3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Jun 4, 2021 at 7:42 PM
    #3101
    1997tacomav6
    Denver
    1997 has ONE cat, not 2
    unstpible and Dalandser like this.
  2. Jun 4, 2021 at 7:43 PM
    #3102
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    96-98 (at least my 98) only have one...
    1997tacomav6 likes this.
  3. Jun 4, 2021 at 8:55 PM
    #3103
    TacoBike
    TacoBike The Researcher
    Mason
    Shingle Springs, California
    2000 3.4 Ext Cab TRD 4x4 with original SC
    ARP head studs Supercharger FIC6 AFR gauge painted fenders audio install
    I know, I’m trying to find one for my Cali 2000
  4. Jun 4, 2021 at 8:56 PM
    #3104
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’d call LCE
  5. Jun 4, 2021 at 8:59 PM
    #3105
    TacoBike
    Mason
    Hmmm, might be more effective to make my own
    But when to get the time
  6. Jun 4, 2021 at 9:43 PM
    #3106
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah we just bought some 2.5 mild steel tubing and made the rest of the exhaust - much cheaper and easier than sourcing something that bolts on. Paid $130 to have it ceramic coated inside and out.
  7. Jun 4, 2021 at 10:01 PM
    #3107
    TacoBike
    Mason
    How much would you say a 2.5" exhaust would be (in just piping?) with a muffler
    If I did all the work myself
  8. Jun 4, 2021 at 11:38 PM
    #3108
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think it was around $70 with a bung but I bought a better one off of the net and a v band between the cat and the muffler to make it easy to remove.
    https://www.kartek.com/parts/clampc...stainless-steel-2-12-inside-dia-coupling.html
    https://www.yotashop.com/toyota-o2-...wT6RPTSRnypjXPYh8xU-qvPziKMs5oBcaAtCEEALw_wcB
    I bought two sets of these to make sure it didn’t shake at all:
    https://www.ebay.com/itm/143142129756
    Milor and 1997tacomav6 like this.
  9. Jun 6, 2021 at 11:05 AM
    #3109
    An3
    An3 Well-Known Member
    Andrew
    White '96 Manual 4x4
  10. Jun 6, 2021 at 11:14 AM
    #3110
    TacoBike
    Mason
  11. Jun 6, 2021 at 9:09 PM
    #3111
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    well I broke down friday. NO ENGINE FAULTS DETECTED WITH SCANNER. NO CHECK ENGINE LIGHT. The truck acted like I was out of gas but I wasn't. In neutral I can rev it out to redline. But when I try and drive once i get around 15mph it cuts all power then when it slows down enough it will go again. truck runs perfect up to 15mph. I changed the fuel pressure regulator but it wasnt the problem. I have now noticed the Throttle position sensor is buzzing loudly with key on. I am picking up a TPS sensor in the morning. Does that sound like a tps?
    * when it stalls the truck it feels like it just cuts all timing like it feels with the knock sensors, but last time that happened to me it threw the code & check engine came on
  12. Jun 6, 2021 at 10:06 PM
    #3112
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Can you see what it’s reading with a scanner?
  13. Jun 6, 2021 at 10:21 PM
    #3113
    Milor
    shaun
    my scanner said no engine faults no misfires
  14. Jun 6, 2021 at 10:27 PM
    #3114
    TacoBike
    Mason
    We mean live data, our trucks will show short term and long term fuel trims and timing as well while plugged in.
    Milor[QUOTED] likes this.
  15. Jun 6, 2021 at 10:59 PM
    #3115
    Milor
    shaun
    I don't know. I put a pressure gauge on the fuel rail and did all fuel pressure checks it was all within spec
  16. Jun 6, 2021 at 11:05 PM
    #3116
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  17. Jun 6, 2021 at 11:36 PM
    #3117
    Milor
    shaun
    I guess my tps sensor is a 4 wire that they don't sell at the auto part stores, they only sell the 3 wire. I have no idea why they are different but this is a pain in the a**
  18. Jun 7, 2021 at 12:03 AM
    #3118
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @mechanicjon
    I’d get a scanner that can tell you what the tps is reading and see where you might have an issue.
    I believe because you’re an 03-04 with the drive by wire instead of a throttle cable 96-01.
  19. Jun 7, 2021 at 4:04 AM
    #3119
    Milor
    shaun
    I'm not drive by wire I have a cable,
  20. Jun 7, 2021 at 4:19 AM
    #3120
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    03-04 definitely had a different throttle body from previous years. IIRC there were combination throttle cable and drive by wire 4runners and possibly Tacoma’s.
    TacoBike likes this.
