2wd lo mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacoswb, Dec 29, 2011.
  1. Jan 14, 2014 at 2:44 PM
    #121
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Wish i could find Plugs and receptacles to make it a plug and play affair.
  2. Jan 15, 2014 at 8:25 AM
    #122
    merkman
    merkman Well-Known Member
    Etna, NH
    2012 green
    I'd buy one for sure, I need the mod, but too chicken to start cutting. Sell the switch too!
  3. Jan 15, 2014 at 10:02 AM
    #123
    07tacoswb
    07tacoswb [OP] Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
    The diagram that is loaded in the first post is the correct one. Shouldn't have any issues with this one.
  4. Jan 25, 2014 at 5:07 AM
    #124
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    I plan to do this tomorrow assuming I can come up with all the parts. I deal with similar relays at work all the time, but those all have 24vac coils, and I don't think 12vdc would quite trip it.
    for those who want to have a track to mount the relay bases to, look up "din rail" on google. it is typically sold in 4 foot pieces, but if you talk to the right person, they can cut you off a 4" piece which is plenty long for 2 relays.
  5. Jan 25, 2014 at 12:00 PM
    #125
    Smar969905
    Zach
    Deer Park, WA
    quick question for you 07tacoswb
    on your relays in the drawings, you just have numbers. do the numbers work out as 5 and 6 are common (separate poles of the relay of course), 3 and 4 are normally open, while 1 and 2 are normally closed? the relays I deal with are work are numbered completely differently, and have a base they plug into (idec relays). Thanks
  6. Jan 25, 2014 at 2:12 PM
    #126
    Black Pipe
    Black Pipe Well-Known Member
    sometimes life just isn't that easy
  7. Jan 31, 2014 at 10:12 AM
    #127
    07tacoswb
    Alan
    North Carolina
    With the relays that I bought 1 and 5 are closed and 2 and 6 are closed. 3 and 4 are open. When the relay is energized 5 and 3 are closed and 6 and 4 are closed leaving 1 and 2 open. This is what tricks the computer to thinking that the front diff is grounded so it shifts to 4wd not knowing that the front diff isn't engaged.
  8. Mar 1, 2014 at 5:42 PM
    #128
    Toyotamudbogs
    Toyotamudbogs Well-Known Member
    Devin
    White Springs , FL
    06 Tacoma 4x4, 4 door sr5
    Tintedwindows,Rockforfosgate amp 2 10" sub , fire dept radio,Rock sliders, Body Armer front Bumper, CB, 3'' EZ leveling kit, fog light mod, beep on lock mod, front duallys rigid led lights, rigid led flasher kit
    So if anyone can help me . I did this mod. And it will now only go in 4whdrive if I turn the switch on. And theres alot of beeping and chirpping goin on to . What type of relays are you gonna need for this mod ... normally closed or opened ? I used the ones from RadioShack. It looks kinda like the guy who uploaded a pic on here a few post up . There clear relays you can see through . I looked all over on the packet and don't see where it says what type of relay it is meaning the normally closed or opened relay.
  9. Mar 1, 2014 at 5:51 PM
    #129
    BradyT88
    BradyT88 Well-Known Member
    With the switch turned on and your selector in 2wd, turn the truck off and then back on. Is your 4wd light blinking?
    When the switch is on and the truck is in 4wd is it really in 4wd or does it just think it is?
    Just testing a couple methods to see which direction the relays might be working.
  10. Mar 2, 2014 at 2:05 PM
    #130
    Toyotamudbogs
    Devin
    White Springs , FL
    Well its snowing out there right now Ill get back to you after I check it out
  11. Mar 2, 2014 at 7:50 PM
    #131
    Toyotamudbogs
    Devin
    White Springs , FL
    well I have 3 pics I got tonight , are these relays the right ones to use for this mod.
    and this next pic the red wire that I have going to a ground location , is that where I need to ground it . Or is there a wire coming out of the other ECU plug that I need to tap into to ground
    And lastly this pic of the one green bigger wire and theres a small wire Do I have the right wire the thicker wire , Im not sure if I d have the right color of green wire here?
  12. Mar 2, 2014 at 7:58 PM
    #132
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    Looks like you have relays for 120v AC Coils not 12v DC
  13. Mar 2, 2014 at 8:11 PM
    #133
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Yup. AC relays won't work.
  14. Mar 2, 2014 at 8:47 PM
    #134
    Smar969905
    Zach
    Deer Park, WA
    I grabbed a couple relays from work that are designed for 24v ac on the coil. I tested it on the battery from my work van and that 12vdc tripped it. Pretty sure that these relays were really designed with coils to go 10-30V ac or dc. The relays are Rib (functional devices brand) 2401D, which is a 2 pole relay, so each relay controls 2 circuits simultaneously. That to me is easier than 4 individual relays. I have yet to put them in. I haven't even cut wires yet to put relays inline.
    Has anybody done this yet on any taco later than 09?
  15. Mar 3, 2014 at 6:35 PM
    #135
    53flattie
    53flattie Well-Known Member
    Upstate, SC
    2006 DC
    2.5" OME
    You can ground it anywhere - that part doesn't matter.
    Re: the green wire - the numbers on the wiring diagram correspond with the pins in the connector. Start at the top left, looking into the connector, and count across the top row, then continue on the left side of the next row. Use a wire that you know to be correct (like the red one) and make sure your numbering is right. The solid green should be #13. The green with black tracer should be #26.
    Here is where I used for ground: jahu7yhy_da9adf6c1d77ef1582ae625bf10409538ef5423e.jpg
  16. Mar 6, 2014 at 4:48 PM
    #136
    Toyotamudbogs
    Devin
    White Springs , FL
    Bout to go out and take another look.
  17. Mar 6, 2014 at 6:31 PM
    #137
    Toyotamudbogs
    Devin
    White Springs , FL
    OK so you know there's 2 green wires . A thick green wire and a small green wire.
    Well I had the thick green wire hooked up to the relays. So I decided to go and swap them around and see if it would work.
    So I put the ends on the small wire and hooked it io and I test drove it on the side of the highway a few mins ago and power braked it and it works . So a big thanks to Brady and 53flattie and the rest if the guys .
  18. Mar 7, 2014 at 5:39 AM
    #138
    53flattie
    Upstate, SC
    2006 DC
    2.5" OME
    Sweet - glad it's working!
  19. Mar 19, 2014 at 9:03 AM
    #139
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    Anybody selling kits yet? :D:D
  20. Mar 19, 2014 at 10:53 AM
    #140
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I'll sell you a kit. *Some assembly, wire routing, wire cutting, soldering required* **Wiring diagram included**
    Please see OP and go to local electrical supplier for wire and relays :cool:
    You can send payment to my paypal available via PM.
