3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. May 10, 2021 at 7:41 PM
    #2961
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Dang. What a mess
  2. May 10, 2021 at 8:33 PM
    #2962
    1997tacomav6
    Denver
    My sweet spot was the ik22 that is 2 steps cooler and that heat range is the fr7.
    That’s what I’m using now.
    indetrucks[QUOTED] likes this.
  3. May 10, 2021 at 8:34 PM
    #2963
    1997tacomav6
    Denver
    I feel for you, this sucks and having the truck down is worst.
    Snarpezal likes this.
  4. May 22, 2021 at 7:24 PM
    #2964
    1997tacomav6
    Denver
    I’m wondering if there is anyone here that has a haltech Stand alone setup for their supercharger?
    I’ve tried to get some input on another posting but no one has chimed in on having one with a SUPERCHARGER.
    I’m probably going to pull the trigger the end of this week for the haltech 2000 and for once and all
    have a perfect tune with a more aggressive timing.
    No more open loop close loop to deal with
    No more MAF sensor to deal with
    Much Better timing number
    Any input good or bad would be appreciated.
    There is a plug and play setup that takes less than an hour to install with a base map that will need fine tuning that’s available in the 750 model and the 2000 model
    CanadaToy and unstpible like this.
  5. May 23, 2021 at 9:10 AM
    #2965
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Not emissions compliant so unless your in a non emissions county here in CO you will fail when they hook up to your OBD2.
    Great for a race car though!
  6. May 23, 2021 at 9:26 AM
    #2966
    1997tacomav6
    Denver
    The nice thing is it takes 30 minutes or less to swap back and forth if you want to run it off road.
    And you can actually install two maps, one that is compliant to 14.7 afr btw And you can install a switch back and forth Says the program guy of these
    unstpible likes this.
  7. May 23, 2021 at 10:39 AM
    #2967
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    I saw You are running the 2" pulley. Do you gap your plugs tighter to stop the boost from blowing out the spark?
  8. May 23, 2021 at 11:32 AM
    #2968
    1997tacomav6
    Denver
    Nope, actually running a 1.9 pulley
  9. May 23, 2021 at 11:59 AM
    #2969
    Milor
    shaun
    sorry about all the questions. Ive had a few to ask you for awhile now since you have the experience. where did you find a 1.9? special made? I run the pulleyboys 2.0 pulley but since I started running it my valve covers have started seeping oil. are you pushing much oil out of the valve cover breathers?
  10. May 23, 2021 at 12:07 PM
    #2970
    1997tacomav6
    Denver
    Had it custom modified for me, and works because I’m at 5300 feet but probably don’t recommend it unless you have your supercharger ported and your spraying a lot of water to cool the supercharger down along with headers etc.
    Supercharger was not designed to spin that fast and the bearing are pushing the limits.
    I have seen plenty of post with others saying they see very little difference from a 2.1 to a 2. Pulley.
    If I was at a lower elevation I would not need a 1.9 pulley.
    My valve covers are fine, They last about 150k before they start leaking again.
    I’m running full synthetic mobile one too, ZERO leaks so far
  11. May 23, 2021 at 12:20 PM
    #2971
    Milor
    shaun
    ya My covers are due for a new gasket. Right now I still have my 7th injector for fueling & cooling but plan on switching to methanol. I bought the snow stage 2 kit but have not installed yet. I run synthetic 5 -30. I also run a Hayden 1040 Heavy duty (Diesel) engine oil cooler to take heat out of my oil. I usually run it about 8k miles and it still looks fresh when I change it
  12. May 23, 2021 at 12:27 PM
    #2972
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Your truck is still OBD2 compliant so you will have to swap ECU's for it to pass. Yours is old enough to still get run on the rollers but the newer trucks are OBD plug in only to check for codes and readiness monitors.
    I've seen that kit for a few years and would love to run it to ditch the factory ECU but the emissions part of it killed the idea for me.
    1997tacomav6[QUOTED] likes this.
  13. May 23, 2021 at 1:32 PM
    #2973
    1997tacomav6
    Denver
    The 750 is NOT OBII compatible,
    The 2000 IS OBII compatible so the scanguage and check engine lights will still work.
    Last time I did my Emissions 8 months ago they just looked to see if I had an OBII port because my scanguage was using it, they did NOT disconnect it and they did not check the OBII function or if there were codes, they ran the truck on the treadmill tho
    They did not even open the hood!
    It always passes with flying colorS with the supercharger
    otis24 likes this.
  14. May 23, 2021 at 1:50 PM
    #2974
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Just a friendly PSA. Stay the fuck away from PLX devises. At worst they’re selling fake products and at best it’s a Kickstarter cash grab. Fuck those people.
    1997tacomav6 likes this.
  15. May 23, 2021 at 1:52 PM
    #2975
    1997tacomav6
    Denver
    Did you get your supercharger square away? Fixed and working?
  16. May 23, 2021 at 2:09 PM
    #2976
    Shortman5
    Supercharged TRD
    I emailed that video to Magnuson. This was the response
    “There is some play and you will hear some noise when doing that. If there is no excessive resistance / grinding noises, then you should be OK but its hard to tell without evaluating the supercharger in person”
    So I guess I’m just going to run it.
    I’m just trying to get the truck rolling again. DT headers had some fitment issues and DT asked me to send them in after looking at pictures. Thanks to California being terrified to go outside and the huge influx of e commerce for things like paper towels and a bag of chips FedEx is taking twice as long to get them delivered.
  17. May 23, 2021 at 2:18 PM
    #2977
    1997tacomav6
    Denver
    Magnusson used to do my rebuilts till they stop the 1st rebuilds,
    They alway did a great job and never had any issues with their work in California
  18. May 23, 2021 at 2:22 PM
    #2978
    eon_blue
    Azusa, CA
    Do they still rebuild the black 1st gen units? Or did they stop those too
  19. May 23, 2021 at 2:22 PM
    #2979
    Shortman5
    Supercharged TRD
    I don’t think they do any rebuilds at all anymore. They told me to go to SOL. But I firmly believe SOL is highway robbery. How in the fuck can you tell me changing the needle bearings is $700 and think that’s fair.
  20. May 24, 2021 at 9:59 PM
    #2980
    1997tacomav6
    Denver
    Placing my order tomorrow Haltech 2000 and 6 weeks later it will arrive,
    Al plug and play with a 30 minute install time frame
    https://m.youtube.com/watch?v=BIHYHKSFv94
    vonellis, TMFF[QUOTED] and Milor like this.
