3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Apr 22, 2021 at 6:02 PM
    #2861
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Yeah those pumps are trash. I threw mine away and went with “Deatchwerks?”
    1997tacomav6 likes this.
  2. Apr 22, 2021 at 6:04 PM
    #2862
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    Does it whine at low speed? I took my truck out to catch some gravel and man it was loud when I was going slow up a small hill
  3. Apr 22, 2021 at 6:09 PM
    #2863
    Shortman5
    Supercharged TRD
    It was loud all the time. It would drown out the engine at idle and when fuel sloshed around it would sometimes activate which I could feel and hear inside the cab.
    Those Walbros are a joke.
    In fact I had 2 because I thought something was wrong with one of them.
    Rldanie likes this.
  4. Apr 22, 2021 at 6:14 PM
    #2864
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    From what I have heard, AEM pumps are nice and quiet
    Rldanie, 1997tacomav6 and Poncate like this.
  5. Apr 22, 2021 at 6:20 PM
    #2865
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Wonder if you could get it decked at a machine shop - you didn't have a leak between the original plenum and the manifold I'm assuming?
  6. Apr 22, 2021 at 6:26 PM
    #2866
    eon_blue
    Azusa, CA
    Mine is really only loud when it's hot outside or I've been driving for a few hours. But when it's loud it's loud. I don't know about feeling it resonating in the cab but you certainly hear it in there when it gets hot.
    Walboro says it's inherit of the design but still annoying af. Mines lasted 5 years so far though
  7. Apr 22, 2021 at 6:31 PM
    #2867
    Shortman5
    Supercharged TRD
    In the past I’ve thought about getting someone to make a set of thermal Teflon gaskets. But after thinking about it I was worried that it would be so “squishy” that it would break one of the little toes off on the ends. Ive already seen a few repairs in that area so I backed off.
    but it’s worth a thought for one that’s maybe 1/16” instead of 1/8” like I originally planned. Hard part would be finding someone to do it.
  8. Apr 22, 2021 at 6:31 PM
    #2868
    Poncate
    PNW
    04 DCSB 4x4
    I didn’t feel it but definitely hear it in the cab. If I listen back by the tank it almost sounds like it’s sucking a little air. Like a filter on a fish tank
    eon_blue[QUOTED] likes this.
  9. Apr 22, 2021 at 6:39 PM
    #2869
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    The Felpro ones with the blue outlines of the passages are the biggest ones I’ve seen. You could try permatex on the outside ridge of the mating surface.
    m3bassman[QUOTED] likes this.
  10. Apr 22, 2021 at 6:40 PM
    #2870
    Shortman5
    Supercharged TRD
    Maybe the P/O of the supercharger overheated his bad slightly warping the mating surface?
    Do you have a flat edge you could check that with?
    Also, maybe clean those bolts and the holes really good and using something to lubricator them all evenly then torque.
    Possible you’re getting some wonky torque values?
  11. Apr 22, 2021 at 7:01 PM
    #2871
    Shortman5
    Supercharged TRD
    Im not an expert but if it were me I would run a bead around each port on the bare side and let it tack up ten install it. That way you don’t have a mess and it should still seal up.
  12. Apr 22, 2021 at 7:28 PM
    #2872
    TacoBike
    Mason
    Making it thin with your finger and waiting for it to be tacky would keep it from dripping in, especially if you make it super thin near the inside
    unstpible likes this.
  13. Apr 22, 2021 at 7:35 PM
    #2873
    TacoBike
    Mason
    Its rtv, its not going to crumble? Maybe im not thinking the same here, but you can just scrape it off yeah?
    The option I would do first would be buy a new oem gasket and clean both surfaces extremely well, then tighten together. Check both for flatness with a machinist's straight edge and feeler gauges.
  14. Apr 22, 2021 at 8:00 PM
    #2874
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Permatex will kind of peel. IMO it wouldn't be a huge issue especially if you used compressed air / vacuum to blow out any debris that get down in the passages. But yeah, no reason any old gasket shouldn't seal if they're both flat surfaces... any confirmation it's that and not anything else on the sc?
  15. Apr 22, 2021 at 10:48 PM
    #2875
    tunerpike
    tunerpike Well-Known Member
    After noticing the vacuum diagram under the hood I decided to pull the vacuum line going to to the pressure regulator; letting the regulator vent to atmosphere. LTFT went to 0..
    I didn’t realize the regulator didn’t require a vacuum source from the factory. I went ahead and hooked it back up for a boost reference. Anyone using a check valve here?
  16. Apr 22, 2021 at 11:35 PM
    #2876
    TacoBike
    Mason
    You would always have positive pressure, essentially making it a higher pressure system and not increasing with boost. Dont know how nice that would play.
  17. Apr 23, 2021 at 6:22 AM
    #2877
    Shortman5
    Supercharged TRD
    I highly doubt that RTV would do any harm going through an engine.
    but maybe I’m wrong. I would think it being very soft that it would either burn up or just get blown out the exhaust.
    TacoBike likes this.
  18. Apr 23, 2021 at 4:07 PM
    #2878
    Shortman5
    Supercharged TRD
    unstpible and eon_blue like this.
  19. Apr 23, 2021 at 5:13 PM
    #2879
    TacoBike
    Mason
  20. Apr 23, 2021 at 5:15 PM
    #2880
    TacoBike
    Mason
    @Rldanie ^
    seeing as i dont think there are many engine mods left for you
