side of the intake I have lying in my garage, and another on the other side with an air chuck and try putting 25psi to it.
    The bigger thing I'd be worried about is the heat. I remember talking with 05taco4x4 a while back about a metal intake and the flange to mate it to the 2tr. As well as the performance fuel rails. I definitely want to lean that way, but we'll see how things go.
  10. Dec 10, 2020 at 6:27 PM
    #430
    BassAckwards
    Around 112k on this motor. About 100k on the trans
  11. Dec 10, 2020 at 6:35 PM
    #431
    BassAckwards
    That would be a good way to test it, I bet the plastic holds up pretty well. A nice aluminum one will always be calling my name though
    He does make some nice stuff for sure. The fuel rail is on my list one day too, it’ll probably happen whenever the injectors need upgrading. Have you figured out what size primaries you’re going to run with your build?
  12. Dec 10, 2020 at 6:47 PM
    #432
    BananaMan
    I have my parts list saved somewhere... I just have to find it again now that I'm getting back into Tacoma things! I honestly can't remember off the top of my head, I talked about it and decided which ones over in the turbo bs thread at some point...
  13. Dec 10, 2020 at 6:51 PM
    #433
    BananaMan
    I missed a lot while I took a hiatus after my white taco died. Did @MrCrowntown ever get his LCE built turbo engine going?
    MrCrowntown and BassAckwards[OP] like this.
  14. Dec 11, 2020 at 5:40 AM
    #434
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @05Taco4x4 has a built 2TR. Turbo, GTR coil packs. Beautiful build.
  15. Dec 11, 2020 at 5:42 AM
    #435
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I believe it is still on a stand. :pout:
    MrCrowntown likes this.
  16. Dec 11, 2020 at 8:17 AM
    #436
    BassAckwards
    I couldn't agree more, his is one of my favorites for sure, all of his work is super clean. When you say GTR coil packs you mean like Nissan GTR?
  17. Dec 11, 2020 at 8:35 AM
    #437
    BassAckwards
    Did you pull the motor out of your white truck and sell the body?
  18. Dec 11, 2020 at 10:10 AM
    #438
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Yep.
  19. Dec 11, 2020 at 10:42 AM
    #439
    BananaMan
    Nope, the motor pictured is the spare I was rebuilding for the white truck. When the white truck lost the fight with the deer I sold it as it was. The motor had 250k hard miles on it and was drinking oil like a mill worker drinks alcohol.
  20. Dec 11, 2020 at 6:45 PM
    #440
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I decided a couple weeks ago I'm going to keep the truck so I'll have it tuned in the coming weeks, my goal is by Feb.
