3/1 Leveling Lift Kit vs an actual lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gdesiato, Aug 15, 2017.
  1. Aug 15, 2017 at 9:18 AM
    gdesiato
    gdesiato [OP] Active Member
    Greg
    2017 Quicksand Tacoma
    non yet
    So I'm new to trucks in general i have always had sports cars and crotch rockets, yes let the noob jokes begin! But i recently got a 17 taco off road in quicksand. I was trying to decide on a leveling kit vs an actual lift kit. OTHER then the price difference what are the pros and cons and what kits should i look at?
    Also I'm all for the general a**holeary of forums so don't hold back the sarcasm!
  2. Aug 15, 2017 at 9:24 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    kings/icons/fox all racing shocks. there top dogs when it comes to suspension lifts and for a good reason. but depending on what your doing with your truck they might not be necessary. bilstien/ome they have pretty nice entry level off road shocks that will get the job done on most occasions. also racing shocks have to be rebuilt and if your not about that life then maybe not the choice for you. then theres spacer lifts which yeah... ill just leave that there.
  3. Aug 15, 2017 at 9:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Why do you think you need any lift?
    Is it a poseur craving, or do you already know of an incompetence the truck has that will be cured by a lift?
  4. Aug 15, 2017 at 9:25 AM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    "leveling" kits is a fairly generic term. It just means you've used a lift to remove the factory rake of the truck.
    The two "types" are spacer lifts vs suspension lifts.
    Spacer lifts involve using the stock suspension and a spacer to achieve the lift. I believe the biggest drawback is that you can bottom out the strut before you hit the bump stops and cause damage to the shock.
    Suspension lifts replace your stock suspension components. These can be in the form of spring and shock combinations, or adjustable coil overs.
    99% of the people here will recommend a suspension lift vs a spacer lift.
    hunter357mag likes this.
  5. Aug 15, 2017 at 9:28 AM
    gdesiato
    Greg
    non yet
    I was planning on doing bigger tires for some moderate offroading, nothing to crazy but the guys i work with said i should do some sort of lift first then bigger tires.
  6. Aug 15, 2017 at 9:29 AM
    gdesiato
    Greg
    non yet
    thanks! now at least i know the proper terminology! And you advise is appreciated.
  7. Aug 15, 2017 at 9:37 AM
    Midknight
    Western Canada
    2018 TRD Off-Road
  8. Aug 15, 2017 at 9:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    Ignore them. Spend more time here.
    255 x 85 x 16 or 255 x 80 x 17 will fit your stock wheels, no rubbing on stock suspension, look sharp, and serve you well off road.
    Some folks will claim they are too skinny. The folks running them have no issue. You can find a couple of long threads on it by doing a bit of searching.
    Oh yea, you'll get ground clearance 'lift' by running that significantly taller tire. Play w/the tire calculator to see what's up.
    offthewallsurfer and Midknight like this.
  9. Aug 15, 2017 at 9:39 AM
    Midknight
    Western Canada
    2018 TRD Off-Road
    Also just a word of caution. A lift alone will not allow you to run larger tires. Your wheel choice (offset etc.) will also determine how much you will rub, and where you will rub.
    You can run skinny 33's using stock OR wheels though (255/85/16), but if you plan on going wide (285's or something like that) you will most likely have to do the cab mount chop (CMC).
    Clearwater Bill likes this.
  10. Aug 15, 2017 at 11:25 AM
    gdesiato
    Greg
    non yet
    Great idea thanks, any recommendations on brands for that size and where to get a good price?
  11. Aug 15, 2017 at 11:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  12. Aug 15, 2017 at 12:04 PM
    gdesiato
    Greg
    non yet
    i was trying to find a thread for the bilstien/ome kit i need for the gen 3, can anyone help here?
  13. Aug 15, 2017 at 12:06 PM
    offthewallsurfer
    offthewallsurfer Well-Known Member
  14. Aug 15, 2017 at 12:08 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    When did lifting 3" in the front and 1" in the rear become a "leveling kit" :laughing:
  15. Aug 15, 2017 at 12:16 PM
    coopcooper
    alberta canada
    smitty99 has a dank write up for bilstiens on the 3rd gen
  16. Aug 15, 2017 at 12:17 PM
    coopcooper
    alberta canada
    factory rake is 2 inches isn't it. there for 3-1 would make it level
    tjpratt likes this.
  17. Aug 15, 2017 at 12:35 PM
    bullaculla
    Da big big island!
    No :laughing: A leveling kit used to be just a 1" spacer in the front to level the vehicle. Spacers for 3" in the front and 1" in the rear is just a shitty lift kit.
    EatSleepTacos likes this.
  18. Aug 15, 2017 at 12:38 PM
    coopcooper
    alberta canada
    I guess lol. well its a lift and a leveling kit in one then o_O
    bullaculla[QUOTED] likes this.
  19. Aug 15, 2017 at 12:38 PM
    bullaculla
    Da big big island!
    Yeah, just semantics :D
  20. Aug 15, 2017 at 6:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That drives me nuts when people say that! Leveling is when the front is lifted to match the rear and the rear isn't touched. More common on full sized trucks with 3+" of rake.
