3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Aug 6, 2021 at 8:18 AM
    #3401
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    If anyone has race gas in your town if do that. Just be sure it’s sensor safe.
    BeLance89[QUOTED] likes this.
  2. Aug 6, 2021 at 9:16 AM
    #3402
    1997tacomav6
    Denver
    I’m pretty consistent at 20 mpg highway 5 speed.
    unstpible, Milor and jruiz555 like this.
  3. Aug 6, 2021 at 9:17 AM
    #3403
    jruiz555
    jruiz555 Well-Known Member
    I just purchased new up and downstream sensors ill see if it helps the current sensors have about 230k miles on them
    BeLance89 likes this.
  4. Aug 6, 2021 at 9:17 AM
    #3404
    jruiz555
    At one time i was getting about 250 per tank. Now im lucky to get 130.
  5. Aug 6, 2021 at 9:35 AM
    #3405
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Ooof, That's a drastic decrease! Most I ever got was 220 out of a tank. But, that old engine and trans were very tired; hoping to see moderate increase in range with the refreshed engine and rebuilt trans.
    unstpible and Milor like this.
  6. Aug 6, 2021 at 9:37 AM
    #3406
    eon_blue
    Azusa, CA
    Well I feel better now lol. When I first got my truck, it was all stock and supercharged. I actually got over 300 to a tank all highway once.
    Now, with the steel armor/bumpers/bed rack/tent/33" tires...I'm lucky to break 180 miles to a tank. I also do mostly in-town commuting too though.
    130 is pretty bad, what size tires are you running? Any extra weight elsewhere? Sounds like you might wanna start with a fresh tune up and go from there. Do you have a scan tool to read fuel trims?
  7. Aug 6, 2021 at 9:39 AM
    #3407
    eon_blue
    Azusa, CA
    I was going to suggest the O2s, that's a good idea. Clean the MAF too with MAF cleaner
  8. Aug 6, 2021 at 9:53 AM
    #3408
    jruiz555
    i am running 33" tires with rock sliders, and a decently weighted front steel offroad bumper.
    Milor likes this.
  9. Aug 6, 2021 at 10:27 AM
    #3409
    Shortman5
    Supercharged TRD
    My tires are 80pb a piece, don’t run a skid right now, and I’m lifted 2”. I’m sure if I was closer to stock I could close that gap
    1997tacomav6[QUOTED] likes this.
  10. Aug 7, 2021 at 1:54 PM
    #3410
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    im running a 2" pully urd 7th injector setup and seeing 12-13mpg on really hard mountain driving 2000 ft -6000 ft elevation with lots of full throttle "driving like i stole it" the whole tank of fuel.. I did a trip from the central valley of california up through yosemite park into nevada and got almost 19 mpg on that mountain drive. if your getting 10 something is wrong
    unstpible and 1997tacomav6 like this.
  11. Aug 7, 2021 at 1:57 PM
    #3411
    Milor
    shaun
    fill with 93 and boost that octane. if it does not smell like varnish you are fine
  12. Aug 7, 2021 at 2:12 PM
    #3412
    eon_blue
    Azusa, CA
    What size tires? In my experience that's the biggest factor in mpgs on these trucks unless you're fully decked out in armor. Weight at the wheels has a dramatic effect on fuel mileage, not to mention the difference in calculation due to larger tire size if that's the case.
    Although 10 mpg is certainly pointing to something else other than tires for sure.
  13. Aug 7, 2021 at 2:13 PM
    #3413
    jruiz555
    Ahh ok i dropped off a set of injectors to ger serviced and i have new exhaust sensors in route. Ill clean the maf sensor and swap air filter
    Milor and BeLance89 like this.
  14. Aug 7, 2021 at 2:16 PM
    #3414
    eon_blue
    Azusa, CA
    How new are the plugs/wires? The cooler Iridium plugs that most of us use should last a lot longer than the OEM copper ones but I still wouldn't run them to 100k like they advertise
  15. Aug 7, 2021 at 2:37 PM
    #3415
    jruiz555
    I have about 20k miles on the urd plugs that came with the 7th injector. The wires idk i would say 70k miles on them. Do u think i should replace wires
    Engine has a total of like 75k miles it was a jdm im
    Milor likes this.
  16. Aug 7, 2021 at 2:37 PM
    #3416
    Milor
    shaun
    something is definitely wrong. I would start with replacing the fuel pressure regulator then maybe your wideband 02 sensor and clean your maf. I had to replace my throttlebody the throttle position sensor wasn't communicating with the cable sensor on the otherside
  17. Aug 7, 2021 at 2:39 PM
    #3417
    Milor
    shaun
    the ruthenium FR7's are awesome a step up from the iridiums
  18. Aug 7, 2021 at 2:42 PM
    #3418
    jruiz555
    Part numbers?
  19. Aug 7, 2021 at 3:48 PM
    #3419
    Shortman5
    Supercharged TRD
    2” pulley and 7th? Didn’t you say you haven’t tuned the 7th injector?
    Out of curiosity what are your AFRs WOT?
    Milor[QUOTED] likes this.
  20. Aug 7, 2021 at 5:30 PM
    #3420
    jruiz555
    Curious what exhaust are u guys running when i had stock i could feel the torque pretty bad and it was nice. I swapped to a high end overland magnaflow and it isnt the same feel anymore.
