3 1/4" ride hieght difference between back and front. Bilstein setting?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Black Sheep, Feb 11, 2011.
  1. Feb 11, 2011 at 6:35 AM
    Black Sheep
    Black Sheep [OP] Well-Known Member
    Jeff
    Pittsburgh, PA
    2011 Black Dbl Cab TRD T/X Pro
    6" Pro Comp Suspension lift with Pro Comp leveling kit, Bilstein 5100's, Full leather interior with seat heaters, Go Rhino step bars, Sony XNV-770BT Head Unit with NAV, DVD, XM and Blutooth, Tonopro toneau cover, Tinted windows, Black mesh grille, Projector headlights with HID lows, HID fogs, Crystal Eyes rear LED taillights, Weathertech mats front and rear
    Ok. My truck goes in tomorrow to have the front bilsteins installed. I had the tsb done a couple of weeks ago. My question is, should I still set the bilsteins at 1.75" or go to the 2.5"? With the 3 1/4" difference, would the 2.5" be better? I don't want to have these installed and then regret my choice either way.
  2. Feb 11, 2011 at 6:38 AM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    pic of truck from side......now
  3. Feb 11, 2011 at 6:45 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    the rear TSB wil settle down a bit maybe an inch.
    go with 0.85" if you want to maintain the stock raked with the back higher, i did this because i tow and when i do it sits level,
    go with 1.75" for a level look. but load the bed or tow and you might be nose high
    2.5" and youll be nose high
  4. Feb 11, 2011 at 6:51 AM
    Benbro
    Benbro Member
    Ben
    Molalla,OR.
    06 SR5 Longbed
    Bilsteins,Wheelers AAL, Westin BullBar,Axcess Ipod Port,265 Toyo's, Snugtop Cap,K&N Cold Air Intake,Weather Tec Protection
    Crank them all the way up!
    Don't pay any attention to the knuckle heads that whine about the ride.
    The speed bump bounce is equal between the two axles.
    And the leveled,balance look is sharp!
  5. Feb 11, 2011 at 6:54 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    x2, all the pics of 2.5" front, TSB rear I've seen are nose-high.
  6. Feb 11, 2011 at 7:06 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I vote 1.75 setting as well. 2.5 will be nose high. My truck isn't nose high at 2.5, but I have an AAL with more lift than the TSB AAL. Also, at 1.75 you shouldn't have any trouble keeping your alignment in specs. I'm at 2.5 and I need new UCAs because I can't get enough caster on the passenger side.
  7. Feb 11, 2011 at 7:15 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Does it really matter? These are adjustable. Keep it level then crank it down if or when the rear settles..
  8. Feb 11, 2011 at 7:21 AM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    Park on level ground and put your jack under the front and raise it to the various settings. Then you'll see how it'll look.
    For me 0.85 plus TSB gave a very slight rake and with weight in the bed it's level.
  9. Feb 11, 2011 at 7:24 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    What might matter more here is if you go 2.5, you'll most likely need UCAs to get the caster to tolerable setting or have twitchy sketchy handling on uneven surfaces or grooves in the road or when it's windy. I'd say go 1.75 in your case if you want a little rake and not need more parts to make it drive right....and it's a bit of a hop to get in set on 2.5 with 32" tires and no step rails if that matters, I don't mind it myself and don't haul stuff or tow often enough for nose high when loaded to matter. Mine has 1.25" of rake with 1.5 AAL on 3 leaf pack and front set on 2.5 with the LR UCAs to have caster correct..........and if you are 4x4 you may have vibe issues if going to 2.5.
  10. Feb 11, 2011 at 7:24 AM
    TexasTacoma37
    Yeah but it's a pain to take them off, re-compress the springs, adjust, put them back on, and get an alignment. Better to get it right the first time.
  11. Feb 11, 2011 at 7:30 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    1.75 with tsb is just about perfect level on my 4x4 dc or.
  12. Feb 11, 2011 at 7:34 AM
    kramer2k
    kramer2k Well-Known Member
    Jacksonville, FL
    08 DC PreRunner TRD OR
    +1
    I'm at 22" center hub to fender in the front and 22.5" on the rears.
    1.75" is the way to go
  13. Feb 11, 2011 at 7:38 AM
    TexasTacoma37
    Pics of 1.75" front, TSB rear can be found in my build if anyone is interested. :cool:
  14. Feb 11, 2011 at 8:27 AM
    Deathbeard
    Deathbeard Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    X2
