2WD-4WD mode change malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YotaEmma, Jul 12, 2020.
  1. Jul 12, 2020 at 3:59 PM
    YotaEmma
    YotaEmma [OP] Member
    Emmanuel
    2020 Black TRD Tacoma
    Lift kit, wheels and tires
    Anyone get this message before after going off-roading “ 2WD-4WD CHANGE MODE MALFUNCTION”
    after going off-roading I tried to put my truck into 2WD and it wouldn’t let me... I was stuck on 4WD so I had to get it towed home. Anyone know what can be wrong? I called the dealer but they haven’t gotten back to me.
    Please help! Thanks!
  2. Jul 12, 2020 at 4:08 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    If your truck is a 2020 then bring it to dealer for warranty repair. Nobody here can fix it and if it’s under warranty I wouldn’t attempt to touch it. Let the dealer fix it
    kgilly and synaps3 like this.
  3. Jul 12, 2020 at 4:09 PM
    YotaEmma
    Emmanuel
    Thank you so much!! Appreciate the quick response!! I’ll take it in! Yeah I just got it 5 months ago!
    TacoTime850 likes this.
  4. Jul 12, 2020 at 4:09 PM
    Bishop84
    Bishop84 Well-Known Member
    Just book it in, they wont fix that over the phone.
    YotaEmma[OP] likes this.
  5. Jul 12, 2020 at 4:17 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    @BigWhiteTRD probably knows. I think we get free AAA or someshit right? With our warrantys? Make sure they reimburse you
    BigWhiteTRD and YotaEmma[OP] like this.
  6. Jul 12, 2020 at 4:18 PM
    TacoTime850
    2019 DCSB 4x4
    They’ll sort it out. Good luck and hope you’re not without your new toy for too long!
    YotaEmma[QUOTED][OP] likes this.
  7. Jul 12, 2020 at 4:19 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    It could be the actuator and / or transfer case. Plenty of information available on TW. You just need to use the search function.
    Here is one thread:
    https://www.tacomaworld.com/threads/help-asap-stuck-in-4wd.559749/
    Let the dealer take care of it.
    If your undercarriage is dirty / muddy you might want to clean it up before taking it to the dealership.
    BSFord, AKGSD and YotaEmma[OP] like this.
  8. Jul 12, 2020 at 4:20 PM
    TacoTime850
    2019 DCSB 4x4
    True, good call
  9. Jul 12, 2020 at 4:20 PM
    YotaEmma
    Emmanuel
    @Skydvrr really! I had to pay for a tow earlier today for it to get to my house! And it wasn’t cheap lol
    Skydvrr likes this.
  10. Jul 12, 2020 at 4:21 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Why tow it? It’s fine to drive in 4x4
    is it stuck in 4LO?
    SR-71A likes this.
  11. Jul 12, 2020 at 4:28 PM
    YotaEmma
    Emmanuel
    @Sharpish it flashes 4LO but the rpm stays at 4 when going over 40.. and i don’t live to close to the dealer
  12. Jul 12, 2020 at 4:33 PM
    SD Quicksand
    Alex
    San Diego, CA.
    Too late now, but no charge towing is included with your ToyotaCare plan. You could call Toyota corporate and see if they will reimburse you. They probably won't but it's worth a try.
    You could use the no charge towing to have it towed to the dealership for inspection / repairs.
    zoo truck likes this.
  13. Jul 12, 2020 at 4:37 PM
    Sharpish
    Brian
    When you’re stopped and in neutral it won’t go from 4LO to 4HI?
  14. Jul 12, 2020 at 4:39 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    NO! It's not OK to drive it on pavement in 4X4. If he had done so he would have ruined any chance of getting warranty work done. People who give out this type of advice is why I won't buy a used 4X4.
    Getting stuck in 4lo is pretty common, with any 4X4 vehicle, not just Toyota. Putting the truck in reverse and backing up 10-15', then shifting to 4hi will usually get it unstuck. Sometimes I've had to do the back up, and pull forward dance 3-4 times before it would shift out of lo range.
    I also find it easier to shift from 4lo to 4hi and then shift to 2hi after I get moving. In theory it should go straight from 4lo to 2hi. But that requires the transfer case to do 2 things at once. I find fewer problems making the shift one step at a time.
    You also need to be in neutral with an automatic, or have the clutch fully depressed with a manual to make the shift out of, or into lo range. It also helps if the truck is rolling VERY slowly while making the shift. I like to stop on a slight incline, move the switch to 4hi and then let off the brakes slightly to let the truck roll. It only takes about 1/4 tire rotation to get the gears inside the transfer case to mesh. If you're at a dead stop and the gears aren't lining up properly it won't make the shift until you let the truck roll a couple of feet.
    JoshyP, BSFord, Twize and 1 other person like this.
  15. Jul 12, 2020 at 4:45 PM
    Sharpish
    Brian
    Get a grip Marshall. The steel gears in the transfer case and differential are way stronger than the grip one tire has on the pavement. I’m not suggesting 4HI is a good idea ALL the time but to limp home one time it’s not going to grenade the truck.
  16. Jul 12, 2020 at 4:46 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
  17. Jul 12, 2020 at 4:47 PM
    jmauvais
    NorCal
    ...stuff
    Just keep it at a low speed. No worries.
  18. Jul 12, 2020 at 5:26 PM
    YotaEmma
    Emmanuel
    I appreciate everyone’s help here!!!! My truck was stuck on 4Hi the whole time, I just got it into for 4Lo but it still won’t go down to 2WD!
  19. Jul 12, 2020 at 5:55 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    It isnt too bad troubleshooting the typical 4wd errors, ideally with a multimeter and a copy of techstream both, although either alone helps alot.
    An introduction to troubleshooting with a multimeter is here. https://www.tacomaworld.com/threads/4wd-actuator-troubleshooting-transfer-case-and-add.578262/ ,but the best thing to start with is techstream, because it helps to quickly narrow it down between the front, rear, and diff actuator. If you wanted to do this, ask for more help.
    HOWEVER, I would not try to diagnose or repair it yourself. Get it to a dealership. You can tow to the dealership, or alternatively if you want to, there are a few ways to force the truck into 2wd. You can remove the front driveshaft (between transfer case and front diff). You can also drive the front ADD (front diff actuator) into 2wd position by applying a few volts to the actuator with some temporary jumper wires... This isnt too hard, but it is not exactly easy... Let me know if you want instructions for this.
    I suggest calling toyota, I believe they will tow it from your house to the dealer, but they may not reimburse your previous tow if you tow it in now...
    Let me know if you want more help...
    Skydvrr and YotaEmma[QUOTED][OP] like this.
  20. Jul 12, 2020 at 6:00 PM
    BigWhiteTRD
    Ted
    If you succeeded in changing from 4hi to 4lo, the front (ADD) actuator is 95% likely culprit
    SR-71A and zoo truck like this.
