2TRFE Idler Pulleys and Tensioner Part Numbers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blackfreighter, May 20, 2020.
  1. May 20, 2020 at 6:25 AM
    Blackfreighter
    Blackfreighter [OP] Member
    Ben
    2006 4cyl Tacoma AWD extended cab
    There have been a few questions about a replacement for the tensioner pulley on the 2TRFE Tacoma. At least in my 2006 the
    The OEM parts are:
    Top Idler Pulley on the Tensioner: 16603-0P030
    Bottom Idler Pulley bolted to the block: 16603-31030
    AC Idler Pulley: 88440-25070
    The Gates part numbers are
    Top:36173
    Bottom: 36174
    AC: 36614
    If you want to press new bearings in it saves a ton of money and its pretty easy with a puller and an old socket.
    Bearing numbers are:
    Top: 6203DUL1 - 17mm x 40mm x 12mm (Regular deep groove ball bearing with double shield)
    Bottom: two of 6302RMX - 10mm x 42mm x 13mm (This one is an oddball, as the 6302 has a 15mm bore normally, so you can't get these from a regular bearing shop)
    AC: two of 6303DU2 - 17mm x 40mm x 14mm (Regular deep groove ball bearing with double shield)
    BassAckwards likes this.
  2. May 20, 2020 at 6:34 AM
    mikkydee
    mikkydee My Taco 2007 DCLB 4x4 Man Truck
    Doyle
    Florida
    2007 Silver DCLB Tacoma, 4X4, 4.0 Liter, 6" lift, 20" rims, 34" tires
    6" lift, 20 " inch rims, 34" tires, billet grill, aftermarket fender flares, custom rear bumper, DVd player with backup camera, all LED lights
    Great info Blackfreighter. How did you find the bearing replacement sizes for this? I may need to do this on my 1GRFE
  3. May 20, 2020 at 6:42 AM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Bearings usually have a number on them that specs what size it is. There is a bearing regulatory commission of sorts that exists that standardized this stuff. In theory a bearing should never go bad for the application it’s used in and they have all sorts of charts and data to help engineers figure out what bearing to use, but obviously sometimes that’s too expensive and they also want to sell replacement parts so it doesn’t always happen like that. I had to take a class on bearings and gears hence I know this useless stuff lol.
    anyways, OP you should post this on the 4 cylinder section.
  4. May 20, 2020 at 1:07 PM
    Blackfreighter
    Ben
    Spot on with the answer, got there before me. I'll repost it to the 4cyl section. Thanks.
  5. Dec 22, 2022 at 6:16 AM
    POedHandyman
    POedHandyman Member
    Searching on parts.toyota.com, these part numbers aren't matching up.
    I would like to do all the idlers pulley on my 2trfe.
    I believe there are 3. Two of which are identical.
    Recently started screeching above 2500rpm, and I want to replace them all and be done with it.
    The belt is brand new already, replaced it last year.
    Any guidance would be great. Thank you!
    Black97v6MT likes this.
  6. Apr 14, 2024 at 5:53 PM
    ingyhere
    ingyhere Member
    Los Angeles, CA
    2006 Taco Prerunner SR5
    For 2005-2007 models (if I recall correctly), the Toy bottom pulley has been discontinued. All that I read says the aftermarket ones rub, and the workaround is to use a washer underneath. Some seem to have the washer included (can't remember which ones). Gates issued a TSB and advises purchasing hardware kit Gates #91051 to deal with spacers/washers, but it is over $100 easy. (Hint: Search 91051 on Ebay for deals.) I think even the replacement p/n Toy pulley is tight. Part numbers may differ for 2008+ models (again, if I recall correctly).
    Updated P/Ns:
    Top Idler Pulley on the Tensioner: 16603-0P030 (current) (also possibly 16603-75010 -- maybe the same, maybe transitioned around 2008)*
    Bottom Idler Pulley bolted to the block: 16603-31030 16603-31040 (current)**
    AC Idler Pulley: 88440-25070 (current)
    Top Idler pulley on the Tensioner: 36173 (This is sort of an off-the-grid recommendation since catalogs will say it's wrong, but aren't assuming tensioner pulley replacement.)*
    Bottom: 36174 (called "Upper" in catalogs)**
    AC: 36614 (called "Lower" w/AC in catalogs)
    * Various catalogs are unclear about this, perhaps because different manufacturer tensioners were used in manufacturing. Therefore, providing a VIN and closely inspecting the part may be a best solution. Also, I would recommend replacing the actual tensioner instead of just the tensioner pulley. That's because the spring inside the tensioner is under constant load and vibration so likely fatigues and/or weakens over time with heat and vibration. Just buy a new made-in-Japan tensioner.
