2wd lower ball joint problem
Discussion in 'Suspension' started by Tour991, Jul 2, 2012.
  1. Jul 2, 2012 at 8:41 PM
    Tour991
    Tour991 [OP] Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    So what is the name and part number of the bracket that the lower Ball joint bolts on to that bolts to the lower control arm, mine is cracked and about to brake.
  2. Jul 2, 2012 at 8:45 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Pics? Usually bolts to the spindle, and BJ goes to the LCA.
  3. Nov 29, 2015 at 1:57 PM
    Master96Yota
    Master96Yota Active Member
    1996 red single cab rwd tacoma
    Stock:(...for now
    I also have this
    I know this is old but maybe someone can help me. I have a 96 2wd tacoma and the passenger side ball joint is worn out. The ball dropped out of the spindle and i cant find the exact part i need to replace it. All i need is the ball.
  4. Nov 29, 2015 at 2:01 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You need the entire ball joint. You can't just get the ball only. You have got a greasy mess there. On the plus side ball joint replacement is not too bad on our trucks. A bit of searching will show you how to swap them out.
  5. Nov 29, 2015 at 2:58 PM
    Master96Yota
    Stock:(...for now
    Do the replacement ball joints look exactly the same. Or will it look slightly different.
  6. Nov 29, 2015 at 3:15 PM
    koditten
    Kirk
    Central Michigan
    They will look just like the originals. Of course you need to get rid of some of that grease to see exactly what they look like.
  7. Nov 29, 2015 at 3:28 PM
    Master96Yota
    Stock:(...for now
    Yea that picture is from some time ago. The grease is gone now but do you know where to look or what to search because everything i see doesn't have the same bolt pattern or is from a different year. I search things like"96 tacoma lower ball joint" and cant find anything that looks alike.
  8. Nov 29, 2015 at 6:06 PM
    Tour991
    James
    South Reno/Tahoe
  9. Nov 29, 2015 at 6:14 PM
    Adventurer_Alex
    Adventurer_Alex Generic mall crawler
    Alex
    AZ
    2013 Nissan XTERRA
  10. Nov 29, 2015 at 6:37 PM
    Master96Yota
    Stock:(...for now
    Thanks alot guys. I got it now.
    Adventurer_Alex likes this.
  11. Apr 10, 2016 at 11:45 AM
    Low lyph tocoma
    Low lyph tocoma New Member
    Brandon
    2wd tocoma
    Dropped
    Yo anyone on here can help me outt? I am looking for the part that connects to the lower ball joint then bolts on to the lower control arm I have be been looking every where an I can't seem to find the one
  12. Apr 10, 2016 at 3:13 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Don't even know what it would be called, although I do know what you're talking about. It is definitely something you can find at the dealer though, maybe even the junkyard.
  13. Apr 14, 2016 at 11:44 AM
    Tour991
    James
    South Reno/Tahoe
    I was never able to find one. So I just had them welded. I'v been running them for 4 years now. No problem at all.
  14. Apr 16, 2016 at 1:29 PM
    Low lyph tocoma
    Brandon
    2wd tocoma
    Dropped
    Yeaah I thinkk but I was trynna find it on here so I don't have pay so much at the dealer
