3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. May 20, 2020 at 7:27 AM
    #2001
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    So what makes it worth it? Even just buying the supercharge at $3500 seems like a high price.
  2. May 20, 2020 at 7:30 AM
    #2002
    1997tacomav6
    Denver
    I don’t think it’s worth it, just my 2 cents
  3. May 20, 2020 at 7:33 AM
    #2003
    2004Taco
    Lou
    California
    LOLOL Most honest answer I've heard.
  4. May 20, 2020 at 7:38 AM
    #2004
    1997tacomav6
    Denver
    Headers are nice but the most expensive upgrade for the least amount of performance and PITA to install. If you can’t install them it will cost 800-1000 for a shop to spend 10 hours install them and you will need welding done more than likely.
    That was my last engine upgrade
  5. May 20, 2020 at 7:46 AM
    #2005
    2004Taco
    Lou
    California
    I was looking into headers but I heard they're kind of pointless without a S.C. Is that true? I'm looking for performance without breaking the bank.
  6. May 20, 2020 at 7:55 AM
    #2006
    1997tacomav6
    Denver
    Even with supercharger they make only a small difference, at higher rpms you will feel a small difference,
    If your running out of mods for the engine then do them.
    I gain around 8 hp or something like that.
    2004Taco[QUOTED] likes this.
  7. May 21, 2020 at 10:37 PM
    #2007
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I installed a new pulley boys 2.2'' pulley today and have a few questions regarding my findings.
    First of all, I found a little pool of oil behind the pulley. I wiped up a little bit of it before taking this picture. Is this normal? I replaced this seal less than a year ago with an upgraded viton seal from rolling performance.
    Also, when I put my pulley boys 2.2'' on, I just ran it on with an impact and it pushed all the way up to the supercharger nose to the point where it wouldn't spin. I had to pull the pulley back a little bit so that it could freely spin. Is this normal? My URD pulley seemed to bump up to the flange on the end of the nose cone shaft and would freely spin even if I ran it on with an impact.
    Finally, with the 2.2'' pulley I'm making 7 lbs of boost on a cool damp day. Pulley boys says that I should be making 9.5 lbs with the 2.2''. Can the lost 2.5 lbs be from my JBA headers?
  8. May 22, 2020 at 8:21 AM
    #2008
    1997tacomav6
    Denver
    1st of all NEVER use impact on the supercharger.
    Your seal is leaking and probably was not set correctly if you used an impact and possibly could have
    hurt the shaft.
    The seal is made of very hard rubber that if not set correctly will wear a grove in the shaft if it’s off center.
    You might have to remove the snout to see if the shaft is damaged with a groove now.
    Your oil level will be low too.
    Boost will depend on your altitude location and is a guesstimate anyways
    Ccrowe323 likes this.
  9. May 22, 2020 at 9:30 AM
    #2009
    eon_blue
    Azusa, CA
    I can't even bring myself to use an impact on my lug nuts lol. I use it on suspension work to break stuff loose but rarely ever to put something on. Unless it's a high torque nut like the axle nut.
    1997tacomav6[QUOTED] likes this.
  10. May 22, 2020 at 1:28 PM
    #2010
    austinmtb
    Austin
    Southern Oregon
    I only use an impact to put on the pulley. The force is isolated between the pulley and the threads. The snout or any internals do not see that force.
  11. May 22, 2020 at 3:03 PM
    #2011
    Ccrowe323
    Ccrowe323 Well-Known Member
    Cory
    Florida
    2001 Tacoma 3.4 DC 5speed TRD OR
    It’s usually always better to use it to remove bolts rather than putting them on.
    The bolt could’ve been a tight fit possibly but you wouldn’t know by using an impact, in turn putting force on the internals. Especially if you used it all the way to the point it’s tight enough that the pulley doesn’t move.
    It is an impact gun that “hammers” bolts/nuts rotationally so that hammering is definitely transferred through to the internals when over tightened.
    Not saying you don’t know this but if you have ever seen how impact guns work internally it is a literal hammer inside which is what makes the sound of an impact, constantly giving it a hammer to the drive to add an extra intermittent force to break a bolt free, or put on a lug nut etc. but definitely not recommended for situations that should be torqued to spec.
    Personally on parts like that I always use a ratchet so I can feel what’s going on, to me it’s not worth saving the little bit of time and effort using an impact to have something happen. But after all it could have no correlation but the fact that it was tightened to the point of not being able to move seems to me to be the reason for sure.
    1997tacomav6 likes this.
  12. May 22, 2020 at 3:16 PM
    #2012
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Pansy.
    MatthewMay1 and Ccrowe323 like this.
  13. May 22, 2020 at 6:55 PM
    #2013
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Just to compare boost figures, I am making 8.7PSI at 650' above sea level on the 2.2 pulley.
    austinmtb[QUOTED] likes this.
  14. May 22, 2020 at 10:44 PM
    #2014
    austinmtb
    Austin
    Southern Oregon
    Do you have a trick to keep the pulley from rotating while installing with a ratchet?
  15. May 22, 2020 at 10:46 PM
    #2015
    austinmtb
    Austin
    Southern Oregon
    Thanks for chiming in with some figures. Do you have headers?
  16. May 23, 2020 at 12:20 AM
    #2016
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Pulley Boys sells a spacer. Possibility yours my require it. Don't run it if you pulled it back out so it wouldn't rub. The pulley is loose now and will eat up the shaft!
    Impact wrench will hammer the gears togeather and can hammer the ball bearings against the bearing race.
    Use a strap wrench to hold pulley
    1997tacomav6 and Ccrowe323 like this.
  17. May 23, 2020 at 12:23 AM
    #2017
    mechanicjon
    Jon
    Scottsdale Arizona
  18. May 23, 2020 at 6:03 AM
    #2018
    1997tacomav6
    Denver
    @Ccrowe323
    There is a pretty good chance you put the pulley on backwards if
    the pulley was sucked up again the snout. There is a front and back
    to these pulleys. They go on one way and it’s not uncommon to install it
    backwards.
    The top photo is the pulley on backwards.
    The inner round block ring should be pushed up again the snout.
    The bottom photo you can’t see the inner round block section and that’s the correct direction.
    I actually had mine on incorrectly for a while with a spacer, lol
    WRONG DIRECTION ABOVE
    CORRECT DIRECTION ABOVE
  19. May 23, 2020 at 6:06 AM
    #2019
    1997tacomav6
    Denver
    With my headers I lost maybe half a pound.
  20. May 23, 2020 at 7:29 AM
    #2020
    Loctite77
    Loctite77 Well-Known Member
    Zeek
    NC
    2097 mashup vroom vroom bigwheelieee
    Some rust, runs good.
    Dammit fellas, I’ve spent the last three weeks reading this thread, I’m at the end now and looking at ordering what I need to supercharge! Hello credit card!! I am in the middle of a frame swap now,
    https://www.tacomaworld.com/threads/frame-swap-n-facelift-for-mable.660848/
    I have easy access to weld in the bung for gauge onto the exhaust. You guys think I can stick that on for now without the gauge or supercharger, while I have access? Should be okay to run/drive with just the sensor in right? Second, can you point me in the direction of the bung/sensor? Or does it come with gauge? Thanks, and F y’all for making me sink another 5K in this project.
