2TR-FE Performance Thread
Discussion in '4 Cylinder' started by BassAckwards, Oct 30, 2019.
  1. Jun 26, 2025 at 11:46 AM
    #1521
    BassAckwards
    BassAckwards [OP] Well-Known Member
    2009 Tacoma AWD Turbo 2TR-FE
    I’d double check with them, but I bet they are going to be needed separately. They’re worth the extra money though. Probably not much more expensive than a set of new toyota head bolts
    Brian422[QUOTED] likes this.
  2. Jun 26, 2025 at 12:23 PM
    #1522
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Anything else to do while im in there. Already got a Valve cover gasket. Mines been leaking.
  3. Jun 26, 2025 at 12:38 PM
    #1523
    BassAckwards
    Spark plug tube gaskets since they’re known to leak and they are separate from the valve cover gasket.
    Are you planning on pulling the head or installing the studs with the head on? I’ve done it both ways and its definitely easier to have the head off while you’re chasing the threads, but that also involves pulling the timing cover off.. You’ll need an M11x1.25 thread clean out/chaser tool to get the block ready to accept the studs either way
  4. Jun 26, 2025 at 12:46 PM
    #1524
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Idk yet, still in the planning phase. Ive never done any deep engine work but i consider myself pretty capable so not too worried lol. I want to make it as reliable as i can since i travel 7+ hours away sometimes in the truck. So i probably will go the route of taking head off if its better.
  5. Jun 26, 2025 at 12:58 PM
    #1525
    BassAckwards
    Yeah you’re plenty capable of knocking it out yourself. There are a list of o-rings and sealants needed for the head gasket job/timing cover removal on page 1. If the timing cover is off you’ll be able to inspect all your timing chain guides and see how they look. I’d say they should be replaced if near 200k miles to be on the safe side. If going this route, definitely stick with OEM on the guides & tensioners
    You could also consider doing a balance shaft delete (LCE makes a kit), but definitely read the instructions as it is a little involved leaving the motor in the truck. These are a known weak link on our motors though since they turn twice the RPM of the crankshaft
  6. Jun 26, 2025 at 1:04 PM
    #1526
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Truck clock says 135k probably closer to 150k since i have 35's on truck. What boost gauges your running?
  7. Jun 26, 2025 at 1:10 PM
    #1527
    BassAckwards
    Probably fine to leave the guides alone at that mileage. I’m running AEM gauges on my truck but im not thrilled with the quality.. if i was to do it over again id go with something like this from speedhut
    https://www.tacomaworld.com/threads...ricks-and-mods.518932/page-2581#post-30458916
  8. Jun 26, 2025 at 1:31 PM
    #1528
    Brian422
    Brian
    Birmingham, AL
    Not Stock
  9. Jun 26, 2025 at 1:48 PM
    #1529
    BassAckwards
  10. Jun 26, 2025 at 2:59 PM
    #1530
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    says it can display
    https://bankspower.com/pages/idash-glossary
  11. Jun 26, 2025 at 3:04 PM
    #1531
    BassAckwards
    Is that using OBDII data though? Ideally, you should have a separate AFR sensor and bung in your exhaust that feeds the gauge instead of the factory sensor.
  12. Jun 26, 2025 at 3:49 PM
    #1532
    Brian422
    Brian
    Birmingham, AL
    Not Stock
  13. Jun 27, 2025 at 7:44 AM
    #1533
    BassAckwards
    Cool, that’s definitely a good option since it has that separate sensor. Im interested in seeing how you like it if you go this route. There’s a lot of different stuff you can display. Are you thinking of going with an a-pillar mount, or something like the Lotek that mounts in front of the steering wheel?
  14. Jun 27, 2025 at 8:03 AM
    #1534
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    idk yet. Still trying to piece a budget together lol. Trying to sell one of my motorcycles so i can get started. I think id rather have in front of the steering wheel but we will see how everything would fit up. I called and spoke with Gabe at S and P speed innovations and he was very helpful. They said if i call them once i get everything installed they can remote to my laptop and tune the truck for me. I feel like that is big lol/
  15. Jun 27, 2025 at 8:21 AM
    #1535
    BassAckwards
    That will help get you started much more easily. The haltech is pretty easy to use also if you want to make adjustments later on. I adjusted my idle up to about 1000rpm to help with the AC performance during the summer. You can make it do whatever you please, the adjustability is awesome
  16. Jun 27, 2025 at 8:34 AM
    #1536
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Yea looking forward to the project. Cant wait to get some boost on the ole girl lol. She needs it.
  17. Jun 28, 2025 at 5:41 PM
    #1537
    hayrider2.0
    hayrider2.0 Over the hill and going down fast!
    Hey You
    2 Centimeters from Hell 200 Miles from Water
    05 & 07 White Reg. Cabs w/ sticks
    05 Magnuson 07 LS Swapped
    Just an FYI Do NOT leave any shavings in the engine like others have done here before! :hattip:
    Would you agree @BassAckwards ⁉️
    Oh, sorry to say the head studs do not come with the supercharger but you can ask for the good guy deal being your dropping some coin with them. The more you purchase I’m guessing the better deal you might get… :notsure:
  18. Jun 28, 2025 at 8:00 PM
    #1538
    BassAckwards
    Clearly you want to clean up everything, but there were no shavings left from chasing the threads in my case Randy:D
    This was from the main bearing that failed which was damaged when you had a shitty tune and probably filled it up with 87 w/ the supercharger. You’ve openly admitted to doing in this thread a few posts back. If you’re gonna post my own picture at least know what you’re talking about:rofl:
    Detonation is hard on engine internals @hayrider2.0 - wouldn’t you agree now?
    Brian422 likes this.
  19. Jun 29, 2025 at 4:52 AM
    #1539
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    What are the head studs dimensions? There’s a longer stud available for the V6 and V8 engines, it threads deeper into the block and bottoms out, might work well if there is room for it.
  20. Jun 29, 2025 at 5:37 AM
    #1540
    hayrider2.0
    Hey You
    Y
    :jerkoff:
    I never ran 87 in the PERFECTLY good engine I sold you WITH 27K original miles for $1,000.00 less than someone else offered me for it! I put 87 in my 05 w/ 157k miles But I guess you can’t read too…
    Plus the engine was still full of oil with MORE than a 1000 miles on the oil when you picked it up and there was ABSOLUTELY NO PIECES OF GLITTER IN THE OIL WHEN YOU DRAINED IT‼️ YOU LEFT SHARDS IN THE ENGINE WHEN YOU COMPLETELY DISASSEMBLED THE ENGINE And CHASED THE TREADS LESS THE CRANK AND PISTONS!! SHARP PIECES OF METAL DONT COME OFF BEARINGS‼️ PLUS THE BEARINGS HAD ABSOLUTELY NO WEAR WHATSOEVER‼️ WHAT A F*CKING ASS YOU ARE. :D
    Plus I told you a long time ago I buy the engine back but you know YOU FUCKED UP, RIGHT⁉️
    I can copy and post are messages here for all to see along with all the other pictures you posted.
    You ass don’t make me out to be the bad guy. So either apologize or FUCK OFF. :jpow:
    :brianr:
