2TR rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Nation, Jan 30, 2016.
  1. Jul 18, 2016 at 1:56 PM
    #141
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    One down, one to go. At least it is drive able now. Wonder if the water messed with some of the components of the air pump? Might have to look it over.
  2. Jul 18, 2016 at 8:26 PM
    #142
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    https://hewitt-tech.com/store/index.php?l=product_list&c=26
    Might want this info?
    Torspd likes this.
  3. Jul 23, 2016 at 2:52 PM
    #143
    Taco Nation
    Taco Nation [OP] Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
  4. Jul 23, 2016 at 3:54 PM
    #144
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is strange. When you turned the truck off and turned it back on, did it still have knock?
  5. Jul 23, 2016 at 6:14 PM
    #145
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Yes. And it was 10 times worse
  6. Jul 24, 2016 at 6:56 AM
    #146
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Uh oh. Drain some oil and look for shavings.
  7. Jul 24, 2016 at 7:03 AM
    #147
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Dude you just can't catch a break.
  8. Jul 24, 2016 at 2:13 PM
    #148
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Planning on it when I am not so mad
  9. Jul 24, 2016 at 2:14 PM
    #149
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Can't win for loosing
  10. Jul 24, 2016 at 5:50 PM
    #150
    landphil
    BC, Canada
    Tundra 5.7 mod
    If you didn't have bad luck, seems you'd have no luck at all.
  11. Aug 2, 2016 at 6:03 AM
    #151
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    Turns out the knock was actually the balance shaft chain flopping around. A bolt holding the tensioner broke as well as a few plates and the tensioner itself. Ended up eating the bearings for the balance shafts. Looks like we are going to replace the bearings and reinstall the shafts and just leave the chain off.
  12. Aug 2, 2016 at 6:09 AM
    #152
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Had the bearings spin, in my friend's tC, for his counter balance shafts. They no longer spin either now.
  13. Aug 2, 2016 at 8:52 AM
    #153
    tgear.shead
    tgear.shead Well-Known Member
    Well there, that sounds like finally a bit of GOOD(-ish) luck in the middle of a run of bad. Funny though that the "bad thing" just turned out to be "not that bad".