    ** See Toyota Parts website for "Previous Version(s)". (Note, at this time the site sucks, and you have to search it with Google to get any meaningful information.) The Gates version from all info is like the newer Toy version so the h/w kit is needed. AC Delco Gold makes on available on Rock Auto that includes bolt/spacer/washer but it's thermoplastic. BUT NOTE THAT you may want the Toy version, anyway, since it is a double bearing design versus aftermarket single-bearing pulleys (that won't last).
  7. Apr 15, 2024 at 6:28 AM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
    Great info, thanks. Seems I have to do this soon along with the tensioner
  8. Jul 5, 2024 at 1:31 PM
    bflan
    bflan Member
    LA, CA
    2005 2.7l 5 lug slug
    I’m having trouble with replacing the bottom pulley (one that bolts to the block) on my 2005 2.7l. Seems like the pulley bearing has a smaller interior diameter on the 2008-2015 updated part. So has anyone successfully installed the updated OEM part 16603-31040 on a 2005-2007 Tacoma 2.7l? Seems like it would need a different (small diameter) bolt and spacer to work? Or should I just go with the gates 36174 (and maybe a 1/8 washer?) Also curious if anyone has found a reputable source for the Koyo 6302RMX bearings if I end up having to just press them out. Not sure if I trust the eBay/“Asian Auto parts”ones
  9. Jul 5, 2024 at 1:54 PM
    ingyhere
    ingyhere Member
    Los Angeles, CA
    Yeah, I bought a Koyo 16603-31040 a couple months ago and it was priced right and fantastic: https://www.ebay.com/itm/322622068244 .
    The hardware kit is the key. For the 16603-31040 there's a weird ferrule/spacer/bushing thingie that adapts it for certain variants. Also, and this is important, The Gates is *not* an identical replacement whereas the Koyo matches as a "double bearing" (look around edges of pulley). You'll get more longevity from a double bearing, I believe. It's cheap so I took a chance and bought it. Made in Japan and it looks like a duplicate of the original toyota part for a fraction of the price.
    If you didn't get the hardware kit, you can get all the hardware from this b*tchin hardware kit which is a clone of a brand-name kit: https://www.ebay.com/itm/274455114056 . It's like $100 less than the brand name but made by the same company, I believe. Lots of extra hardware there, too. I bought it, and it looks fantastic.
    Steves104x4 likes this.
  10. Jul 5, 2024 at 3:51 PM
    Hopehik
    Hopehik Active Member
    Steven
    Maine
    13 Tacoma DCSB TRD Sport
    I bought my tensioner pulley, idler and belt on ebayand if I do it again will just get them through a Toyota dealer online. Quality was questionable, not sure how long they will last (bearings), doesn't seem worth it to do it twice
    Black97v6MT and Steves104x4 like this.
  11. Jul 6, 2024 at 12:44 AM
    bflan
    bflan Member
    LA, CA
    This is all super helpful, thanks!
  12. Jul 10, 2024 at 12:40 PM
    ingyhere
    ingyhere Member
    Los Angeles, CA
    That's not what I posted. I know it's hard, nigh impossible sometimes, to get the right parts on Ebay. The secret is that Toyota contracts out for high quality, tightly spec'd parts. Those links are only made in Japan parts by the OEM manufacturer, and that's exactly what I wanted. Also, consider they were a third or half the price. If you buy Ebay and it's not what was expected, just return it. No harm, no foul.
    The kicker: You *cannot* get one of the original parts from Toyota (2005-2008, maybe later/discontinued). You'll need spacers and/or a washer for the replacement p/n. The Gates parts are decent but they are definitely not the same (not "double bearing"). If you have the capacity to properly inspect and match parts there's no reason to pay mucho extra for a nice, shiny red and white box.
