2WD with LSD - why? when?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDsport253, Sep 7, 2011.
  1. Sep 7, 2011 at 11:15 AM
    TRDsport253
    TRDsport253 [OP] Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    I have the TRD sport with the mech LSD. Is it off road worthy? And is LSD better than open diff or just the same?
  2. Sep 7, 2011 at 11:16 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    It's better then open diff.
    It's not anything compared to a selectable locker though..but it's still better then open.
  3. Sep 7, 2011 at 11:17 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    With momentum is will do ok "as will open" but if you slow down or try climbing steep hills slow it's not going to help much but it is better then open/open
  4. Sep 7, 2011 at 11:18 AM
    Us3r
    Us3r Reading...
    Socali
    98 Tacoma Std. 2RZ-FE 2WD
    Axle wrap mod (Shackled), 140 Amp Alternator & Wires, HID Headlights, Brush Guard Grille, Hella 550 Driving Lights. |Saving:Total Chaos.|
    lsd is better than open diff and is kinda in the middle of being off road to street applications.
    open diffs will allow one wheel to spin freely while the other is engaged. In an offroad applications, open diffs can get you stuck if both rear wheels are not on the ground.
    LSD limited slip diff. is just that, it limits the slip of a wheel not being in traction. On the street this can be kind of jarred when making a tight corner. You can sometimes feel clunking or one wheel slightly locking up.
    Locking diffs allows the user to lock up the differential making both wheels spins.
    having LSD is a plus over an open diff and should come in good use on an off road application, just not too extreme.
    Locker would be best.
  5. Sep 7, 2011 at 11:18 AM
    Manwithoutaplan
    ID
    it is ok but i would rather have locker :D. SOon lockers and gears :D.
  6. Sep 7, 2011 at 11:23 AM
    TRDsport253
    Edgewood, Wa
    2021 TRD sport 4x4
    Thanks everyone I understand LSD now.
  7. Sep 7, 2011 at 12:03 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    That was a sweet video Christian!
  8. Sep 8, 2011 at 12:33 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    1:25
    Another reason why lockers are fun :spy:
    Nice video though!
