3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Aug 22, 2020 at 5:00 PM
    #2281
    jruiz555
    jruiz555 Well-Known Member
    Are you talking about yhe split second software? I never messed with the tuning software but i do have it.
  2. Aug 22, 2020 at 5:00 PM
    #2282
    1997tacomav6
    Denver
    Another note, I had my stock injectors cleaned and serviced last month when my supercharger was rebuilt and replaced my stock fuel pump with a new DENSO pump.
    My results With the use of the 2” pulley at 6000 feet Are zero ping and AFR at WOT is at 10.5-11.
    There are a lot of different results depending on your trucks health conditions and if auto or manual
  3. Aug 22, 2020 at 5:08 PM
    #2283
    jruiz555
    Motor has about 60k on it, i am looking to send in the injectors to get serviced. Just so painful to remove all the crap to get to them, i need to make my way to the knock sensor harness to replace that also.
    1997tacomav6 likes this.
  4. Aug 22, 2020 at 11:32 PM
    #2284
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Curious to know what outlet temperatures look like at 2500rpm full boost vs 4000-5500rpm full boost without water injection.
  5. Aug 23, 2020 at 7:52 PM
    #2285
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
  6. Aug 23, 2020 at 9:34 PM
    #2286
    jruiz555
    Today with 95 degree temps outside, i plugged my deck plate mod and it ran better hmmm
  7. Aug 23, 2020 at 9:46 PM
    #2287
    Shortman5
    Supercharged TRD
    well, yeah you’re not sucking in in hot engine bay air now.
  8. Aug 24, 2020 at 7:16 AM
    #2288
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Mine cools off quick after I start driving
  9. Aug 24, 2020 at 7:38 AM
    #2289
    Shape-Shifter
    Shape-Shifter Well-Known Member
    Todd
    Elizabeth, CO
    I need some advice - I just installed a brand new SC kit. Everything has been going perfect and I've put about 800 miles testing it on steep climbs in Colorado between 6000 and 12000 feet in elevation and loving every minute of it.
    Suddenly, I am getting detonation pings under moderate to heavy loads. Im not sure what happened. Any ideas?
  10. Aug 24, 2020 at 7:48 AM
    #2290
    1997tacomav6
    Denver
    Probably a fuel issue if it just started,
    Or MAF or vacuum leak.
    Any codes?
    Bad gas ? Not 91 octane, if the gas is not 91 you definitely will have knock
    There are a few things that people don’t do that is important to do when getting a supercharger.
    1) new fuel pump if over 150k,
    The fuel pumps wear out over time even tho they work they don’t work at 100 percent when needed at full boost,
    If it’s not superchargered it would not matter
    2) same goes for the fuel injectors if over 150k
    They work fine if not superchargered BUT when superchargered they
    are Not delivering enough fuel and if they have over 150k miles they probably are not working at 100 percent and need a cleaning as they
    have a filter there and the spray pattern.
    3) fuel filter under the sear needs to be replaced every 50k
    If you don’t do these items above you will not know if your fuel system is working at 100 percent and you will need a 7 th injector or methonal to cover the difference, you might need it anyways but there’s a good chance you will not if
    you engine and fuel system are working aT 100 percent
    otis24 likes this.
  11. Aug 24, 2020 at 8:14 AM
    #2291
    Shape-Shifter
    Todd
    Elizabeth, CO
    No codes. 91 is as high as I can find around here. Maybe its gas quality between brands? First couple of tanks were Sinclare, this tank is Conoco. Not sure it that matters.... Its a high mileage truck that runs excellent (just rolled 200,000k) and your points are all valid and good input, but I'm not sure why the first 800 miles of testing were ping free.
    Cheap and easy things first, Ill run some injector cleaner through a tank or two. If that doesnt help, Ill try some octane booster. If that doesn't work, its gonna get suckey...
    1997tacomav6[QUOTED] likes this.
  12. Aug 24, 2020 at 8:31 AM
    #2292
    1997tacomav6
    Denver
    Put some octane booster in there and see if that helps till your next tank of gas.
    Did you put in cooler plugs?
  13. Aug 24, 2020 at 9:13 AM
    #2293
    Shape-Shifter
    Todd
    Elizabeth, CO
  14. Aug 24, 2020 at 9:17 AM
    #2294
    1997tacomav6
    Denver
  15. Aug 24, 2020 at 9:24 AM
    #2295
    Shape-Shifter
    Todd
    Elizabeth, CO
    Its all stock Magnusson pully. The IK22 are a bit cooler than the IK20s I think.
  16. Aug 24, 2020 at 9:24 AM
    #2296
    1997tacomav6
    Denver
    5 pounds of boost?
    22s will help, but your problem is not the plugs,
    Probably fuel related maybe or octane.
    I can run a 2” pulley without any issues at 10,000 feet on a stock setup if I needed to,
    BUT my fuel system is at 100 percent perfect.
    Start with the simple things,
    Different gas
    MAF cleaning
    ANY Vacuum leak,
    The smallest of a vacuum leak will make the supercharger have problems
  17. Aug 24, 2020 at 12:14 PM
    #2297
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Auto or manual?
    Fuel brands can make a differance slso.
    I tried Walmart gas once. Won't do that again!
    If you decide to put some octane booster in it. Autozone sells VP fuel brand called Ocutane. You can pour about 1/4 of a can to a full tank. Try that, if not add some more. Do that until you get it figured out. Do you have an AFR gauge? How about a scangauge to watch fuel trims?
  18. Aug 24, 2020 at 12:25 PM
    #2298
    Shape-Shifter
    Todd
    Elizabeth, CO
    Its a 5 speed.
    I have a Scangauge but I dont see anything when I program air fuel mix in to one of the gauge slots.
  19. Aug 24, 2020 at 12:26 PM
    #2299
    Shortman5
    Supercharged TRD
    You need a standalone AFR gauge.
  20. Aug 24, 2020 at 12:27 PM
    #2300
    eon_blue
    Azusa, CA
    In order to see fuel trims on a scangauge you have to get into the X-Gauge mode, if you still have the instructions for it they tell you how in there. Otherwise I'm sure it's probably online somewhere, I haven't programmed it into mine yet but I know it's possible.
    As for AFR, you'll need to install Wideband O2 sensor before the cats in order to get an accurate Wideband AFR reading with a standalone AFR gauge. The AFR reading that the ECU provides is narrowband
