3.4L losses power under heavy load
Discussion in '1st Gen. Tacomas (1995-2004)' started by TODEOTA, Dec 3, 2012.
  1. Dec 3, 2012 at 11:37 AM
    TODEOTA
    TODEOTA [OP] Well-Known Member
    Jake
    Lewiston, ME
    2000 SR5 4x4 extra cab
    Horn upgrade, 2.5" Rough Country lift going in soon
    I've got a problem in my 2000 5 speed SR5 3.4L. Normal city driving, there is no issue that I can tell, but but if I try to accelerate a little more aggressively (50% or more throttle), my engine loses acceleration power and if I try to climb a steep hill, I have to downshift to 2nd and my top speed would top out at 20MPH. When I accelerate onto a highway, I can only give it about 30% or so throttle without losing power. If I am in 3rd, and I press the gas too far, it bogs down and stops accelerating. 4th or 5th under full throttle, I start slowing down and the engine sounds labored.
    List of any ideas what could be my issue?
    PS. I have to run with 91 octane to keep it running better. 87 octane it rattles like crazy and there is not enough power for the highway.
  2. Dec 3, 2012 at 11:43 AM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    Bump for you
    Dirty maf
    Clean your tb
    Old plugs
    The usual stuff already checked?
    What have you done to it so far?
  3. Dec 3, 2012 at 11:44 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  4. Dec 3, 2012 at 2:53 PM
    TODEOTA
    Jake
    Lewiston, ME
    I cleaned the MAF since I keep getting a code for it, Still do... but it didn't effect much last time
  5. Dec 4, 2012 at 12:30 PM
    luckydogie
    luckydogie Member
    01 prerunner
    No expert but i would replace fuel filter and then check cat.
  6. Dec 4, 2012 at 12:50 PM
    Sittingbull2
    Sittingbull2 Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    may need to just get a remanufactured MAF sensor. They can go bad. Pull a plug and make sure you have the right plugs in there. NGK= BKR5EKB-11 and Denso= K16TR11. How long has it been since you put a new fuel filter on it? Wix about $23 OEM I don't even know. If fuel filter has been replaced recently check fuel pressure rent fuel pressure gage or buy one. You can also check if your fuel regulator is working also when checking for fuel pressure. Could also be a coil going bad. Simple things first. before you start throwing $ bills at it. PDF's attached might help you a little
  7. Dec 4, 2012 at 5:42 PM
    TODEOTA
    Jake
    Lewiston, ME
    Thanks.
    I've only had this truck for 5k miles.
