3/4" lift spacers with 5100's Y/N??????
Discussion in 'Suspension' started by brutalguyracing, Mar 29, 2010.
  1. Mar 29, 2010 at 6:30 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    can i use 3/4" lift spacers with the 5100's @ 2.5 to get the full 3" lift???
    oh i have stock springs.....
  2. Mar 29, 2010 at 6:30 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    1/2 - 3/4 will be fine
  3. Mar 29, 2010 at 6:31 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    i would guess it would be a big no.
  4. Mar 29, 2010 at 6:33 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    why so, it wont enough to bottom the shock before the IFS hits the front suspension. Wait does the adjustments on the 5100s limit uptravel? The OME kit supplys .5 inch spacers to get a full 3 inch.
  5. Mar 29, 2010 at 6:34 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
    Thats why I didn't think it'd be a big deal...
  6. Mar 29, 2010 at 6:34 PM
    98_Mud_bug
    lucedale Ms.
    a 3" spacer with the billies set at 2.5? thats gonna be more than 3 inches of lift wont it?
    edit: sorry i read it wrong.. im not paying attention. i thought he said a 3 or 4" spacer. not a 3/4 inch spacer
  7. Mar 29, 2010 at 7:47 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    its a 3/4" lift spacers which means its like 1/2" or 3/8" thickness of spacer = 3/4" lift
  8. Mar 29, 2010 at 11:17 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    I run a 3/8 spacer on my driver side with 5100s to compensate for the driver side lean. Some people use a 1/4 inch spacer, but my truck leaned so badly I needed a 3/8 inch spacer to make it level.
  9. Mar 29, 2010 at 11:20 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
    It'd be fine...it won't hurt anything honestly
  10. Mar 31, 2010 at 1:11 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    hey did you have to compress the spring to install the 3/8 spacer????
  11. Mar 31, 2010 at 9:15 AM
    sincitytaco
    Las Vegas
    Um.........Well yes because you will have to install longer studs to accomodate the spacer.
  12. Mar 31, 2010 at 9:57 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    If You are useing 5100s set at 2.5" with stock springs, then you can use a 3/8" thick topspacer to get you the full 3" of lift. A 3/4" thick one would be a bad idea.
  13. Mar 31, 2010 at 10:50 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    thanks guys
