2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Feb 23, 2020 at 11:31 AM
    #61
    OVTune
    OVTune Well-Known Member
    OVTune
    yes
  2. Feb 23, 2020 at 11:47 AM
    #62
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
    MY50cal and BassAckwards[OP] like this.
  3. Feb 23, 2020 at 3:01 PM
    #63
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  4. Mar 4, 2020 at 4:23 PM
    #64
    Dean2016
    Dean2016 Active Member
    Dean
    2016 tacoma SR 4x4 5sp
    Got 16' here, would be interested in this in the future
  5. Mar 5, 2020 at 8:39 PM
    #65
    lamjam
    lamjam Well-Known Member
    Los Angeles
    2021 TRD Off road 4x4
    Is this going to work for the 3rd gens? Take my money right now if it works for the 3rd gen
  6. Mar 6, 2020 at 4:43 AM
    #66
    OVTune
    OVTune
    Unfortunately it won't support the 3rd 2.7 gen right now
    whatstcp likes this.
  7. Mar 6, 2020 at 6:49 AM
    #67
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    2012!
    BassAckwards[OP] likes this.
  8. Mar 7, 2020 at 12:26 PM
    #68
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    ^ he is kidding btw
  9. Mar 12, 2020 at 4:11 PM
    #69
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    I'm thinking a group buy for OVT 2TR ghost cam/flame tunes might be in order...
    Matt, I need at least this much chop, thanks!
    ...also kidding
  10. Mar 23, 2020 at 10:50 AM
    #70
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
  11. Mar 23, 2020 at 11:00 AM
    #71
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
  12. Mar 23, 2020 at 11:10 AM
    #72
    BassAckwards
    Not that im aware of, havent seen/heard anything from anyone on here.. my 2.7 has a head gasket starting to go bad, so i wont be able to jump on that bandwagon for at least a few months:(
  13. Mar 23, 2020 at 11:11 AM
    #73
    BassAckwards
    Every little bit helps! I will be doing the same when the time comes. If there is throttle mapping available with this, it should make the truck feel much peppier
    Brian422 and whatstcp[QUOTED] like this.
  14. Mar 23, 2020 at 1:30 PM
    #74
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I need a 2nd gen 2.7 tune @OVTune!
    whatstcp and BassAckwards[OP] like this.
  15. Mar 24, 2020 at 9:04 PM
    #75
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    Did anyone hear anything else about the VT Racing twin screw kit?
  16. Apr 6, 2020 at 5:27 PM
    #76
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    09 2tr here
  17. Apr 6, 2020 at 5:30 PM
    #77
    BananaMan
    Everything I've seen is that the pistons and balance shafts are the weak points. But not until some pretty good boost levels.
    Hooligans[QUOTED] likes this.
  18. Apr 6, 2020 at 6:01 PM
    #78
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Get it and let's see what you can do with it!
    BananaMan[QUOTED] likes this.
  19. Apr 6, 2020 at 6:19 PM
    #79
    BananaMan
    I'll happily start with the stock Ecu as long as it can support my mods/need for power. And hey, first time ever tuning anything with a computer, nothing can go wrong!
    Torspd[QUOTED] likes this.
  20. Apr 6, 2020 at 6:42 PM
    #80
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Says the color blind man, cutting the green wire.... :anonymous: :D
    BananaMan and whatstcp like this.
