2wd lo mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacoswb, Dec 29, 2011.
  1. Feb 3, 2012 at 7:41 AM
    #41
    07tacoswb
    07tacoswb [OP] Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
    Radio Shack has them for $9.99 but I got mine off of ebay.
    #41
  2. Feb 3, 2012 at 7:59 PM
    #42
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    #42
  3. Feb 3, 2012 at 9:11 PM
    #43
    Doc McCoy
    Doc McCoy Untitled Offroad
    Calgary, Ab
    '98 TRD
    TRD Supercharger, TRD Headers, Borla Exhaust Custom Front & Rear Bumper, Allpro Sliders IVD Extended Front Coilovers, Total Chaos UCAs, TC Spindles, Alcan Rear Leafs, IVD Omega Rear Shocks Regeared to 4.88s, Front ARB Airlocker, Manual Hub conversion Also Mastercraft seats and sick cue ball shifters :D
    Is that a standard automotive style pinout? I work in industrial and you can often find some pretty crazy relays but the trick is to find an okay mounting solution. Even if you have to use two automotive relays it might be cleaner than rigging up a completely custom mount for a single relay. Personal preference though.
  4. Feb 3, 2012 at 11:38 PM
    #44
    landphil
    BC, Canada
    Tundra 5.7 mod
    Standard 5 pin automotive relays are SPDT, so you would need 4, but I'm considering that as well, just assembling a bank of four in a modular base. The biggest appeal to me with that idea is the ready availability for replacement if ever needed, but then again, I doubt I'd ever use 2lo enough to "wear out" a relay of any type.
    With that 14 pin one I posted, I'd probably mount it by the side with doublesided foam tape, and use high quality insulated female spade connectors, or solder and shrink each one individually. Or, maybe there are single bases available for them, I'll have to look now.:)
  5. Feb 3, 2012 at 11:53 PM
    #45
    landphil
    BC, Canada
    Tundra 5.7 mod
    Omron PTF14A is the base for the relay I linked to, it has 14 set screw type terminals, would make for a very clean end result, especially if there is room and enough harness length to use only the factory wires, ie, without extending them at all.
  6. Feb 4, 2012 at 7:39 AM
    #46
    07tacoswb
    Alan
    North Carolina
    I don't think they are long enough for that. a short wiring harness is easier to work with.
  7. Feb 4, 2012 at 11:06 PM
    #47
    tacomawv
    tacomawv tacomawv
    Richard
    WV
    sr5
    Wade sure-fit mats, afe dry filter
    Any pics of the wiring. Wiring freaks me out. The more info that i a have the better i feel doing wiring. Need this mod for the boat ramp. [​IMG]
  8. Feb 5, 2012 at 5:31 AM
    #48
    Doc McCoy
    Calgary, Ab
    '98 TRD
    Oops. I think i was thinking of a dual make SPST, but I'm pretty sure that won't work here. Carry on.
  9. Nov 8, 2012 at 3:12 PM
    #49
    BradyT88
    BradyT88 Well-Known Member
    So... I just tried the mod using 2 relays and one switch and it didn't work... When the switch is off everything seems to work fine. When I flip the switch on, the 4x4 and 4-lo lights just flash at me... Is it possible this doesn't work on Taco's with full traction control?
    EDIT: I was just comparing the two diagrams and I don't think they quite match up, well unless our relay diagrams are different. I'm going to play with it and see what I come up with.
    So when we flip the switch we want to ground the wires coming from the ECU and just disconnect the wires coming from the ADD right? I believe that is what your diagram using 2 swtiches shows, but the other diagram grounds the wires coming from the ADD.
    Yep I believe that was the problem. It seems to be working now. I just need to throw everything back together and take it for a spin to confirm.
  10. Nov 8, 2012 at 3:55 PM
    #50
    badger
    badger Well-Known Member
    07 SR5
    I haven't read through this thread. Is the switch to engage the ADD or lock it out? If it is to engage it, then you will need to move the truck a slight amount for engagement to actually happen. I have a switch for my ADD in conjunction with the manual Tcase, and this is how it works.
  11. Nov 8, 2012 at 4:12 PM
    #51
    BradyT88
    It is to disable it so that you essentially can obtain 2Lo on the factory Tcase.
    Yep it all works like it is supposed to, just not quite like I expected it to. haha
    So I have full traction control and I hate when the roads are slick and one of the tires slips when you try to leave from a stop sign. The TRAC engages by braking the slipping tire and the VSC engages by shutting off the throttle which will basically cause you to coast or sit there. Well when you shift into 4WD VSC turns off but TRAC stays on (basically ATRAC). I was hoping that by disengaging the ADD and shifting into 4Hi the VSC would basically shut off and I would have an electronic limited slip rather than an open diff in 2WD. Well when I disengage the diff and shift into 4Hi the VSC light stays off so I'm guessing it is still engaged... I wonder if I can find a simple wire in there that tells it to disengage when in 4WD.
  12. Nov 8, 2012 at 7:59 PM
    #52
    BradyT88
    In that diagram, are those swinging arm looking things switches? and if so what exactly activates them? I have being tearing throw the FSM's trying to understand what is going on and I'm a little confused there.
    Edit: A little closer, so I think the signal to disable the VSC is sent off in the junction box on the LG-B wire, so if I grounded that side of the wire it would turn the VSC off like 4WD does normally, but it would also power the ADD wire in the ADD. What exactly does that wire do? I know the motor engages the ADD, but what do the rest of the wires have to do with the ADD>
  13. May 17, 2013 at 5:26 PM
    #53
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
  14. May 17, 2013 at 8:25 PM
    #54
    BradyT88
    Waste of money until your tcase actuator dies :p haha I'll take that crawlbox though!!:D
  15. Jul 2, 2013 at 12:03 PM
    #55
    Raoul Duke
    Raoul Duke Well-Known Member
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    retrofit/bhlm, CB, System, color match grill, debadge, TRD wheels
    has anyone had luck doing this on a 12 - 13 year model yet?
    this is coming up on my list to get done
  16. Jul 2, 2013 at 12:53 PM
    #56
    Raoul Duke
    CJ
    Vancouver, Canada
    TRD O/R Pyrite
    cool, that what i suspected. did you do this mod PSU?
  17. Sep 4, 2013 at 6:23 PM
    #57
    jwiereng
    jwiereng Member
    This is how you properly spell engaged
  18. Sep 4, 2013 at 6:51 PM
    #58
    07tacoswb
    Alan
    North Carolina
    Oops, my bad! Thanks for correction, Dick! Did I spell that right?
    winkel likes this.
  19. Sep 4, 2013 at 7:17 PM
    #59
    Got2ryde
    Ryder
    Maryland
    Wow his 2nd post! Way to make friends.:rolleyes:
    Can anyone confirm if this works on 2012 OR? I would love to have 2lo, so many instances to use it. Nice write up/diagram.
  20. Sep 4, 2013 at 9:16 PM
    #60
    07tacoswb
    Alan
    North Carolina
    Next time just send a pm and tell me I made a mistake. Don't post on the thread and try to make me look stupid. May not have been your intent but that is the way it was taken!;)
