2wd lo mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacoswb, Dec 29, 2011.
  1. Mar 19, 2014 at 11:46 AM
    #141
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    if anyone can source the plugs and receptacles id make a PnP kit
  2. Mar 19, 2014 at 12:46 PM
    #142
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    I may take you up on that.... :)
  3. Mar 19, 2014 at 12:58 PM
    #143
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    My first sucker... I mean Customer, yes, very good deal here!
  4. Apr 3, 2014 at 11:20 AM
    #144
    merkman
    merkman Well-Known Member
    Etna, NH
    2012 green
  5. Apr 3, 2014 at 11:28 AM
    #145
    07tacoswb
    07tacoswb [OP] Well-Known Member
    Alan
    North Carolina
    16 Tundra CrewMax XSP-X
  6. Apr 3, 2014 at 1:13 PM
    #146
    Smar969905
    Smar969905 ToyotaLover
    Zach
    Deer Park, WA
    96 Dodge 12valve cummins- mine, 16 T4R - wife's, 11 Taco - totalled
    You would have to get 2 of them, or get 1 of these for the relay, and the base that you can put wires directly into without needing to crimp anything.
    I deal with those types of relays at work a lot, except with 24VAC coils instead of 12VDC.
  7. Apr 3, 2014 at 4:06 PM
    #147
    Bogg
    Bogg Well-Known Member
    Surrey, Canada
    07 TRD Sport 4x4
    You'll need 2 relays and 2 bases. Both relays will be 2 pole. Can either terminate wires directly under set screws on relay bases or use stak ons
  8. Aug 7, 2014 at 10:13 PM
    #148
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
  9. Sep 14, 2014 at 11:52 AM
    #149
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    guess ill have to hit up junk yard to do my own PnP harness, cant find anything close that matches factory plug and receptacle.
    super g likes this.
  10. Oct 4, 2014 at 5:21 AM
    #150
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    If somebody can come up with a PnP kit, I think they'd have a gold mine. I just read the entire thread(again) and it seems no one has confirmed to have successfully done this on a 12 yet? Great write up. A perfect example of TW members helping members.
  11. Oct 4, 2014 at 11:21 AM
    #151
    Smar969905
    Zach
    Deer Park, WA
    Nobody has gotten this on anything later than 09 is my understanding. I gave it in mind to try on my 11, but it isn't on my to do list anytime soon.
  12. Oct 4, 2014 at 12:52 PM
    #152
    Pigpen
    Dan
    Northwest Montana
    These trucks are damned complicated when it comes to wiring IMO. This would be by far my favorite mod, but I haven't had the balls to even start buying parts. I'm sure it's less complicated than I think, but I don't even know what I'm looking at when seeing the diagram in the OP.
  13. Oct 4, 2014 at 1:56 PM
    #153
    Smar969905
    Zach
    Deer Park, WA
    Parts are easy. Some red and black wire, add a fuse thing from auto parts store, 4 pole double throw relay (or two DPDT relays) with 12VDC coil, and switch to mount in your truck in easy reach of where you drive, and likely a few female disconnect crimps. Put in add a fuse right on battery positive lead, splice to red wire. Put black wire onto negative of battery. Run black and red wires in through firewall into cab. Red wire to switch (if switch has a light, put black piece off of it, and splice to piece coming in from battery, and another piece that goes to other side of truck behind glove box) and another red from switch to other side of truck behind glove box. Red from switch to one point on coil of relay, black to other side of coil, as well as a couple points for normally open on relay.
  14. Oct 8, 2014 at 6:43 PM
    #154
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Just remove your front driveline and put it in 4lo. Done. :p
  15. Oct 11, 2014 at 11:16 AM
    #155
    Josh2755
    Josh2755 Member
    ON, Canada
    09 Regular Cab SR5 4x4
    trd offroad rims charcoal filter delete afe pro dry s drop in filter intake resonator delete lce header
    If someone makes a pnp kit for this count me in!
  16. Oct 11, 2014 at 11:20 AM
    #156
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    I'm with this guy ^^^
  17. Oct 11, 2014 at 11:50 AM
    #157
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    X2
  18. Oct 11, 2014 at 1:23 PM
    #158
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
  19. Oct 11, 2014 at 1:30 PM
    #159
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Not exactly.
  20. Oct 11, 2014 at 2:30 PM
    #160
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Not for me.
