3.4L supercharger
Discussion in '1st Gen. Tacomas (1995-2004)' started by CHMM, Sep 14, 2019.
  1. Aug 30, 2021 at 9:06 AM
    #3561
    1997tacomav6
    Denver
    My Emissions is the same as yours and I get one every two years, it not a problem for me
  2. Aug 30, 2021 at 4:21 PM
    #3562
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Was it the evap monitor that took so long?
    In CA for model years after 2000 you can still pass with the evap monitor not set.
    Could your state be the same?
  3. Aug 30, 2021 at 4:28 PM
    #3563
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Catalytic was what took forever. For literally no reason too
  4. Aug 30, 2021 at 4:41 PM
    #3564
    otis24
    Mark
    California
    Man…that sounds frustrating.
  5. Aug 30, 2021 at 4:42 PM
    #3565
    eon_blue
    Azusa, CA
    sorry, but
    I have no idea what you tried or didn't try but I've had it take longer than others sometimes, really depends on how much highway driving I do.
    I thought there was some specific routined outline in the FSM to get the monitors to be green after a battery reset, certain driving patterns/miles etc
  6. Aug 30, 2021 at 6:51 PM
    #3566
    Empty_Lord
    Dan
    Drive cycle per FSM never set it. Ultimately it was a 400 mile road trip when it finally decided it wanted to be passed
    eon_blue[QUOTED] likes this.
  7. Aug 30, 2021 at 9:50 PM
    #3567
    Empty_Lord
    Dan
    New plugs will be here tomorrow. @1997tacomav6 ’s recommendation of the ruthinium.
    Took the truck for a spin tonight, no pinging with the 65 degree IAT
    Milor and 1997tacomav6 like this.
  8. Sep 1, 2021 at 10:31 AM
    #3568
    Milor
    Milor Well-Known Member
    shaun
    03 Tacoma sr5 .TrD offroad 5spd..
    supercharged 2" pulley 6 puck clutch
    Amm my monitors are set except for my cat. which is crazy since the cats aren't but 1.5 years old. they look good not clogged. maybe my rear o2 sensor is lazy?
  9. Sep 1, 2021 at 11:56 AM
    #3569
    Empty_Lord
    Dan
    I had magnaflow cats. It seems anything other than oem takes forever to set the monitor
  10. Sep 1, 2021 at 11:58 AM
    #3570
    eon_blue
    Azusa, CA
    Hm, I have Magnaflows and a test coming up in the next month or two. Better not disconnect the battery until after lol.
  11. Sep 1, 2021 at 12:25 PM
    #3571
    Empty_Lord
    Dan
    Since I didn’t look super close, are the plugs on the driver side accessible without pulling the blower on the grey unit? Going to try and get the plugs done tonight
    Assuming I get off work on time
    1997tacomav6 likes this.
  12. Sep 1, 2021 at 12:42 PM
    #3572
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    You can get to them no problem. #6 can be a little tight.
    unstpible and 1997tacomav6 like this.
  13. Sep 1, 2021 at 1:39 PM
    #3573
    1997tacomav6
    Denver
    X2 if you have a magnetic spark plug socket it definitely is not hard.
    I usually remove that vertical metal bracket that’s attached to the supercharger
  14. Sep 1, 2021 at 1:42 PM
    #3574
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Bad oxygen sensor? I've seen the cats take forever to pass if at all due to faulty o2's.
    unstpible and Milor like this.
  15. Sep 1, 2021 at 1:43 PM
    #3575
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What do emissions have to do with the Haltech? I'd imagine it's a piggyback and not a standalone right? If it is a standalone then I rescind my statement, rather, question.
  16. Sep 1, 2021 at 3:17 PM
    #3576
    Empty_Lord
    Dan
    Haltech is stand alone
    no o2 sensor was fine. It’s just the way these trucks test and the magnaflow aren’t nearly as packed with shit as the factory one
    12TRDTacoma[QUOTED] likes this.
  17. Sep 1, 2021 at 4:08 PM
    #3577
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh. Damn, okay. Well then comment rescinded. Lol.
  18. Sep 1, 2021 at 4:14 PM
    #3578
    Loober
    Loober Well-Known Member
    I just went through the same experience with my 2002, took forever to set the the Cat monitor. Got pulled over twice over the course of 4 months driving it with expired tags. I would pull out my scanner and show the cop what I am trying to do, luckily they were cool about it.
    Empty_Lord likes this.
  19. Sep 1, 2021 at 6:15 PM
    #3579
    Empty_Lord
    Dan
    I had to get 3 1 month extensions by the time it set
  20. Sep 1, 2021 at 6:35 PM
    #3580
    Loober
    I dread when every time I get that notice in the mail
    otis24 likes this.
