2x4 upgrade to 4x4 with ESC can it be done
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TxRoo, Aug 24, 2014.
  1. Aug 24, 2014 at 9:31 AM
    TxRoo
    TxRoo [OP] New Member
    08 PreRunner SR5
    I am very new to the Toyota world, but would not trade my Tacoma for anything. I am about to be stationed somewhere with lots of snow and in the mountains. I currently have a 2008 Prerunner SR5 TRD off road 2x4. I am curious if anyone has known, or knows if one can change the transmission and front axel/suspension to a 4x4? If so is it better to go through Toyota to have the mods done and pay the extra costs? Or through a third party vendor?
  2. Aug 24, 2014 at 9:33 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I would think it would be cheaper to just sell your truck and buy a 4x4. Anything can be done for a price, but that is a lot of work.
  3. Aug 24, 2014 at 9:40 AM
    cotrailruns
    cotrailruns Well-Known Member
    Luke
    Colorado
    14 TRD Offroad
    Icon, Dakars, LR UCAs, Relentless Fab Front Bumper. All Pro Pack Rat, RTT. SOS Sliders
    You are better off selling it and getting a 4x4 model, if you live some where now where most trucks are 4x2 you are better off doing this before you move....
  4. Aug 24, 2014 at 9:42 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^This. If you intend to just install factory parts from a 4x4, unless you can find a donor truck, the part costs will be prohibitive (tranmission, transfer case, front diff, driveshafts, ECU...)
    On the other hand, if you are going all-out with solid front axle, Marlin crawlbox, etc., then a PreRunner is a good place to start. Take the truck to a 4WD speciality shop that does SAS conversions. Budget about $8000.
  5. Aug 24, 2014 at 9:49 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Toyota will not do the conversion cheaper and better to buy a factory 4x4
  6. Aug 24, 2014 at 9:55 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Just nail 2 of these together and you'll have a 4x4!
  7. Aug 24, 2014 at 9:56 AM
    arock
    arock Well-Known Member
    MD
    2020 Cement TRD Off-Road
    Not sure where you guys are getting your pricing but the swap can be done using used parts for ~$3000ish. Used trannies are on eBay for ~700, fj transfer case for ~500. Axels, 4wd hubs front differential, and random bolts/bushings I haven't look too much into so I can't say the pricing for those. Check this out if your interested in doing the conversion http://www.rocksolidtoys.com/forum/showthread.php?t=396
    Its actually not too complicated, more time consuming than anything. Hardest part I see is the custom cross member for the transmission since I don't do welding. But I'm sure it wouldn't be hard for metal shop to fab up.
  8. Aug 24, 2014 at 11:07 AM
    KenLyns
    Belly of the Beast
    If TxRoo can't do it himself, figure 8 hours shop labor which would be $800-$1000 depending on location. So $4000 total.
    Cheaper to sell the PreRunner and buy a used 4x4 of similar vintage.
  9. Aug 25, 2014 at 7:30 AM
    Surfinpig
    Surfinpig Well-Known Member
    Eric
    Philadelphia, PA
    10 2.7 4x4 SR5
    Avid Offroad light bar, trd skid plate, are cap, billy 5100's
    Snow tires and tire chains, problem solved
  10. Aug 25, 2014 at 7:33 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Not quite, you need a 1/2 plywood rip between them. ;)
  11. Aug 25, 2014 at 8:00 AM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    It would be much cheaper and much simpler/easier to just sell it or trade it and get a 4x4.
    IF you MUST keep your current truck than a rear locker and snow tires will get you about anywhere a 4x4 w/o a locker would. Chains as a backup wouldn't hurt either.
    Your biggest limiting factor with your current truck is lack of weight over the drive wheels. Sand bags or similar to add weight over the rear axle would be the cheapest and simplest solution.
  12. Aug 25, 2014 at 8:14 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    I agree. I know several people who get around up here in Winter with 2WD trucks; good set of dedicated Winter tires and some sandbags in the bed over the rear axle. Not as convenient as 4WD, but with some situational awareness and a little finesse, they get around fine.
    EDIT: I should add if you're convinced you need 4WD, or just simply want the convenience of 4WD, you should sell your current truck and get a 4WD before you PCS. 2WD trucks don't sell very well here and you'd likely take a hit on true value.
  13. Aug 25, 2014 at 8:40 AM
    jpop8807
    jpop8807 Well-Known Member
    Josh
    Fort Hood
    2011 Prerunner TRD 2wd
    I'm in the same boat as you. I emailed rock solid toys. They said all together you would be looking at around 5-8000 this is parts and labor depending how cheap you can find the parts for it is doable for as little as 4k. Vancity did this conversion. You'll have to search him. He has a gold looking tacoma. The only feasible reason to do this is if you are like me. You've already beaten up your pre runner, and you owe much more then it is worth. I owe about 18000 on a 2010 with 120000 miles on it KBB said my truck is only worth about 9grand so I'd be better off going convert then going that far upsidedown on a trade.
  14. Aug 25, 2014 at 10:22 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    It can and has been done. THere is a thread on here somwhere with it done and lots of pics.
    Swap out the front hubs to 4x4. front dif, fj transfer case, shorter trans from the 4x4, new crossmember, new ECS, front axles. I think thats about it.
  15. Aug 25, 2014 at 10:24 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    http://www.tacomaworld.com/forum/2nd-gen-builds/23170-building-beast.html
    From the man himself
  16. Aug 25, 2014 at 10:27 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
