2wd gear ratio's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjewell, Jan 19, 2008.
  1. Jan 19, 2008 at 5:00 AM
    jjewell
    jjewell [OP] Member
    08 base 2wd
    getting the truck jan 2nd 08 will have the entire stereo down and rockin on friday the 4th.
    are the gear ratio's interchangeable between 2wd and 4wd tacomas? i have a 2wd 2.7l with the 3.31 rear gears and at some point i'd like to swap them out for the 3.73 or the 4.10
  2. Jan 19, 2008 at 12:06 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Don't know ? But why would you ?
  3. Jan 19, 2008 at 12:17 PM
    jjewell
    jjewell [OP] Member
    08 base 2wd
    i'd like to get better use of the really long gears on the 2wd's tranny. i don't drive on the highway much and i'm not real worried about gas mileage. if the truck had some lower gearing it'll be much quicker off the line and climb hills alittle better.
  4. Jan 19, 2008 at 12:28 PM
    concrete jedi
    Rochester N.Y
    Makes sense, i thought you may be pulling a trailer. I pulled one today, with load maybe a 1000lbs, and my 4:10's made it seem effortlessly. :D
  5. Jan 19, 2008 at 2:47 PM
    jjewell
    jjewell [OP] Member
    08 base 2wd
    no i just like to get from point a to point b as quickly as possible;)
  6. Jan 19, 2008 at 3:33 PM
    concrete jedi
    Rochester N.Y
    Maybe an X-runner would have served you better ?
