2wd lo mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacoswb, Dec 29, 2011.
  1. Dec 13, 2013 at 7:52 PM
    #101
    53flattie
    53flattie Well-Known Member
    Upstate, SC
    2006 DC
    2.5" OME
    Thank you. I'm very happy with it and I use it more often than I thought I would.
  2. Dec 13, 2013 at 8:15 PM
    #102
    Lordaca
    Lordaca Well-Known Member
    Melbourne, FL
    TRD SPRT DC LB 4x4
    Weathertech floor liners and wind deflector, OEM roof Rack, Wet Okoles seat covers, cb installed
    Sub'd going to have to do this as well.
  3. Dec 14, 2013 at 5:41 PM
    #103
    SierraMare
    SierraMare Well-Known Member
    Ted
    Alaska
    2001 TRD OffRoad Xtracab, stepside bed, 2.7 L, 5-speed manual
    ARE cap, BFG KO2 (LT 245/75R16), Front Bilstein 5100 with OME 2881 coils, Rear HS 3-leaf progressive AAL.
    So if I understand this mod correctly, not only would you be able to create 2-low, but when the switch is thrown you should be able to do "locker anytime" as well as have ABS disabled? If this is true I would say it's a "three-fed"... Great work, everyone - thanks!
  4. Dec 14, 2013 at 5:50 PM
    #104
    BradyT88
    BradyT88 Well-Known Member
    um... no. It is just 2Lo. I have separate mods for ABS disable and anytime locker.
  5. Dec 14, 2013 at 7:06 PM
    #105
    53flattie
    Upstate, SC
    2006 DC
    2.5" OME
    I haven't tried it yet, but I assume you would be able to engage the rear locker and disable the ABS when in 2Lo because the ECU thinks you're in 4Lo.
    I'll try it tomorrow and report back - I have been meaning to try it anyway and I don't know why I haven't gotten around to it yet...
  6. Dec 14, 2013 at 7:11 PM
    #106
    SierraMare
    Ted
    Alaska
    Thank you, 53... That was my thinking. I am anxiously awaiting your report...
  7. Dec 14, 2013 at 7:13 PM
    #107
    BradyT88
    Ah! Got ya. Yeah that would work that way. haha
  8. Dec 16, 2013 at 10:46 AM
    #108
    53flattie
    Upstate, SC
    2006 DC
    2.5" OME
    I just tested this and the rear locker will engage and the ABS will disable when in 2Lo.
  9. Dec 16, 2013 at 10:50 AM
    #109
    BradyT88
    Yep. Should be no different than with the switch since the ECU thinks you are in 4wd still.
  10. Dec 16, 2013 at 10:55 AM
    #110
    SierraMare
    Ted
    Alaska
    So, just to be clear, if the switch for 2-Low is on, and the 4WD knob is on 2-Hi, will:
    1. The ABS be disabled, and
    2. the Locker be functional when that switch is thrown?
    3. And when the 4WD knob is turned to 4-Hi you will still be in 2-Hi, and
    4. When the 4WD knob is turned to 4-Lo you will be in 2-Lo?
    Thanks for the help!
  11. Dec 16, 2013 at 11:13 AM
    #111
    BradyT88
    1. ABS will not be disabled by just flipping the switch. Under normal operations the only way to disable ABS is to engage the rear locker which can only been done while in 4Lo. So to disable ABS with the switch, you flip the switch then shift from 2wd to 4hi and then to 4lo and then engage the locker and ABS is disabled, but you are also now in 2Lo with the rear locker engaged. If you don't have the rear locker there is no way to disable ABS without an ABS kill switch via another mod.
    2. Again the locker is only functional when in 4Lo. Unless you do the locker anytime mod.
    3. Yes, although the computer thinks you are in 4Hi. The one difference if you front drive shaft is now locked in and spinning, whereas it is not in 2wd.
    4. Yes, again with the front drive shaft spinning.
    Note: If you have a front locker and engage it while using this mod, you will be in 3wd. The front driver tire will be receiving power from the tcase due to the design of the ADD that this mod bypasses.
  12. Jan 12, 2014 at 1:20 PM
    #112
    faller
    faller Active Member
    Vancouver Island
    Tacoma
    Bilstein 5100's @ 0.85, Toytec/Eibach coils, 1.5" AAL fbconvert's DIY AUX Input
    Two questions: When I click on the diagram for the DPDT relays in the first post, it says picture not found in database. Does anybody still have the diagram (original size) to post up? Second question is has anybody found made their own harness so we don't have to cut and splice all the wires? Thanks!!!
  13. Jan 14, 2014 at 4:59 AM
    #113
    53flattie
    Upstate, SC
    2006 DC
    2.5" OME
    When I click on the diagram, it opens for me - jut like it should??
    Re: the harness - I'm not aware of anyone making one. I considered making and selling them, but was asked not to
  14. Jan 14, 2014 at 5:45 AM
    #114
    07tacoswb
    07tacoswb [OP] Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
    I tell you what Tim. If you want to make and sell those harness's then go right ahead. It will help out a lot of guys with this mod. I put this diagram out to help fellow members with this mod. Never intended to have profit made from it. But I understand that this may be an easier way to install this mod and that takes time and money to put together. Good luck with the harness's.
  15. Jan 14, 2014 at 7:59 AM
    #115
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    I've been looking at this for a very long time, but it still scares me a little. If someone built and sold a kit with instructions, I'd gladly buy it; and be willing to pay a fair price for the convenience. Just my two cents FWIW.
  16. Jan 14, 2014 at 11:02 AM
    #116
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Anyone want to make and sell these wiring harnesses? I'm sure you could make a pretty penny selling them!!! Jus sayin'
    EDIT: I missed the posts above! Do it!
  17. Jan 14, 2014 at 12:11 PM
    #117
    BradyT88
    A guy PM'd me for some pics, I took some basic ones. I didn't want to dig into my wiring too much because there are a lot of them there from all the mods I have done, but they should at least help you locate the harnesses for wires in the diagram.
  18. Jan 14, 2014 at 1:39 PM
    #118
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
    I'm ready to do this mod. Id even buy the harness
  19. Jan 14, 2014 at 1:42 PM
    #119
    Toyotamudbogs
    Devin
    White Springs , FL
    Is the wire diagram the same one that's at the first part of this thread . ?
  20. Jan 14, 2014 at 2:35 PM
    #120
    53flattie
    Upstate, SC
    2006 DC
    2.5" OME
    Alan - the original poster - made a couple revisions to the wiring diagram while I was working on mine. I can't remember if he updated the diagram in the first post or not. You'll need the updated diagram for it to all work.
