2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Sep 9, 2021 at 9:13 AM
    #961
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Ouch. Lots of ouch. Weird too. My buddy was running around 13 psi for a short while. Super glad that his didn't grenade.
    If you're getting a used replacement, what are your plans with it?
  2. Sep 9, 2021 at 9:23 AM
    #962
    Sscustoms
    Sscustoms Well-Known Member
    Seth
    05 taco 2.7 5spd
    -315s on Methods -5.29 gears -Arb/Detroit lockers -Twin Arb compressor -LCE header -mandrel 2.5” side exit exhaust -4X rock sliders -LCE dual comp clutch
    I have since aquired 2 core engines. One is currently being setup to be a stock fresh rebuild with standard bore. Second block already has arp top/bottom studs and head is at LCE for porting/cams/valves. Forged 8.5:1 pistons and rods are also all paid for and awaiting delivery. Both blocks will have balance shaft deleted. It all takes so bloody long to get things together and rolling, LCE has gained me a lot of traction. Boost limiting valve pictured will be set at ~3psi and tig welded into the cold side tank of the intercooler. Current 80mm pulley will stay on along with MAP ECU3 and 5th injector. This will all stay on the stock block. Build block is getting a haltech with integrated water/meth injection… yes, ouch. Lots of ouch.
    Once the built block is done ill open up the boost back to the 9-10psi range and see how i like it. Im only clutched for 385hp so i probly wont be able to go much above that. 61DB4E4E-DF43-4C9D-AE86-5DC6194E6AB3.jpg
    Taco47 and BananaMan like this.
  3. Sep 9, 2021 at 9:30 AM
    #963
    Sscustoms
    Seth
    05 taco 2.7 5spd
    I really assume its purely due to the dead weight of the trailer, oversized tires etc. it was totally fine until the first trip towing a trailer with a side by side, it was decetly loaded down, dirtbike, SXS and all the camping gear and i wooded it in 3rd to pass a quad cab with a toy hauler and it held for a long time during the pull. But let loose after appx 10secs of floored action. Never even saw redline. I need to get some pics of the piston to show. Ill do that tonight
  4. Sep 9, 2021 at 9:51 AM
    #964
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Your built engine will likely be the new one to replace @MrCrowntown 's :boink: It will be far stronger than 385 too.
    Said, "It's been a blast, but I'll see myself out."
  5. Sep 9, 2021 at 12:35 PM
    #965
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Mine is sad, and needs to put in its new home. Damn not having any freetime!
    buyobuyo, BananaMan and Sscustoms like this.
  6. Sep 9, 2021 at 2:00 PM
    #966
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pay some friends to swap it in???
    MrCrowntown[QUOTED] likes this.
  7. Sep 9, 2021 at 2:27 PM
    #967
    Sscustoms
    Seth
    05 taco 2.7 5spd
    Do you legit have a fully built engine sitting in your garage not exchanging oxygen!?!?
  8. Sep 9, 2021 at 3:08 PM
    #968
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    He has for quite some time now...
  9. Sep 9, 2021 at 3:11 PM
    #969
    Sscustoms
    Seth
    05 taco 2.7 5spd
    either some wicked will power or lost the go fast mojo, i mean how is that even possible. I swear once ive got product in hand ill probly take a vacation day to install. After waiting 8months from the point of block impact im getting antsy to hear the side dump rev limiter again
    BananaMan[QUOTED] likes this.
  10. Sep 9, 2021 at 3:13 PM
    #970
    BananaMan
    If I remember correctly, he runs his own business and business has been booming. Also the truck or engine is somewhere else in the country and he still needs to rectify that.
    edit: I also believe his was a prerunner/desert hopper build? I can't remember 100%
    Torspd and Sscustoms[QUOTED] like this.
  11. Sep 9, 2021 at 3:16 PM
    #971
    Sscustoms
    Seth
    05 taco 2.7 5spd
    Stupid adult priorities getting in the way of play time man.
  12. Sep 9, 2021 at 3:20 PM
    #972
    BananaMan
    You're telling me! Been talking with LCE and others about this build for a year... then I have to go and try to buy a house. Talk about a money suck. And restoring a classic British car. :annoyed:
    Sscustoms[QUOTED] likes this.
  13. Sep 9, 2021 at 3:30 PM
    #973
    Sscustoms
    Seth
    05 taco 2.7 5spd
    Skip that drama lol. Buy a sick hauler and live in overland mode with a car trailer.. “in a van down by the river, livin on government cheese”
  14. Sep 9, 2021 at 3:40 PM
    #974
    Bloodytaco208
    Bloodytaco208 Well-Known Member
    Twisted steel sex appeal reg cab tacoma
    Bunch of built and bought mods
    Has lce or any other company produced a turbo cam for the 2.7l or is it just custom order
    05Taco4x4 and BananaMan like this.
  15. Sep 9, 2021 at 4:45 PM
    #975
    BananaMan
    Custom order so far. Best experience of contact and talking details has been with WEB cams. Six week turnaround, you send them your stock cams they modify and have it back to you. 1100 said and done.
    edit: for what it's worth, LCE is who recommended I contact WEB cams.
    05Taco4x4 and Sscustoms like this.
  16. Sep 10, 2021 at 12:00 PM
    #976
    MrCrowntown
    Alyn
    Ky
    Correct! Still in the shipping crate lol it took so long to get the motor from them as it was used for R&D, that my whole work and state location changed while I waited.
  17. Sep 10, 2021 at 1:19 PM
    #977
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I could knock that out in a weekend..... :boink:
    Bloodytaco208 likes this.
  18. Sep 10, 2021 at 1:25 PM
    #978
    Bloodytaco208
    H
    Hmmm going to have to contact them. I have a motor that i picked up for 200 so hopefully this winter is getting tore down and rebuilt to harness the power of the gods lol. Just need around 20 psi of boost.
    05Taco4x4 and BananaMan[QUOTED] like this.
  19. Sep 10, 2021 at 1:27 PM
    #979
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That sounds delightfully fun.
  20. Sep 10, 2021 at 1:28 PM
    #980
    Bloodytaco208
    And wheelies cant forget about doing wheelies
    Torspd likes this.
