3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Oct 1, 2019 at 11:45 AM
    #261
    1997tacomav6
    Denver
    I would just get a urd pulley 2.1 and get the back spacer washer just in case you need it.
    You can always go to the 2 inch pulley later since they only cost a hundred bucks after you're happy to make sure everything is working okay.
    The two inch pulley you might have to change out your nose seal to accept the higher RPMs I'm not sure on that supercharger that's why I'm saying just run with a 2.1 pulley for now.
    The upgraded nose seal can take higher temperatures and higher RPMs then the stock one that comes with a supercharger
    Rldanie likes this.
  2. Oct 1, 2019 at 11:55 AM
    #262
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    I found the pulley on the URD website. Does that require a different belt? Thanks,
  3. Oct 1, 2019 at 11:56 AM
    #263
    1997tacomav6
    Denver
    Ok, but with the stock pulley you probably will not need the methanol spraying ,fyi
  4. Oct 1, 2019 at 11:57 AM
    #264
    1997tacomav6
    Denver
    Nope, there should be an option for a spacer tho looks like a big washer
  5. Oct 1, 2019 at 11:58 AM
    #265
    1997tacomav6
    Denver
    Did they install a Gates supercharger belt?
    The gates supercharger belt can withstand the extra RPMs and the extra heat the stock one can't.
    The gates supercharger belt will last you 75000 miles or so the generic supercharger belt will last you maybe 30,000 40,000 miles depending on how hard you run your truck and what size pulley
  6. Oct 1, 2019 at 12:12 PM
    #266
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Is this the case with a brand new, "2nd" gen (black) supercharger?
    I do see an option from The High Speed Lab: "Supercharger Double-Lip Seal Needle Bearing Upgrade Installation Service" [link]
    …ideal for High Performance, Methanol or Water Injection systems.
  7. Oct 1, 2019 at 1:49 PM
    #267
    CHMM
    CHMM [OP] GTO
    Gabe
    I was thinking the same thing. My thoughts were that I wanted the truck to run cooler and cleaner. I wanted to steam clean the engine and not have to worry about carbon buildup. That's what I was trying to accomplish with the methanol injection. It seems to correlate with how clean your truck is. It was more of a preventative type move for now. What do you think? Thanks,
    Also the pickup and torque is really awesome. I don't get tailgated and I could go in whatever gear at any time. It's really nice.
  8. Oct 1, 2019 at 1:51 PM
    #268
    JasonLee
    15 TRD OffRoad
    Without increasing the boost, the meth will make the engine too rich since it runs in Closed Loop most of the time. Not sure how much you'll be able to spray (if any) with the stock pulley.
  9. Oct 1, 2019 at 1:54 PM
    #269
    eon_blue
    Azusa, CA
    I could be wrong but I thought that methanol was even used on N/A applications strictly for it's cooling/cleaning properties, and you can adjust it to only spray when under a certain amount of boost?
    If it can be 'tuned' so-to-speak so that it only sprays during WOT or open loop then it could be beneficial even with a stock supercharger setup, I would think. Again I'm really only speculating so I could be wrong in that assumption
  10. Oct 1, 2019 at 2:12 PM
    #270
    1997tacomav6
    Denver
    If your truck is not running lean then you probably do not want to add methonal with the stock pulley.
    But you could run distilled water instead if you wanted too and you can set your spray points but winter is almost here and that would would mean freezing. For summer this would work.
    My opinion if your adding methonal kit is to add the 2.1 pulley, you won’t regret it.
    If your not going to a smaller pulley I don’t know if I would add the meth kit and cost.
  11. Oct 1, 2019 at 2:17 PM
    #271
    CHMM
    CHMM [OP] GTO
    Gabe
    ok. I will listen to you on this. I'll give it some thought.
  12. Oct 1, 2019 at 2:26 PM
    #272
    1997tacomav6
    Denver
    If your on the fence about getting a smaller pulley I would wait on installing the methonal kit.
    Or you could go with the more conservative 2.2 pulley and not necessarily need meth kit But might have a little pinging.
    The 2.1 pulley will give you probably 40 more horses or so, your boost should go up to 8 pounds or so instead of 4 pounds. This is an estimate number as each truck is a little different.
    I’ve have had all these pulleys at one time and each pulley upgrade is a very noticeable difference.
    The methonal will definitely eliminate heat soaked issues that come with the supercharger but that’s not an issue in winter and will clean your engine of carbon,
  13. Oct 1, 2019 at 3:24 PM
    #273
    CHMM
    CHMM [OP] GTO
    Gabe
    Hey John, Are you running the 2.1 Pulley? Thanks,
  14. Oct 1, 2019 at 3:28 PM
    #274
    1997tacomav6
    Denver
    No, I have a 2" pulley that will give you 10 pounds of boost at 6000 feet.
    But if you decide on a 2" pulley I would suggest getting the high performance nose seal that is rated at a higher rpms and higher temperature rating than your stock nose seal.
    CHMM[QUOTED][OP] likes this.
  15. Oct 1, 2019 at 3:32 PM
    #275
    CHMM
    CHMM [OP] GTO
    Gabe
    ok. Sounds good. a little more to consider.
  16. Oct 1, 2019 at 3:58 PM
    #276
    CHMM
    CHMM [OP] GTO
    Gabe
    The thing is I have the methanol and the Innovative gauge sitting in my office and I look at em everyday. LOL...
  17. Oct 1, 2019 at 7:27 PM
    #277
    eon_blue
    Azusa, CA
    I mean if you have it might as well install it, unless it will hurt the truck in some way (such as running too rich)....but I feel like that might not be the case, methanol does two things - cools the intake and increases the octane rating...neither of which are going to make you run too rich, it's not like you're adding more fuel (like you would be with the 7th injector), you're just upping your octane rating. Unless I'm mistaken...I just don't see how it would hurt anything
  18. Oct 1, 2019 at 7:32 PM
    #278
    Typereg
    Typereg Well-Known Member
    Danny
    Los Angeles, CA
    2018 White Tacoma 4x4
    Supercharged is the way to go on 1st gen
  19. Oct 1, 2019 at 9:19 PM
    #279
    JasonLee
    15 TRD OffRoad
    i did some more reading... water/meth blend injection which I think all of us are talking about mainly reduces the air temps from the supercharger compressing it. Also, the blend reduces the risk of early detonation. For this discussion of NO ECU tuning, it mainly will help when increasing boost with the smaller pulley.
    The more I read, the more I want to get the 7th injector piggyback ECU in order to control the timing, fuel AND the meth spray based on MAP (it taps into the boost port and has an internal MAP sensor). Can load in 3D tables based on multiple values and really take advantage of the setup without adding the 7th injector itself and spraying more gasoline.
  20. Oct 1, 2019 at 9:25 PM
    #280
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    John do you have any of your old pulleys? Are the any good or worn out?
