3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Oct 1, 2019 at 9:30 PM
    #281
    1997tacomav6
    Denver
    Yes, I have 5 or 6 gave one away to a local member.
    The URD pulleys are worn, I have two steel pulleys and the stock steel pulley still.
    Don’t want to get sell any tho
  2. Oct 1, 2019 at 9:33 PM
    #282
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Were are you getting your steel pulleys?
  3. Oct 1, 2019 at 9:40 PM
    #283
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    CHMM[OP] likes this.
  4. Oct 1, 2019 at 9:42 PM
    #284
    1997tacomav6
    Denver
  5. Oct 2, 2019 at 12:52 AM
    #285
    mechanicjon
    Jon
    Scottsdale Arizona
    Well that sucks!
  6. Oct 2, 2019 at 12:53 AM
    #286
    mechanicjon
    Jon
    Scottsdale Arizona
  7. Oct 2, 2019 at 6:08 AM
    #287
    1997tacomav6
    Denver
  8. Oct 2, 2019 at 8:29 AM
    #288
    CHMM
    CHMM [OP] GTO
    Gabe
    Castle Rock, Colorado
    2001 TRD Xtra Cab 4x4 Supercharged
    5100s SPC UCAs Energy bushings #70 spring clutch mod Supercharged
    here is what I’m going to do. I’m gonna ask the performance shop and see what they say. I have the AFR gauge so I’m installing that for sure. I was reading that they run methanol/water on whatever vehicles and it adds power. I’ll see what the performance shop says. If we can tune it etc... I’m thinking it’s not too much fuel that’s being added, it’s better fuel. I don’t know. :)
    eon_blue[QUOTED] likes this.
  9. Oct 2, 2019 at 2:21 PM
    #289
    1997tacomav6
    Denver
    You can dilute the methonal mixer down to windshield solution mix 30/70 that is 20 below zero if you want and there will be less fuel being injected instead of 50/50 boost juice as an option too and your still safe from freezing
    CHMM[QUOTED][OP] likes this.
  10. Oct 2, 2019 at 2:31 PM
    #290
    JasonLee
    15 TRD OffRoad
    Or save the hassle and some money and buy it pre-mixed 30/70 for $2-3/gallon. I won't be buying boost juice until I want a higher blend.
  11. Oct 2, 2019 at 4:14 PM
    #291
    CHMM
    CHMM [OP] GTO
    Gabe
    ok. Got the 2.2 Pulley. So we should be pushing 5 to 5.5 pounds of boost as opposed to 4 pounds at this altitude.
    I’m taking that and a Gates belt to the performance shop in Colorado Springs. Is there a way they can see what it needs? Dial it in. I’m not too familiar with tuning etc...
  12. Oct 2, 2019 at 4:17 PM
    #292
    1997tacomav6
    Denver
    They will do that for you with a Dyno to know what size nozzle you need.
    You will probably need a #1 or #2 nozzel, but the #1 nozzel because it’s so small will plug up probably every 10-15k miles but you will get 1500 miles from a gallon of boost juice.
  13. Oct 2, 2019 at 4:21 PM
    #293
    1997tacomav6
    Denver
    It’s best NOT to use windshield fluid unless you have a larger nozzle, even a size 5 like mine tends to plug up over time if you use wiper fluid. If your ok with cleaning it regularly then it’s ok.
    A 1 or 2 nozzel will plug up very fast if you run just wiper fluid.
    Wiper fluid is not distilled or filtered down for minerals.
    20 below is 30 percent methonal.
    0 probably would not be a good choice of you wanted methonal
  14. Oct 2, 2019 at 4:21 PM
    #294
    CHMM
    CHMM [OP] GTO
    Gabe
    So from the dyno, they can tune AFR etc?
  15. Oct 2, 2019 at 4:22 PM
    #295
    1997tacomav6
    Denver
    You want a two size if possible just because the one will plug up so easily
  16. Oct 2, 2019 at 4:23 PM
    #296
    1997tacomav6
    Denver
    The Dyno gives them real time information for both setups to make sure the numbers are correct
  17. Oct 2, 2019 at 4:23 PM
    #297
    CHMM
    CHMM [OP] GTO
    Gabe
    That’s good to know. I’ll bring that up when installing.
  18. Oct 2, 2019 at 4:24 PM
    #298
    CHMM
    CHMM [OP] GTO
    Gabe
    that’s awesome.
    1997tacomav6[QUOTED] likes this.
  19. Oct 2, 2019 at 4:25 PM
    #299
    1997tacomav6
    Denver
    This way you know 100 percent that your AFR is correct and the methonal kit is spraying at the correct set points too
  20. Oct 2, 2019 at 4:27 PM
    #300
    1997tacomav6
    Denver
    You got a 2001-2004 pillar pod?
