2TR Performance Parts!!!
Discussion in 'Performance and Tuning' started by LsuMeDesigner, Dec 4, 2012.
  1. Jan 21, 2013 at 7:58 AM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Jan 24, 2013 at 8:10 AM
    #42
    LsuMeDesigner
    LsuMeDesigner [OP] Well-Known Member
    Alright for anyone interested I started the build thread under the build section, with the name SupraYota
  3. Jan 24, 2013 at 8:14 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Link? I didn't see it.
  4. Jan 26, 2013 at 2:09 PM
    #44
    LsuMeDesigner
  5. Jan 27, 2013 at 7:46 AM
    #45
    LsuMeDesigner
    I gave up on 2tr because there is no aftermarket support. I would have to spend time researching, designing, and developing all my own parts. I just don't have the time with my work schedule right now.
    I chose the GE over GTE because they are not very different and the GE is much cheaper and easier to get a hold of. I'm the type of person that is going to tear a part an engine if it's used before I just slap it in. If I'm going inside the engine I might as well get the GE and upgrade it.
  6. Jan 28, 2013 at 11:08 AM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Wikipedia has the dimensions listed.
    As far as rods being forged, I highly doubt it, since it isn't classified as a GZE or GTE engine. Most likely they are the same powder cast steel rods. Inherently weak as well as thin which makes them structurally weak as well. I would also place money that the pistons are hypereutectic pistons.
    Crank I am sure will handle plenty of power though. If it is anything like the 1GR crank which has been tested to over 630 whp and ~620-650 wtq.
    Sending out a rod and piston to a manufacturer would make it super easy to have a set made. Being a 4 cyl., it wouldn't be expensive either. Relatively.
  7. Jan 28, 2013 at 1:08 PM
    #47
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pretty sure that they are 10:1 compression as well. You can always try talking with Omar at Joe Meyer's Toyota, on Eldridge and 290.
  8. Apr 18, 2013 at 9:25 AM
    #48
    franzcars
    franzcars I'm different, in a different way
    Justin
    ST.louis MO
    08 Base Taco I4
    Plasti-dipped rims, blacked out Taco logos, small interior mods, AFE prodry drop-in, DJM 3/4 drop, Viper alarm, Power locks, Fogs, Viper 305 alarm, Kenwood HU
    SingleCabGuy have any luck getting the rods and pistons? I was reading around and like other I wonder how similar the rods are to the 3gr and was wondering if you had any luck
  9. Apr 18, 2013 at 9:48 AM
    #49
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    Damn, what happened to the rod and piston you ordered?
  10. Apr 18, 2013 at 9:57 AM
    #50
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  11. Apr 18, 2013 at 10:03 AM
    #51
    franzcars
    Justin
    ST.louis MO
    08 Base Taco I4
    That's why SingleCab got a piston and rods, which i might be doing when i get a job. All parts will need to be custom made, and we're basing it off of the fact that we might have a forged crank. So we'd need to get a custom manifold, figure out what to do with the air valve, tuning, injectors and a few other things. But since my parents wont allow me to have another car, might as well make due with what i have
