3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Aug 20, 2021 at 4:27 PM
    #3501
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    dont have a idle control valve. It’s all done with the throttle motor. The TB is clean and only a few years old.
  2. Aug 20, 2021 at 9:15 PM
    #3502
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    I haven’t noticed that change. It seems to warm up the same as before the SC
  3. Aug 23, 2021 at 7:51 AM
    #3503
    Bigal90
    Bigal90 Well-Known Member
    Houston, Texas
    98 XCab 3.4 Manual 4x4 SR5
    Headed to Baja this week and won’t have reliable access to premium fuel, what octane booster do y’all recommend? Preferably something I can pickup off the shelf.
  4. Aug 23, 2021 at 8:00 AM
    #3504
    Shortman5
    Supercharged TRD
    FWIW Kenne Bell recommends Lucas. If KB goes with Lucas it’s probably a good bet.
    Torco is one the internet seems to recommend.
    Water/Methanol is a good idea as well for an environment like that.
    unstpible and Bigal90 like this.
  5. Aug 23, 2021 at 8:37 AM
    #3505
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    Worst case scenario, you could zip tie the bypass valve open so Sc doesn't build boost. @Bigal90
    unstpible, Bigal90 and 1997tacomav6 like this.
  6. Aug 24, 2021 at 5:00 PM
    #3506
    Billnis
    Billnis Well-Known Member
    Bill
    Menifee, CA
    2001 White PreRunner Extra Cab 3.4L V6 Oak Int.
    PERFORMANCE: TRD Gen1 Supercharger, Snow Performance Water/Methanol Injection, Toyota E-Locker, Falken Wildpeak Tires, 5100 Bilstein Shocks, Redarc Tow Pro Brake Controller, B&M Transmission Cooler. EXTERIOR: Raptor Spray-on Bedliner, Custom NRT Off Road decals, Chase Rack with Offroad Lights, Fog Lights, Bed Lights, Rear Bumper Lights, Rago Bed Stiffeners, T1A Metal Door Handles, 7-Pin Trailer Connector, Switchback front turn signals, LED tail lights, License Plate Lights Shutoff For Backup Camera. INTERIOR: Android Head Unit with OBD2, Dash Camera, Backup Camera, TPMS, and Hands Free Microphone, Rockville SS8P Subwoofer, Remote Door Locks with Automatic Window Close, RFID Kill Switch, Custom Switch Panel, Hands Free Phone Mount, All LED lights LED, Ignition Light Ring, A pillar two gauge pod with VC-50 Meth Injection Controller and NRT Branded Oil Pressure gauge, Torque Pro App for Gauges (Wideband Air/Fuel, Water Temp, Trans Temp, MAF, Volts, Timing, Engine Load, Intake Temp, Throttle Position, Fuel Status - shows open or closed loop, Instant MPG.)
    Rebuilding the supercharger that came off of a wrecked truck I bought. A '98 and the supercharger was put on at the dealer when it was new. I turned it over to drain the oil from the snout and found this sticker.
    Does anyone know if it has any significance?
    1997tacomav6 likes this.
  7. Aug 24, 2021 at 5:06 PM
    #3507
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I’ll have to check my 98 with a 98 installed dealer blower. Lol probably nothing.
  8. Aug 24, 2021 at 5:15 PM
    #3508
    1997tacomav6
    Denver
    That’s the serial number, so it’s one of the 1st ones made,
    Interesting think is they did a recall on the 1st run of these superchargers tho
    unstpible likes this.
  9. Aug 24, 2021 at 5:43 PM
    #3509
    Billnis
    Bill
    Menifee, CA
    If there was a recall, does anyone know what it was? Hopefully the the recall wasn't a replacement and the problem was taken care of.
    The truck was a one owner vehicle and he was a service technician for Toyota.
    unstpible and 1997tacomav6 like this.
  10. Aug 24, 2021 at 5:55 PM
    #3510
    Shortman5
    Supercharged TRD
    You’re fine. Turn the pulley too see if it hangs up, feels like it’s rubbing anything, or has excessive play. If it’s turns smooth it’s probably good. Oil change would be a good idea.
  11. Aug 24, 2021 at 6:07 PM
    #3511
    1997tacomav6
    Denver
    I’m sure it would have been address at ‘this stage!
    I bought my supercharger new and was one of the 1st ones that bought one back then 1998
    A year later they exchange it on a recall, dont remember what it was for tho
  12. Aug 24, 2021 at 6:08 PM
    #3512
    Billnis
    Bill
    Menifee, CA
    When the truck was wrecked it ended up upside down letting a lot of oil get into the supercharger. going to take the SC apart to clean out the engine oil. While I have it open, going to do a rebuild of the snout and change the needle bearings in the back. Doesn't feel like it's rubbing on anything. or excessive play.
  13. Aug 24, 2021 at 7:31 PM
    #3513
    Empty_Lord
    Dan
    Speaking of rebuilds, what’s the go
    To nose rebuild kit. The 98 is at 95k. Since the engine will be easily accessible when it’s getting frame swapped, I think it’s due for a rebuild (although it sounds nice and quiet at idle)
  14. Aug 24, 2021 at 9:16 PM
    #3514
    Jon64l
    Jon
  15. Aug 24, 2021 at 9:49 PM
    #3515
    Empty_Lord
    Dan
  16. Aug 24, 2021 at 11:16 PM
    #3516
    Billnis
    Bill
    Menifee, CA
    I just ordered a few parts from Rolling Performance, they didn't have the rotor needle bearings in stock, I got those on ebay from The High Speed Lab. Since I have the 1st gen SC, I needed the bypass o-rings, I could only find those at Jon Bond Performance. I also got some of my parts from Khaos Motorsports.
  17. Aug 25, 2021 at 1:42 AM
    #3517
    1997tacomav6
    Denver
  18. Aug 25, 2021 at 2:11 AM
    #3518
    Billnis
    Bill
    Menifee, CA
    Oil Fill Drain Plug, going to tap a new hole in the top of the snout and us it fir the plug
    Delrin Supercharger Coupler
    ACDelco Supercharger Oil w/ Syringe 8oz
  19. Aug 25, 2021 at 1:22 PM
    #3519
    Billnis
    Bill
    Menifee, CA
    Not sure if it will make any difference, but since I have the tools to do it, I am making a 1/4" spacer out of Delrin plastic to go between the throttle body and the supercharger intake to hopefully lower possible heat that gets transferred from the supercharge intake to the throttle body. Any thoughts from people if they think this will do anything? I'd attach a picture of the spacer, but I am waiting for the Delrin to arrive. I made a prototype out of MDF and it fits really well. I am still weeks away from the installation.
  20. Aug 25, 2021 at 1:36 PM
    #3520
    Jon64l
    Jon
    Anything helps. Maybe try one where the SC bolts to lower intake manifold. Also try ducting around the air filter so you are not sucking in hot air that just passed through the radiator.
