3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Aug 7, 2021 at 9:39 PM
    #3441
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    They pop up. But yea they’re rarer now, the v6 was not a common option either. But they’re out there. In Australia they were around till 97. So there’s far more out there globally at least.
    Milor[QUOTED] likes this.
  2. Aug 7, 2021 at 9:41 PM
    #3442
    Empty_Lord
    Dan
    Gotta make due with what you can on the 3.4. She’s super outdated, so there’s little chance any aftermarket will pop up for it. It’s a good motor, but defiantly forgotten in the performance world due to the VVTI motors proving to be reliable and able to make gobs more power.
    Milor likes this.
  3. Aug 7, 2021 at 9:50 PM
    #3443
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Thing is the 5vz is stout. Seems to take a lot of abuse. Would have been a great tuner motor if little things like the ECU wasn’t impossible to tune.
    I’m not sure how it would have worked but Gadget made a comment back in the day about working on VVT on the 3.4. Would have been cool if that worked out.
    Colt cams still does regrinds for the 3.4 as of a year or so ago. But then you gotta pay extra special attention to making sure you’re valves are set. Might as well go with the $1200 LCE skim kit to avoid spitting spims out.
    At that point might as well swap in a LS. Ive been wondering if a 400hp 6.2 will fit. The picture CX has shows a corvette LS sitting pretty nicely in there with room for long tubes.
  4. Aug 7, 2021 at 9:56 PM
    #3444
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    If I had to guess it might not make more power but it will change the hp & torque curve to come in at a higher rpm. it might make it a great highway motor with great power response for passing cars
  5. Aug 7, 2021 at 9:57 PM
    #3445
    Empty_Lord
    Dan
    Honestly the 2GR (previous gen, no big news on the current gen) has proven to be super stout and make good power. N/A can do 300hp on a car. Over 700hp with boost on a stock engine has been done. I imagine the FKS can do well too.
    the best thing that could happen for the VZ is someone get bored and throw free valve on it. This engine would Probably be at 3rd gen hp numbers with more torque easily
  6. Aug 7, 2021 at 9:57 PM
    #3446
    Empty_Lord
    Dan
    The ACIS adds power up top without sacrificing down low by offering both runners. Basically it broadens the power band. And it works wondefully
  7. Aug 7, 2021 at 9:59 PM
    #3447
    Milor
    shaun
    Ive heard of a couple ls swaps and a ton of 350 swaps
  8. Aug 7, 2021 at 10:00 PM
    #3448
    Empty_Lord
    Dan
    personally im not a fan of the LS. too easy to make power. i will probably swap a tacoma one day. but i plan on using a 2GR FKS after they've come down in price. coupled with a manual trans it would be a blast
    i also just dont like GM.. or ford. or chrysler... too many bad experiances with all of them... and nissan.
  9. Aug 7, 2021 at 10:02 PM
    #3449
    Milor
    shaun
    I saw a youtube video of a kid doing a freevalve swap on a harbor freight 5 horse and it made a ton more power haha.
  10. Aug 7, 2021 at 10:04 PM
    #3450
    Empty_Lord
    Dan
    you can run without a throttle with free valve. its awesome
  11. Aug 7, 2021 at 10:05 PM
    #3451
    Milor
    shaun
    ya gm is kind of a shit carmaker nowadays. I think the LS would be too heavy of a motor and would hurt handleing. and moving all that weight up front would just make the rearend spin happy, I doubt you would get the power to the ground without a ton of weight on the ass end
  12. Aug 7, 2021 at 10:07 PM
    #3452
    Empty_Lord
    Dan
    and aluminum block LS likely weighs less than a 5VZ
  13. Aug 7, 2021 at 10:09 PM
    #3453
    Milor
    shaun
    Ive been wondering if you sealed off the water pump with a plate and ran an electric water pump if that would help make more power with the engine not having to push the water around
  14. Aug 7, 2021 at 10:09 PM
    #3454
    Empty_Lord
    Dan
    not really. all the electrical load will just make the alternator harder to turn.
  15. Aug 7, 2021 at 10:15 PM
    #3455
    Milor
    shaun
    wow thats a shock a fully dressed aluminum ls and 5vz both weigh around 500 pounds... thats wild... I was thinking more of the iron ls blocks that come in the trucks but I looked that up and its around 600 pounds so not too bad..
  16. Aug 7, 2021 at 10:15 PM
    #3456
    Empty_Lord
    Dan
    Fun fact, the Toyota v12 weighs less than a 5vz
    unstpible and Milor[QUOTED] like this.
  17. Aug 7, 2021 at 10:26 PM
    #3457
    Milor
    shaun
    the v-12 still only made 300hp... not sure if that was at the crank or wheels tho.. super rad engine tho & sounds awesome
    unstpible likes this.
  18. Aug 7, 2021 at 11:12 PM
    #3458
    Empty_Lord
    Dan
    It makes much more with a custom computer. They were limited to 275 in Japan or somerhign
  19. Aug 8, 2021 at 10:12 AM
    #3459
    eon_blue
    Azusa, CA
    Why even bother making a 12 cylinder if you're limited to under 300hp lol.
  20. Aug 8, 2021 at 10:18 AM
    #3460
    jruiz555
    jruiz555 Well-Known Member
    Anyone running the transgo kit
