3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. May 18, 2020 at 5:17 PM
    #1981
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    That's nice to know, it might have been the change from boosted to non boosted and back again, too many changes for it, after 200k boosted.
  2. May 18, 2020 at 5:41 PM
    #1982
    eon_blue
    Azusa, CA
    Anything you can do to mitigate the added heat that the supercharger creates is probably the best thing. Since these superchargers don't have built in intercoolers (like the 2nd gen Tacoma superchargers have), we're subjected to heat soak which kills performance and if too extreme can cause damage.
    Best way to cool the blower temps is by using methanol injection, really it's the only way. Make sure your grill isn't blocked, cooling system is working optimally, etc.
  3. May 18, 2020 at 5:59 PM
    #1983
    1997tacomav6
    Denver
    I don’t think so, but if your head gasket was weak with a problem boosted would help it on its way
  4. May 18, 2020 at 6:02 PM
    #1984
    TacoBike
    Mason
    Yeah that makes sense, probably pushed it over the top.
    1997tacomav6[QUOTED] likes this.
  5. May 18, 2020 at 6:03 PM
    #1985
    TacoBike
    Mason
    Wish I could do methanol, smog and I still owe my father for part of the truck and until I have the truck in my name, I've been told no methanol or 7th so larger injectors and fuel pump are somewhere in the future after this.
    eon_blue[QUOTED] likes this.
  6. May 18, 2020 at 6:05 PM
    #1986
    1997tacomav6
    Denver
    How about methonal setup with just water?
  7. May 18, 2020 at 6:25 PM
    #1987
    TacoBike
    Mason
    You're not being serious, right?
  8. May 18, 2020 at 7:12 PM
    #1988
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    Meth injection with just water is a pretty normal thing if you're just after cooling.
  9. May 18, 2020 at 7:14 PM
    #1989
    1997tacomav6
    Denver
    Some states don’t allow methonal, probably Cal.
    I’m serious, you can spray water by itself.
    For cooling on hot days and changing the air mixture to a denser mixture.
    Before the methonal kit I would have huge swings in power from a 100 degree dry air,
    But on a cool foggy or rainy day I would have fantastic power huge difference.
    Hot air is thin, cold damp air is heavy.
    Water injection would drop the supercharger temps by 100 degrees
    You would have heavier cooler dense air.
    You would use a much larger nozzle maybe a #6 compared to a 1 or 2.
    Now my power is pretty much the same at 100 degrees as at 60 degrees
  10. May 18, 2020 at 7:18 PM
    #1990
    austinmtb
    Austin
    Southern Oregon
    How are you watching your supercharger temps?
  11. May 18, 2020 at 7:20 PM
    #1991
    1997tacomav6
    Denver
    You can shoot it with a lazer heat gun.
    I can put my hand on my supercharger anytime and it’s never to hot to pull it back.
    Before the methonal the supercharger was like a heat sink
    austinmtb[QUOTED] likes this.
  12. May 18, 2020 at 7:25 PM
    #1992
    austinmtb
    Austin
    Southern Oregon
    Gotcha.
    Just out of curiosity it would be nice to have a sensor in the supercharger so I could see exactly how much my water/meth spray is cooling it. It's obviously working though because my pulls are way more consistent than without it.
  13. May 18, 2020 at 7:26 PM
    #1993
    TacoBike
    Mason
    Oh I didn't realize you can run 100% water, at that point why not do methanol too though. Also cali smog but hate it so if you do it right they might not even notice. But yeah cali laws suck.
  14. May 18, 2020 at 8:08 PM
    #1994
    1997tacomav6
    Denver
    Depending on the truck and motor it might or might not need the methonal, the added fuel part.
    Not all supercharged Tacoma need the added fuel, some do, some don’t. Mine doesn’t unless I use
    a 2” , 2.1” pulley.
    If I run a stock pulley or a 2.2 pulley I don’t need the added methonal fuel, the stock system does just fine and
    If I used methonal with the stock pulley or 2.2 pulley I would run rich.
    But I could run just the water if I wanted too with the larger pulleys.
    TacoBike[QUOTED] likes this.
  15. May 18, 2020 at 8:36 PM
    #1995
    TacoBike
    Mason
    Might run this by but somehow I don't think he's going to be much happier with it.
  16. May 19, 2020 at 3:34 PM
    #1996
    Ccrowe323
    Ccrowe323 Well-Known Member
    Cory
    Florida
    2001 Tacoma 3.4 DC 5speed TRD OR
    Figured this would be the place to post this since a lot of you have done this with the supercharger.
    Anyways, currently needing a new crank pulley. I don’t care for the “added performance” of the LCE lightweight pulley As I don’t believe it really does that much but more so that it’s only $190 (and made by LCE) vs $600 oem is what my local Toyota quoted also found for $400 on Toyota oem direct but still pretty damn expensive.
    That being said my question is:
    I’ve heard a rumor on here that adding a lighter crank pulley can in turn cause excessive wear on internals as not having the vibration dampening of a heavier pulley. This sound like a plausible idea but also sounds kinda ridiculous so figured I would ask if there’s any actual proof to this or if it’s just a skeptical idea
    I think either way I will be buying the LCE as I don’t really have another option and it’s quality.
    btw, I am not supercharged if that matters
  17. May 19, 2020 at 5:04 PM
    #1997
    1997tacomav6
    Denver
    X2
    I would like to know this question too from somethat that has one installed
  18. May 19, 2020 at 8:13 PM
    #1998
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Listening...
  19. May 20, 2020 at 7:20 AM
    #1999
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
  20. May 20, 2020 at 7:24 AM
    #2000
    1997tacomav6
    Denver
