?2wd to 4wd?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Itchyfingaz33, Oct 26, 2009.
  1. Oct 26, 2009 at 10:58 PM
    Itchyfingaz33
    Itchyfingaz33 [OP] Member
    Joshua
    817
    01 PreRunner SR5
    how would i go about making my 01 prerunner into a 4wd? can it be done? and how much money would be invilved?
  2. Oct 26, 2009 at 11:08 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    yes it can but you might as well buy a new truck.. it would be a lot of moolah
  3. Oct 26, 2009 at 11:15 PM
    Itchyfingaz33
    Joshua
    817
    01 PreRunner SR5
    mhm ic. lol after i posted this i started reading some other related posts and found one almost exactly like mine heha. but thanks for the reply. :B i guess ill have to do some more browsing on jusy how much moolah
  4. Oct 26, 2009 at 11:35 PM
    All Locked Up
    All Locked Up New Member
    For a first gen its actually not that expensive from what I've read. You can also do quite a bit of the swap with aftermarket parts instead of OEM.
    When you're done, you should have a very capable 4x4.
  5. Oct 26, 2009 at 11:39 PM
    Itchyfingaz33
    Joshua
    817
    01 PreRunner SR5
    so what all do you think i need?
    Transmission w/ transfer case
    4WD read drive shaft
    front CV shafts
    Front diff...
    from what ive read thats what i think i need...where would be a place to find out what all i needed. i dont want to mess it up lol.
  6. Oct 26, 2009 at 11:42 PM
    Itchyfingaz33
    Joshua
    817
    01 PreRunner SR5
    im new to all these terms and lingo. so im kind of just learning and doing my own research. but i just want to get the right info.
  7. Oct 27, 2009 at 12:30 AM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    If you do try the swap I'd go solid axle. It would be alot stronger and the way to go. and maybe easier.
  8. Oct 27, 2009 at 6:19 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If all this is NEW to you....and you're not even sure about the lingo....then this project is probably something you should not attempt.
    Putting 4WD onto a 2wd is not an easy job. It'll be expensive, it'll require a lot of time, and a lot of knowledge or it won't be done accurately.
    I've never done it - but I can tell you...it'll be more than just slapping in a transfer case, driveshaft, & front differential. There are other components that would need to be changed that you wouldn't even think of.
    You're better off selling the Prerunner and buying a 4WD truck. At that point, you can learn and do your own lift kits and modifications (smaller things) that'll get you up to speed with the lingo & knowledge.
  9. Oct 27, 2009 at 8:56 AM
    slickyd
    slickyd Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    +1:turtleride:
  10. Oct 27, 2009 at 8:57 AM
    Itchyfingaz33
    Joshua
    817
    01 PreRunner SR5
    well not the work just forums and stuff im new to. i had an 88 toyota pickup 4wd that i did some work too like transmission and stuff but swaping or making a 2wd into a 4wd im just trying to gain some insite on. :) thanks for the replies and info guys!
  11. Oct 27, 2009 at 1:28 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    I get wanting to make your truck bigger and better.
    this site might have more info for you.
    But keep in mind you can sell your truck and buy a 4WD for allot less.
    You might even break even.
  12. Oct 27, 2009 at 2:09 PM
    Janster
    Jandy
    Lancaster, PA
    Not saying that you couldn't do it..... The first thing that came to mind was - *in over your head*.
    I've seen a lot of guys jump into BIG projects similar and after a while, they start loosing interest because it's taking them too long and costs too much. After seeing their rig sit in their garage for a year or more....they realize they'll never finish it. Then - they start selling off their stuff and starting with something else more managable.
